Isolator - AC23A operation
  • Thread starter nisham
In summary, the differences between the AC22A and AC23A switches are that the AC23A is more robust and can handle more inductive loads.
Dears,
Can anyone brief what is the operation functionality of AC23A operation of isolators & what is the difference between AC22A & AC23A operation.
It would seem it's just a difference in ratings, AC23 being robust enough for more highly inductive loads.
http://www.hevacomphelp.com/ELEC/1pdf/MCP/0001.PDF
DEFINITIONS OF UTILIZATION
CATEGORY
AC20A Connecting and disconnecting
under no load condition.
AC21A Switching of resistive loads
including moderate overloads.
AC22A Switching of mixed resistive
and inductive loads including
moderate overloads.
AC23A Switching of motor, or other
Was that the question?
There'll be differences in contact size & material, and in the arc quenching apparatus.
This link gives power factor of 65% for AC22, 35% for AC23
http://www.gil-lec.co.uk/custom/upload/pdfs/circuit%20protection/Hager_Isolators_Switches.pdf
and suggests that a given switch may be used for more severe duty at reduced current
Manufacturers may assign more than one AC duty rating to their
devices. For example an AC22 switch can be given a lower
current rating when assigned to AC23 duty. Manufacturers may
also assign a maximum kW power rating for motors or a kVAr
reactive power rating for capacitors.
If you're looking for construction details , i'd take apart a few from different manufacturers to see how they get around one another's patents.
Thank you, even i have the same information as you have told. i would like to know what makes the AC23A duty to give a different current rating than other duty. Also what is the theoretical reason behind introducing such different duties in isolators.
nisham said:
Thank you, even i have the same information as you have told. i would like to know what makes the AC23A duty to give a different current rating than other duty. Also what is the theoretical reahttp://www.gil-lec.co.uk/custom/upload/pdfs/circuit%20protection/Hager_Isolators_Switches.pdfson [Broken] behind introducing such different duties in isolators.
again, http://www.gil-lec.co.uk/custom/upload/pdfs/circuit%20protection/Hager_Isolators_Switches.pdf
Common types of defined switching category:
• 20 Connecting & disconnecting under no load.
• 21 Switching of resistive loads.
• 22 Switching of mixed resistive & inductive loads.
• 23 Switching of highly inductive loads.
Have you ever played with inductors and noticed how the make an arc when you interrupt current?
That is rough service for a contact - it must be made from something that resists arc welding.
e = l di/dt
Suggested for: Isolator - AC23A operation
