Understanding Relativity: Chat with a Physics Professor Online for Clarity
In summary, the expert says that if two particles are going the same speed, and one has eyes, it would say that the other particle is going zero relative to it. If the particles are going opposite directions, then the one with eyes would say the other particle is going 1.6 relative to it.
  • #36
You expected that by applying Lorentz contractions of time and space, you would get a different measurement of the velocity of the object itself when "it" measured its own velocity against the walls. When you didn't, you were dumbfounded. You expected such result to explain the apparent paradox. Something like the object measuring a different speed, like 0.4878c. Then you would add the two velocities to get twice that, ie 0.9756c. Well, that's not how it works. The fact that you cannot just add the two velocities to see how fast each object moves with respect to the other is - for you, and everybody that starts with this - completely absurd. You have been doing that all through your school years. It's a kind of indisputable, mathematical axiom. Well, it's not. What can you expect in a world where something (light) has the same speed for you even if you are running towards it or away from it? The consequences are immense. Think of why you think you can just add velocities. Take three observers: O, A and B. A moves with Va with respect to O. B moves with Vb with respect to A. How can O determine the speed of B with respect to him? Try to think of an experiment that will give O this speed. In order to do that, O needs to observe B at one place x at time t and then observe him again at x' at time t'. Follow that line of thought...
  • #37
I showed you in detail in Post #14 what A does measure when he measures how fast -A is moving away from him. Have you even tried to understand this?
yes i understood what you are saying. did you try to understand my reply to this post? (#16)
  • #38
phillip1882 said:
yes, i saw the links, i clicked the links, i read the links. i saw nothing in those links explaining what physical mechanism could possibly cause motion to remain constant relative to one observer, but change drastically relative to another.
Why do you require a mechanism before you will accept that it is true? Do you need an explanation of the mechanism of gravity before you will accept that it exists?
  • #39
I answered those in detail in Posts #20 and 22.
  • #40
What is a "physical mechanism" in your meaning? When most people think of the "physical mechanism" of relativity they think of the two postulates: the principle of relativity and the invariance of c.
I assume that you are aware of the two postulates, so you must not think of them as being a physical mechanism. So what do you mean by the term? What kind of explanation are you looking for? The postulates seem to work for everyone else, do you disagree with them?
  • #41
okay, i can see I'm not making any headway, and neither are you guys, so now I'm basically just a troll at this point. when you feel like a troll, it's time to end the conversation. i apologize if I have offended anyone, and that i couldn't make my points more clearly understood. thanks for trying guys. appreciate your dedication to educating an ignorant, misinformed soul. :-) hope no hard feelings. if you wish to continue this conversation, i don't mind but, i feel like I'm wasting your time. so, perhaps if one of you wants to pm me that would be better, i don't know.
  • #42
I can't see post numbers, but I think you are asking about this and its follow-up:
phillip1882 said:
you're using the speed of light itself to determine the seped of two objects that could potentially be moving faster than the speed of light.
No, you're not. As it turns out, objects can't travel faster than the speed of light. In fact, all objects measure themselves to be stationary with respect to the speed of light, meaning they always measure the same speed of light, regardless of if they think they are moving or not. So for example, if someone is moving at 200,000 km/sec they don't measure the speed of a light beam to be 200,000-100,000=100,000 km/sec, they still measure it to be 300,000 km/sec.
I would like to point out that sound has similar properties.
Indeed it does. And for a long time, people believed that that meant light and sound behaved in exactly the same way, traveling at a fixed speed in a medium that was stationary in a single reference frame. But a little over 100 years ago, it was discovered that light in fact travels at a fixed speed in every (non-accelerating) reference frame.
if velocity is unchanging, even factoring in space and time dilation, then velocity should be relative to your motion.
The way you worded that doesn't really make much sense. Velocity is a measure of motion so you just said velocity is relative to itself (or motion is relative to itself).
i accept...
i find it hard to believe that...
i just personally don't see how it logically adds up.
Relativity appears counterintuitive at first glance, but it only looks illogical because the starting premise we are used to turned out to be wrong (the first part of this post). To be blunt: the universe doesn't care if you accept how it works or not. It is up to you to let go of your prejudices and preconceptions and accept the way it really works if you really want to know how it works. All I can suggest (as others did) is do the math and look at the experimental evidence.
