Isomorphous Materials: Beyond Copper-Nickel Diagrams
  • Thread starter Alain47
  • Tags
    Materials
In summary, isomorphous substitution refers to the ability of one element or ion to substitute another in a compound, as long as their atomic sizes and charges are similar. This is possible even when the charges are different, as long as a charge compensation ion is introduced. Many different substances can form solid solutions through isomorphous substitution, such as minerals like corundum and eskolaite, which form the rare mineral ruby. There are also many other examples of solid solutions in minerals, metals, and soluble salts.
Alain47
I'm working on an assignment about phase diagrams and one of the topics we skim is isomorphous phase diagrams. As a topic its easy to grasp and the copper nickel diagram is a good example, however I was wondering if someone can outline any other isomorphous materials because I would like to use a different example and not the usual CuNi. I looked all over but could only find CuNi, any suggestsions?
Hi,
Usually one speaks about isomorphous substitution. One element can substitute another if its atomic size is similar. For ions, the situation is similar, but the charge must be also the same. Substitution is also possible if the charges are different, but a charge compensation ion must be also introduced. For compounds composed of several elements or ions, a few or all of them could be substituted. If all of the elements (ions) of one compound can be substituted by those of another compound one usually speaks about solid solutions. In this case, the crystal structures (best defined by their space groups) must also be the same besides ionic sizes and charges. There are a lot of possible combinations of substances which form solid solutions. Take for example aluminium oxide (the mineral corundum) and chromium oxide (the mineral eskolaite). Both have the same structure and chromium and aluminum have the same charge (3). The chromium oxide which is green substitutes isomorphically the alumina forming a pink (reddish or purplish) solid solution which is a rear mineral called Ruby. There are many other minerals which form solid solutions (e.g. garnets, spinels), many metals, soluble salts, etc.
1. What are isomorphous materials?
Isomorphous materials are solid solutions that have the same crystal structure and similar atomic sizes, allowing them to mix in all proportions. They are characterized by a single-phase microstructure and have a continuous, gradual change in properties across their composition range.
2. How are isomorphous materials different from other solid solutions?
Isomorphous materials are different from other solid solutions in that they have the same crystal structure and similar atomic sizes, while other solid solutions may have different crystal structures and/or atomic sizes. This allows for a greater range of compositional variations and leads to a more gradual change in properties.
3. What is the significance of isomorphous materials in materials science?
Isomorphous materials are significant in materials science because they provide a better understanding of the relationship between composition and properties. By studying the behavior of isomorphous systems, scientists can gain insights into phase transformations, material behavior under extreme conditions, and the development of new materials with tailored properties.
4. How are isomorphous materials represented in phase diagrams?
Isomorphous materials are typically represented in phase diagrams by a single-phase region where the composition of the material gradually changes. This region is often referred to as a solid solution phase or a continuous solid solution phase. The composition of the material is represented on the horizontal axis, while temperature is typically shown on the vertical axis.
5. Can isomorphous materials be used in industrial applications?
Yes, isomorphous materials have a wide range of industrial applications, including in the production of alloys, ceramics, and composites. They are also used in various fields such as aerospace, automotive, and electronics industries. The ability to tailor material properties through compositional variations makes isomorphous materials highly versatile and valuable in industrial applications.
  • Materials and Chemical Engineering
  • STEM Academic Advising
  • Beyond the Standard Models
  • Electrical Engineering
