Can Isopropyl Alcohol Be Used as Fuel for Rocket Engines?
In summary, creating a rocket engine using isopropyl alcohol as fuel is possible but it presents several challenges. The main challenge is finding a suitable oxidizer, as liquid fuels are more difficult to mix with oxidizers compared to solid fuels. Some common choices for oxidizers are ammonium nitrate and potassium nitrate, and it is also possible to use gaseous oxidizers in hybrid rocket motors. However, this requires precise control of the flow rate of the oxidizer. Isopropyl alcohol can also be diluted with water, making it important to carefully source the fuel. Ethanol may be a better alternative for rocket fuel, but obtaining it may present legal and safety issues. Creating a design to mix the fuel and oxidizer
yrjosmiel73
Y'know, just because. Will it be possible to create a rocket engine using isopropyl alcohol as fuel? Why or why not?
(will be used just for show and not really for sending ships to space. I'd rather have an entire school intact than it being blown to bits if I used hydrogen)
The challenge with liquid fuels in amateur rocketry is the oxidizer.
With solid fuels, there are a number of oxidizers that are solids and not too hard to mix in using amateur techniques. Some common choices are ammonium nitrate and potassium nitrate. It is also possible to make amateur rockets with solid fuels and gaseous oxidizers. These are known as hybrid rocket motors, the controlling the flow rate of the gaseous oxidizer controls the burn rate of the fuel. Often, O2 gas is simply used as the oxidizer in amateur rockets, but some professional designs use hydrogen peroxide.
So is that a yes, or a no? I'm taking it as a yes.
If you can't figure out what your oxidizer will be, it's a no.
So if I take O2 as an oxidizer, it's a yes?
If you can figure out a practical and achievable design to mix the fuel and oxidizer in the combustion chamber with available resources, it might be a yes.
It is theoretically possible. It will be practically difficult for amateurs.
How will the isopropanol and O2 be stored in the rocket? How will their flow into the combustion chamber be controlled at the proper rates to ensure proper thrust and a near stoichiometric mixture?
The amount of $ and expertise and weight needed to address these issues makes alternate designs (different fuels) much more practical.
Doing it to say you did is irrelevant if it costs and weighs 10 times more than more practical designs.
You also have to be careful of the source of your rocket fuel. Most of the isopropanol which is commercially available has been diluted in water to varying degrees.
The stuff from the drug store can be 50%, 70%, or 90% isopropanol. Sometimes, you have to look hard to find the 90% kind.
This is a good point. We use 90% isopropanol as our most common cleaning solvent in the lab. We pick it up at Walgreens and they seem to always have it.
For rocket fuel, I would probably use ethanol instead. 95% ethanol is available in liquor stores as Everclear. It's more expensive due to the tax, but cutting the water in half would improve the qualities as a fuel, and odds are a single bottle will go a long way in amateur rocketry. Just don't drink the stuff.
Ethanol and isopropanol are our favorite lab solvents, because they are safe for skin contact. Even though we usually wear gloves, contact is hard to avoid and other common solvents tend to be dangerous (except water).
That's what I use it for. Sometimes, though, the stock may be limited at a particular store.
This presents a couple of possible problems.
The OP seems to indicate that he is a student of some sort. I wouldn't advocate that any possibly underage students go cruising to the local liquor store for alcohol, lest they get themselves or the store in trouble for selling alcohol to minors.
Carrying potable alcohol on school grounds could violate a number of school regulations and/or local laws. I would rather the OP get a chance to shoot his rocket, rather than face suspension from school or a trip to jail.
It would be wise for the OP to obtain permission/clearance from school officials before bringing these materials to school.
Likes yrjosmiel73
Yeah, I'm not the best artist (I'm struggling with 2 art projects and failing them miserable right now) but I'll try to show the supposed design.
I'm trying to do something new. If this doesn't work, then that's a new thing to learn today!
The oxidizer and isopropyl alco might as well as get mixed in the pump.
Mixing a liquid and a gas in a controlled and defined ratio in most pumps is tricky business.
What if, pipes with different diameter so different amounts will flow?
Whoa! Slow down!
If you are talking oxygen in the vapor stage, every gram of alcohol is going to need 19 grams of oxygen. That's 13 liters.