  • #43
Draw out what you are trying to do, start with them both moving away from a mid point at .8c. Then switch to a different frame of reference, and take note of the speed of light and where the light would be.
  • #44
Good discussion. I hope we have helped you make some progress. Remember that if by "making headway" you mean "disproving relativity" then you will never make any headway, because it is correct.
  • #45
Hi phillip1882,
It occurs to me that you may be confounding two different mathematical operations and getting confused. One is the composition of velocities (commonly but confusingly called "velocity addition").
Velocity composition is a transformation from one frame to another, i.e. if a velocity is v in frame V then what is its velocity in frame U where U is moving at velocity u wrt V? The answer is $$\frac{v-u}{1-vu/c^2}$$ Note that something at rest in V (v=0) will have a velocity of -u in U. Note also that if v=c then the result is c, regardless of u.
So velocity composition transforms a velocity in one frame to a velocity in another frame. That is the first mathematical operation. The second mathematical operation is called separation velocity, this is simply the difference in velocities. Note that in order to calculate a separation velocity, the two velocities must be in the same reference frame. Note also that separation velocity does not represent the velocity of anything physical, so it is not limited to c and does not represent superluminal transfer of energy or information. Separation velocity is just v1-v2 where v1 and v2 are the velocities of particle 1 and particle 2 respectively in a given reference frame.
  • #46
DaleSpam said:
Hi phillip1882,
I hope this isn't the cause of the confusion, since it's what I addressed in one of the very first posts in this thread.
  • #47
well, its somewhat the cause of confusion.
here's how i feel the conversation went.
can you add velocities in an intertail frame of reference? yes. if an inertial frame sees two objects going two velocities, you can add and subtract them.
are all inertial frames equivalent? yes, this is the first law of SR.
If B sees A going 0.8, would A see B going 0.8? yes, though the distance traveled and the time it took to get there would be different.
if two objects each going 1.6 away from each other from one inertial frame, can they do so from their own inertial frame? no, because the second law of SR prevents this.
it's like you're saying the law of addition applies, but not to myself, which is a confusing state of affairs to me. in my opinion SR should state one of the following.
a) space and time dilation lead to a change in velocity.
b) you can never add two velocities from any frame of reference.
c) the speed of light is relative to the observer but constant relative to the space it's occupying.
if relativity stated one of these things, then it would make sense to me, and if it stated C it would be in line with every observation i can think of. Can you think of an experiment that was tried that lead to C not being true?
  • #48
In regard to these counter-intuitive things that lie outside our realm of normal experience, I like this quote from Feynman. He was talking about quantum mechanics, but I think the temptation to ask "How can it be like that?" applies equally well to relativity.
"The difficulty really is psychological and exists in the perpetual torment that results from your saying to yourself, "But how can it be like that?" which is a reflection of uncontrolled but utterly vain desire to see it in terms of something familiar. I will not describe it in terms of an analogy with something familiar; I will simply describe it. There was a time when the newspapers said that only twelve men understood the theory of relativity. I do not believe there ever was such a time. There might have been a time when only one man did, because he was the only guy who caught on, before he wrote his paper. But after people read the paper a lot of people understood the theory of relativity in some way or other, certainly more than twelve. On the other hand, I think I can safely say that nobody understands quantum mechanics. So do not take the lecture too seriously, feeling that you really have to understand in terms of some model what I am going to describe, but just relax and enjoy it. I am going to tell you what nature behaves like. If you will simply admit that maybe she does behave like this, you will find her a delightful, entrancing thing. Do not keep saying to yourself, if you can possible avoid it, "But how can it be like that?" because you will get 'down the drain', into a blind alley from which nobody has escaped. Nobody knows how it can be like that."
  • #49
I can't resist a couple more comments:
(1) One of the whole lessons of relativity is that there is no "relative to the space its occupying". There are no signposts scattered through space which you can use to measure velocity " relative to space". You can only measure velocity relative to physical objects.
(2) I'm not sure what you mean when you say that "the speed of light is relative to an observer". Do you mean that different observers will measure different speeds of light depending on their state of motion? If so, this is demonstrably false, as shown by the Michelson-Morley experiment.
(3) The universe behaves the way it behaves, whether or not it makes sense to you. Saying, "I cannot accept that the universe behaves this way," will get you nowhere.
