Is Isospin Conservation Related to Angular Momentum Conservation in Weak Decays?
In summary: This is why we shall adopt a more general view and define and angular momentum \mathbf{J} as any set of three observables which satisfies: [J_i,J_j]=i\hbar\epsilon_{ijk}J_k.
quasar987
Homework Helper
32
In weak desintegrations, the isospin is not necessarily conserved. But is the total angular momentum J=L+S+I always conserved?
Yes. The total angular momentum conservation is twin to energy and linear momentum conservation, and that has never been observed to be broken. :approve:
This is not the answer I was hoping for!
I have this problem here that roughly says "a B particle disintegrate into a pi+ and a pi-". So I said "B has isospin 1/2, spin 0 and (there exists a ref. frame where B has) L=0. So that's J=1/2 for B. I know that the state ket for pipi must be symmetrical (2 indistinguishable bosons). And now I know that J total must be conserved.
Can someone show me the reasoning behind how to extract the nature (symmetric or antisymmetric) of [itex]|\pi^{+}\pi^{-}>[/itex] given the above information.
I'm sorry I did not notice that you include isospin in your angular momentum. I'm not sure what you are doing here. Possibly G-symmetry...
Usually, J=S+L is the total angular momentum. Isospin is analogous to spin but acts in internal space, unlike spin and angular momentum.
So the isospin is an angular momentum in the sense that it obeys the commutation relations defining an angular momentum ([itex] [I_i,I_j]=\hbar\epsilon_{ijk}I_k[/itex]) but for conservation of J to hold, we must not include it in the total angular momentum.
No, isospin isn't angular momentum in any sense. Yes, it obeys an algebra that is a carbon copy of that used for angular momentum. But a nucleon that is "isospin up" is a proton, and a nucleon that is "isospin down" is a neutron. This has got nothing to do with the z-component of its angular momentum.
I think you're getting 2 different things confused here. You quote the total angular momentum as J=L+S+I, and then call I the isospin. But most textbooks refer to I as the nuclear spin, which is an angular momentum. Isospin is usually represented by [itex]\tau[/itex].
Cohen-Tanoudji defines angular momentum as any operator which satisfies the commutation relation [itex] [J_i,J_j]=\hbar\epsilon_{ijk}J_k[/itex].
This is why I called the isospin an angular momentum.
But it doesn't add to L and S.
He does !? :confused:
That only defines a symmetry group, not to what the symmetry is applied (as Tom Mattson said).
I am quite bugged.
So, what you are doing has no link with G-symmetry ? You were mentionning weak interaction. It maximally violates parity, so combining parity and isospin reverse, you often get (almost) conserved quatities...
The J=1/2 is wrong. Ispin has nothing to do with angular momentum.
Just the math is similar.
The two pions have L=0, a symmetrical state.
First sentence of p.646: This is why we shall adopt a more general view and define and angular momentum [itex]\mathbf{J}[/itex] as any set of three observables which satisfies: [itex] [J_i,J_j]=i\hbar\epsilon_{ijk}J_k[/itex]
I don't know what G-symmetry is; this exercise is in the context of the Wigner-Eckart theorem in an ordinary undergrad QM class.
quasar987 said:
First sentence of p.646: This is why we shall adopt a more general view and define and angular momentum ...
:rolleyes: what is the previous sentence... or what was he talking about :confused:
As Meir Achuz said, the pions are in a L=0 state, which must be symmetrical.
The three operators associated with the components of an arbitrary classical angular momentum therefor satisfy the commutation relation [itex][L_i,L_j]=i\hbar\epsilon_{ijk}L_k[/itex]. It can be shown, moreover thatthe origin of these relations lies in the geometric properties of rotation in three-dimensionnal space. This is why...
OK, fine: Isospin doesn't satisfy that algebra, if only because there is no [itex]\hbar[/itex] in there. The isospin matrices satisfy:
[tex][\tau_i,\tau_j]=i\epsilon_{ijk}\tau_k[/tex]
There are no angular momentum units anywhere in there.
Actually, I've been thinking about my last post and I'm not satisfied with it. In natural units (where [itex]\hbar=1[/itex]), the algebras are identical. So that's not why isospin is not an angular momentum.
Angular momentum is the generator of rotations in the normal 3-space in which we all live. It is conserved in physical systems that are invariant under rotations in that space. Isospin, on the other hand, is the generator of rotations in a completely different space altogether, called isospin space. Isospinors are not elements of the eigenspace of [itex]J[/itex], and neither are spinors elements of isospin space. And there is no reason that conservation of [itex]J[/itex] should imply anything about conservation of [itex]\tau[/itex], and vice versa.
What is isospin and why is it important in particle physics?
Isospin is a concept in particle physics that describes the symmetry between particles with different electric charges but the same strong interaction. It is important because it allows us to understand the behavior of particles in nuclear reactions and helps us classify and organize the different types of particles.
What is conservation of angular momentum and how does it relate to isospin?
Conservation of angular momentum is a fundamental principle in physics that states that the total angular momentum of a system remains constant unless an external torque is applied. This principle also applies to isospin, as particles with different isospin values can interact and change their isospin states, but the total isospin of the system remains constant.
What is the relationship between isospin and spin?
Isospin and spin are two distinct properties of particles, but they are related in that they both describe the intrinsic angular momentum of a particle. Isospin is specifically related to the strong interaction, while spin is related to the electromagnetic and weak interactions.
What is the role of isospin in the study of the strong nuclear force?
Isospin is crucial in the study of the strong nuclear force because it allows us to understand and predict the behavior of particles in nuclear reactions. By classifying particles based on their isospin values, we can determine how they will interact with each other through the strong force.
How is isospin conserved in nuclear reactions?
In nuclear reactions, isospin is conserved through the strong force. This means that the total isospin of the initial particles must equal the total isospin of the final particles. If this principle is violated, it indicates that another force, such as the weak or electromagnetic force, was involved in the reaction.