If you want to get the volume down by pressurizing the oxygen, what experience do you have with high pressure systems? If you want to get the volume down by liquifying the oxygen, what experience do you have with cryogenics?
Vanadium 50 said:
Whoa! Slow down!
I actually don't need this to be flying. Yes, I'm planning to use gaseous oxygen. Volume is not very much a problem.
The pump probably will be an issue though. Pressure fed will likely be much simpler and easier to make functional. There's a lot of potential for danger here as well - rockets (by their very nature) have a lot of energy, and can sometimes violently release that energy in unexpected ways. I'm not convinced you know what you're doing well enough to end up with much more than just a pipe bomb here.
Likes Vanadium 50
I will note that I saw 91% isopropanol in the pharmacy section of Sam's Club while waiting for my flu shot today.
I'm not sure this makes me feel better. A rocket that doesn't fly is pretty much just a flamethrower.
Likes Dr. Courtney
I wouldn't necessarily agree with that - you can learn a lot from static firing a rocket, and the supersonic exhaust and large amounts of thrust produced by a rocket make it fairly different from a flamethrower. If all you are interested in is the pyrotechnics, there are significantly cheaper and better ways to make large amounts of fire.
In that case, I have a great bargain for you. A tank suitable for your gaseous O2 oxidizer sits unused and abandoned in Green Cove Springs, Florida. It was built for the NASA space shuttle. Make them a reasonable offer. :wink:
Likes yrjosmiel73 and Drakkith
We've done a lot of static firing to measure thrust curves and quantify impulse and specific impulse and the effects of various factors. Sure, it can be useful to tweak a design and diagnose issues.
But if the whole design has insurmountable technical barriers to actually flying (too heavy, etc.), what's the point?
It can be a nice educational tool. Experiment with different nozzles, chamber pressures, etc and see how it affects performance. A heavy rocket engine can also be a good first step towards a flyable one - once you've instrumented and tested the heavy one, you can see where mass could be removed, what could be optimized, etc.
It's not impossible that one can learn something with non-flying rockets, In this case, though, it's clear that the OP has nowhere near the expertise to do this safely. He doesn't understand the basic stoichiometry of fuel and oxidizer. His diagram on post 10 has combusion occurring inside the pump - not good. And, as pointed out, it's not like this won't quite fly. It's not close.
Based on the OP's level of knowledge and experience, this thread is closed.
To the OP -- please seek our your local amateur rocketry club to get the benefit of their experience and the oversight of their Mentors.
Likes yrjosmiel73
1. What is an isopropyl rocket engine?
An isopropyl rocket engine is a type of rocket engine that uses isopropyl alcohol as its fuel source. Isopropyl alcohol, also known as rubbing alcohol, is a colorless and flammable liquid that is commonly used as a disinfectant. In rocket engines, it is combined with liquid oxygen to create a powerful combustion reaction that propels the rocket forward.
2. How does an isopropyl rocket engine work?
An isopropyl rocket engine works by combining isopropyl alcohol with liquid oxygen in a combustion chamber. The liquid oxygen acts as an oxidizer, which helps to ignite and sustain the combustion reaction. As the mixture burns, it creates a high-pressure gas that is directed through a nozzle, providing thrust and propelling the rocket forward.
3. What are the advantages of using an isopropyl rocket engine?
One of the main advantages of using an isopropyl rocket engine is that it is relatively inexpensive compared to other types of rocket engines. Isopropyl alcohol is readily available and affordable, making it a popular choice for amateur rocket builders. Additionally, isopropyl rocket engines are relatively simple in design and can be easily scaled up or down depending on the size of the rocket.
4. Are there any risks associated with using an isopropyl rocket engine?
Like any type of rocket engine, there are risks associated with using an isopropyl rocket engine. Isopropyl alcohol is highly flammable, so proper safety precautions must be taken during the building and launching process. It is also important to carefully follow instructions and guidelines to ensure the engine functions properly and does not cause harm to individuals or property.
5. What are some common uses of isopropyl rocket engines?
Isopropyl rocket engines are commonly used in amateur rocketry and model rocketry. They can also be used in larger rockets for scientific research or as a propulsion system for satellites. Additionally, isopropyl rocket engines have been used in military applications such as target drones and sounding rockets.
  • Aerospace Engineering