  • #50
Not just because there's a "law" that says no. I showed you how to use SR to calculate the velocity of B in the inertial coordinate system that's comoving with A. You didn't reply to that.
I don't know what you mean by those statements.
a) Do you mean that if the speed of B relative to A is v, the speed of A relative to B is not -v? SR states very clearly that the speed of A relative to B is -v.
b) Are you talking about how the rate of change of the coordinate distance between A and B is 1.6c, in the coordinate system in which A has velocity -0.8c and B has velocity 0.8c? This couldn't be any other way, because it's part of what we mean by things like "position", "time", "distance", "rate of change", etc. It doesn't have anything to do with what theory of physics is the most accurate. There isn't even a change of coordinates involved, since we're doing everything in one coordinate system.
c) Here I can't even guess what you mean.
I think the main problem is that you keep relying on intuition instead of asking yourself what the theory actually says. Look at this again:
phillip1882 said:
well sure it does.
if A is traveling at 0.8 relative to B
and -A is traveling at -0.8 relative to B,
then A relative to -A should be 1.6.
In the last line you used only your intuition, and ignored the definition of "A relative to -A". "A relative to -A" is defined as the velocity of A in the inertial coordinate system that's comoving with -A. So to know what the velocity is, you must know what that coordinate system is, or at least how it's related to the one in which A and -A have velocities 0.8 and -0.8 respectively.
This is a non-trivial subject. Your intuition is telling you that the two coordinate systems must be related by a Galilean transformation. (This is what everyone's intuition is telling them, even if they don't know what a Galilean transformation is). But there's a rather sophisticated mathematical argument that shows that there are exactly two types of transformations that can be used in theories of physics to describe the relationship between two inertial coordinate systems: Galilean transformations and Lorentz transformations. The theory that uses Galilean transformations is prerelativistic classical mechanics. The theory that uses Lorentz transformations is special relativity. So you have to use a Lorentz transformation here, by definition of "special relativity".
Your intuition is tricking you to into not using SR some of the times when you try to answer your own questions. That's why the theory seems inconsistent to you. If you use some SR ideas (time dilation, Lorentz contraction), while ignoring others (relativity of simultaneity), the results you get will certainly not make sense.
  • #51
One of the principles of relativity is to ditch the concept of 'space' and rather focus on how distances are measured in this 'space'. And how would you be able to measure its speed relative to the 'space it's occupying' ? In physics, you only talk about things which you can measure and for which a concrete procedure can be carried out to measure it. Otherwise, its not physics, its not even science.
To understand relativity you need to critically think about the concepts of space and time. This is something you can understand only by pondering over it with assistance from some book, and not by discussing in the forum. Two books come to my mind here - one is the small book written by robert resnick(i don't know if it is still in publication) and the other one is the one by Einstein written for the lay reader. These are good starts but no book can really hand it over to you you need to put the pieces together yourself.
So I don't really think anything written on this forum can really help you you got to meditate upon it yourself with assistance from written material. Good luck!
  • #52
This is the separation velocity. All of the velocities are calculated in a single frame.
Here you are asking how velocities in one frame transform into another. This is a fundamentally different question, so it shouldn't be surprising that it requires a different formula.
Again, this is asking how velocities transform between frames.
  • #53
I'm not trying to be difficult, I'm just trying to state what logically makes sense to me.
yes. either velocity should change, allowing the property of addition to apply, or the property of addition should not apply to any observer.
I'm not quite sure how to respond to this, as i feel I've addressed this several times already.
okay. we all agree that, no matter what direction you fire a light beam in air, it will have the same velocity.
so i would argue the speed of light relative to air is constant. however, if i ran toward toward a light beam, i would measure a different velocity of light.
if a star emits a light beam, the light beam relative to the background radiation, (the light and electromagnetic radiation of other stars) will always be the same value. therefore i would argue that the speed of light relative to the star is changing. can you prove other wise? please no math, just logic.
okay, you're really hung up on this, so let me do the following.
let me make the following assumptions.
1) there is an instantaneous method of determining distance and time.
2) there is no fundamental speed limit
3) the detector of distance and time can only measure in one direction.
Code:
<-----OO------>    O----->
 50          60             50
what's actually occurring, according to an impartial observer.
Code:
<-----------O|O             <-O
     110                          10
what's occurring according to the 60 m/h ball.
