1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Isomorph homework question
  1. Mar 8, 2008 #1
    2. Relevant equations&3. The attempt at a solution
    isomoprism is bijective
    i have no clue whatsoever..im gonna research a little bit now
    ill appreciate any help
  3. Mar 8, 2008 #2
    You are given that F is an isomorphism from X to Y and G is an isomorphism from Y->Z. You are asked to show that G[itex]\circ[/itex]F is an isomorphism from X to Z. I can guess that X, Y, and Z are vector spaces since another part of the problem talks about a "spanning set" but you should have said that! Proving an isomorphism of groups, rings, fields, etc. is quite different. An isomorphis is, as you say, bijective: you must prove this is surjective: that if z is any member of Z, then there exist x in X such that G[itex]\circ[/itex]F(x)= z. Since G is an isomorphism from Y to Z it is surjective: what does that tell you? Once you have that, you know that F is surjective from X to Y. Use that.
    An isomorphism must be injective also. If x1 and x2 are such that G[itex]\circ[/itex]F(x1)= G[itex]\circ[/itex](x2) then you must prove that x1= x2. Use can use the fact that F and G are each injective to prove that. Of course, a isomorphism must also "preserve" the operations. You need to show that G[itex]\circ[/itex]F(au+ bv)= aG[itex]\circ[/itex]F(u)+ bG[itex]\circ[/itex]F(v).
    As for b) using the definition of "span" together with that last statement: G[itex]\circ[/itex]F(au+ bv)= aG[itex]\circ[/itex]F(u)+ bG[itex]\circ[/itex]F(v) should be enough.
Similar Threads - Isomorph homework question Date
Proving a (known isomorphic) graph is isomorphic Nov 28, 2017
Isomorphism homework help Sep 25, 2008
Isomorphisms problem homework Oct 3, 2007
