Issue Using Defines In C
  • Thread starter Lancelot59
Lancelot59
643
This is once again for my robot. My current issue is with a define command:
I have the following function defined in motor_control.c:
Code:
//Motor Control Functions
void forward(void)			//Go striaght forward
	motorR(THROTTLE,TRIM);
	motorL(THROTTLE,TRIM);
The throttle value controls speed, trim offsets the speed variable. Although it probably will be eliminated.
Anyhow, I have throttle defined in a header called system_config.h:
Code:
#define THROTTLE = fast 	//Default forward throttle value to use
The value for "fast" has been enumerated in the header for motor_control.c
I have included the system_config.h file in the motor_control.c library, so what can't I see it? As far as I'm aware it should be able to see that defined value.
Answers and Replies
magwas
125
Show error messages.
D H
Staff Emeritus
Insights Author
15,415
687
Get rid of the equals sign.
#define THROTTLE fast
Lancelot59
643
...That was a silly mistake. Thanks for the catch.
The only error message I got was a syntax error when the compiler got to the first function that tried to pass THROTTLE to a function. It didn't say anything else.
Thanks again for the help.
8,199
The code your compiler saw was this.
Code:
motorR(= fast,TRIM);
motorL(= fast,TRIM);
The reason for this is that the #define preprocessor directive does nothing more than text replacement. This is why you DON'T want to put = in simple preprocessor directives.
Lancelot59
643
I see, that makes sense.
Suggested for: Issue Using Defines In C
  • Last Post
  • Last Post
  • Last Post
Comp Sci C++ array issues
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