Okay. Imagine I have two balls each traveling apart at 50 miles an hour. after 1 hour, they are 100 miles apart. to determine the distance, the 50 mile an hour ball fires a 60 mile an hour ball toward the other 50 m/h ball. each ball has a diameter of 1 mile, so each ball can know how far away they are based on their own size, and each carries an accurate method for determining time.
the 60 m/h ball can't detect his own motion of course, but he sees the distant 50 m/h ball approaching him in a very odd manner. despite the fact he can detect the distance between himself and the distant ball as roughly 100 miles, it seems that the distant ball covers a distance of 600 miles in a time span of 10 hours, despite the fact the ball is traveling toward him. he concludes some sort of time space dilation must be occurring.
he doesn't know how much time dilation is occurring yet, but he can safely assume that space is being dilated by a factor of 6, and guesses that the ball must be traveling toward him at a rate of 10 miles/hour. now that the 50m/h ball has reached him, the 60 mile/hour ball bounces of the 50 m/h ball and is now traveling 60 m/h in the opposite direction. wow. the other ball is now a distance of 1100 miles away from him, despite the fact that only 10 hours have passed. he knows space is being dilated by a factor of 6, so 1100/6 = 183 miles must be the actual distance between him and the distant ball. dividing the two, he concludes that the ball must be traveling at a rate of 18.3 miles an hour. he doesn't know if time is being dilated yet, so he checks. it takes a very strange 18.3 hours for the ball to reach him, instead of the expected 10! "since I've already factored in space dilation, the only explanation must be time dilation." he reasons. dividing the two, he concludes that time must be dilated by a factor of 1.83. factoring in both,velocity must be being dilated by a factor of 3.27. therefore the original ball must have been going a speed of 600/10 = 60, 60/3.27 = 18.3 miles per hour, and the other must be going the same in the opposite direction. his job finished, he reports back that the velocity between the two 50 mile an hour balls is roughly 36.6 miles/hour.
  • #54
You can argue that all you want, but it's just not true. That's why we do experiments, to check our intuitive arguments against how the world really works. The experiments say that if you run towards a light beam you won't measure a different velocity of light, although you will measure a blue shift.
Hard to do, because logic is a branch of mathematics.
  • #55
SR and pre-relativistic classical mechanics are both defined to be consistent with some basic symmetry assumptions about space, in particular rotation invariance. This ensures that both of these theories will agree that if the velocity of A relative to B is v, the velocity of B relative to A is -v.
I'm not saying that a theory in which the velocity of B relative to A is different from -v is logically inconsistent, but I am saying that such a theory has nothing to do with relativity.
I haven't seen you do it. If A's position at time t is given by ##x_A(t)=-vt##, and B's position at time t is given by ##x_B(t)=vt##, then the distance between them at time t is, by definition of distance, ##x_B(t)-x_A(t)=vt-(-vt)=2vt##. If we denote this by d(t), then the rate of increase of the distance is defined to be d'(t), and this is equal to 2v. Note that everything follows from the definitions. There's no physics in this problem.
Right, every theory that's consistent with rotational invariance would say this, so we don't even have to use SR. Pre-relativistic classical mechanics says the same thing.
According to pre-relativistic classical mechanics, yes. According to SR, no. And experiments say that SR is right about this (or at least a lot less wrong than pre-relativistic classical mechanics).
You're just telling me what your intuition is telling you, and your intuition is telling you all the things that pre-relativistic classical mechanics says, because that theory was made to agree with our intuition. SR on the other hand was made to agree with the idea that you won't measure a different velocity of light when you're running toward the light source. (In 1905, this could be motivated both by Maxwell's equations and the Michelson-Morley experiment).
This is like asking me to run without using my legs. Proofs are mathematical, and they're done within the framework of a theory. It doesn't make sense to ask for a theory-independent proof that doesn't rely on math, because there's no such thing.
I also don't understand what you said before that, so I don't even know what you're asking me to prove.
Both of these assumptions contradict SR, but are consistent with pre-relativistic classical mechanics. So I hope you won't be mentioning anything relativistic later, because then you'll be contradicting yourself as well.
There's nothing like that going on here. Consider an external observer who sees ball A go at -50 mph, ball B at 50 mph and ball C at 60 mph. From ball C's point of view, ball C is stationary and ball B is 100 miles away and moving towards ball C at 10 mph. This will take 10 hours. From the external observer's point of view, the position of ball C at time t (in hours, after it left ball B) is -50+60t, and the position of ball B at time t is 50+50t. Set the two equal and solve for t (to find the value of t at which both balls have the same position). The result is 10. The external observer and ball C agree that it takes 10 hours. There's no time dilation or anything like that at all.
Your assumptions imply that there's no time dilation. Your conclusions appear to be a result of combining coordinate assignments made by different coordinate systems in a bad way.
  • #56
I don't know what is so hard to understand here.
In any frame you can take velocities measured in that frame and use ##v-u## to get the separation velocity between V and U that frame. In any frame you can take velocities measured in that frame and use ##(v-u)/(1-vu/c^2)## to get the velocity of V in U's frame.
What is in any way unclear or inconsistent about the above?
  • #57
in any frame you can take velocities measured in that frame and use v−u to get the separation velocity between V and U that frame. In any frame you can take velocities measured in that frame and use (v−u)/(1−vu/c2) to get the velocity of V in U's frame.
re read this again please.
if i can add and subtract v and u to get the velocity between v and u in a frame of reference, and time dilation and space dilation doesn't change velocity, why would v see a different velocity with respect to u?
well, no.
for example i can prove that the force of gravity must change with mass.
if if we accept Newtons first hypothesis, Force = Mass* acceleration, and we know all falling objects accelerate at the same rate, then when mass changes force must change with it.
now. we have two hypothesis of Einstein. 1) the laws of physics are constant with respect to all frames of reference. okay i agree with this, there's no argument from me here. the speed of light is constant with respect to all frames of reference. okay i disagree with this part, because in my opinion it leads it impossible to detect a particle that could potentially be moving faster than the speed of light.
the Michel Morley experiment doesn't prove light is constant in all frames of reference. what the Michel Morley experiment proves is that you cannot push a light beam that's traveling through medium any faster.
here's three experiments i would recommend.
#1) measure the speed of light in a strong wind versus a calm day. i strongly suspect that if the medium changes velocity so will the speed of light.
#2) measure the speed of light on an airplane that's going faster than the speed of sound. I strongly suspect the speed of light will measure the same value, despite the fact the plane is in motion, which again doesn't prove light is constant to all observers, just constant to the medium it's traveling in.
#3) have the light beam that's fired inside the plane exit the plane and hit a target on the ground. the light beam will change velocity, for the same reason as it would in experiment #1.
if you disagree with this assessment, please try these experiments for yourself.
we know for a fact that the speed of light changes depending on the medium it's in. so how can the speed of light possibly be constant for all observers?
and again i would like to state that sound has this same property.
  • #58
If you are asserting that light requires a medium to propagate, this would be contrary to observed fact, contrary to relativity and provocative in the extreme considering how many people you have ignored in this thread.
The speed of light in a vacuum is the universal constant. Intoducing media is irrelevant to the issues you've raised.
  • #59
Simple. You can't add and subtract velocities as vectors.
Strictly speaking, the only time it is valid to add or subtract velocities is if one of them is zero. That one apparently can add or subtract velocities is a consequence of the errors becoming immeasurably small in the world of everyday events where velocities are less than one millionth of the speed of light (670 miles per hour).
Just because it appears that something is valid in our ordinary, everyday world does not mean that it is universally valid. Newtonian mechanics falls apart in the realms of the very small, very large, and very fast. Extrapolating your everyday experiences to domains orders of magnitude removed from those experiences is, simply put, wrong.
  • #60
That first thing follows immediately from the definitions of position and derivative, and is the same in all classical theories of motion (including SR). That other thing follows from the definition of special relativity, which states that inertial coordinate systems are related by Poincaré transformations. (Lorentz transformations if they have the same origin).
You can't just jump to conclusions based on what your intuition is telling you, and ignore what the theory is saying.
phillip1882 said:
well, no.
You just used a theory and mathematics. :smile: These are the two things you told me not to use.
You disagree with the postulate that gave us the most successful scientific theories in human history?
This conclusion is incorrect. And in SR, a particle either stays slower than c through its entire existence, or stays faster than c through its entire existence. Particles of the second type are believed not to exist.
I'm not even going to address the rest of your misconceptions. You need to think about whether you want to learn relativity or not. If you do, then you need to start asking questions about relativity, and stop making arguments based on your intuition and your ignorance of what the theory says.
  • #61
He was asking why you can't do that. I posted a complete answer to that in #24. Unfortunately, he's not interested in an answer that uses mathematics or is based on special relativity.
  • #62
Because velocities in one frame don't directly tell you anything about velocities in another frame. You have to transform into the other frame to get velocity in the other frame.
This has nothing to do with special relativity. This has to do with coordinate transformations. If a value is coordinate-dependent (like velocity) then the value in one coordinate system doesn't tell you anything about the value in another coordinate system, you must transform to the new coordinate system.
  • #63
This is simply wrong. Here is a thread where we discussed this at length:
https://www.physicsforums.com/showthread.php?t=683408&page=2
See in particular posts 23 and 28.
It is not impossible to detect v>c, the fact that we have not detected any particle with v>c is due to the behavior of all known particles, not due to a limitation of our measuring devices.
  • #64
phillip1882 said:
If i can add and subtract v and u to get the velocity between v and u in a frame of reference, and time dilation and space dilation doesn't change velocity, why would v see a different velocity with respect to u?
It wouldn't, but there is more to Lorentz covariance than just time dilation and length contration. You're overlooking the relativity of simultaneity, and the physical basis for that.
Remember, speeds have meaning only in terms of a given system of space and time coordinates. To test your ingenuity, see if you can imagine two relatively moving systems of space and time coordinates such that a given pulse of light has the same speed in terms of both of them. Feel free to adjust the scaling AND tilt the space and time axes as necessary to achieve this. (Hint: It's possible.)
  • #65
okay then use this measuring device relative two the two particle a and -a!
don't use light itself.
if i fire two light beams at each other, use this device to determine the speed between the two light beams.
in a vacuum, light has a medium. not matter, background radiation. you can never fully eliminate background radiation because it exists everywhere, and any sort of attempt to block it will generate background radiation itself. show me a way to completely eliminate background radiation, and fire a light beam through it. i would dearly love to know what happens.
  • #66
That gives you the separation velocity in the device's frame, not the velocity of -a in a's frame nor the velocity of a in -a's frame.
This is completely illogical. The background radiation IS light. It is the light given off by a black body at ~3 K, just like the light from a typical lightbulb is given off by a blackbody at ~3000 K. So what you are saying here is that light has a medium and that medium is light.
  • #67
derive the equation for velocity addition (a1 +a2)/(1 +a1*a2/c^2)
with the assumption that two particles can detect motion faster than the speed of light; because apparently its possible.
in a round about sort of way yes. if you can believe the illogical assumption that light is not relative to an observer no matter the speed, than i can believe the illogical assumption that light requires a medium in a vacuum, even if that medium is light itself.
i think if you completely eliminated light from a medium, and then tried to put light through a medium, the light would not just go straight through. it would immediately scatter.
light is made up of particles. but those particles require other nearby particles in order to travel. you can't have motion without a frame of reference, therefore light creates it own frame of reference.
  • #68
As everyone can see, we have closed this thread. The discussion was clearly not going anywhere.
Likes 1 person
  • #69
Sorry Fredrik, I wanted to leave phillip1882 with a response to his last post, in case he checks in. I know it is probably futile, but who knows?
Sure, here is a brief outline of the proof. Assume the following three things:
1) The principle of relativity
2) The invariance of c
3) Superluminal motion can be detected
From 1 and 2 derive the Lorentz transform. From the Lorentz transform derive the velocity composition formula.
If you notice, the third assumption is irrelevant to the proof. There is no need to assume it, but there is no harm in assuming it either. In fact, the third assumption need not be assumed at all, it can be proven as I did in the posts I linked to earlier on the other thread.
The difference is that the first "illogical" really means "unintuitive to me" while the second "illogical" really means "self contradictory". If light needs a medium and the medium for light A is light B then light B still needs a medium, unless light doesn't need a medium, in which case light B is not the medium for light A. Your premise contradicts itself.
Pure speculation with no relationship to mainstream scientific knowledge whatsoever.
I am sorry that you couldn't wrap your head around relativity this time. Hopefully after some time some of this will sink in. Good luck!
Just FYI, the most important thing about relativity is how well it matches experiment. Any other theory is going to have to be equivalent to relativity in all regimes tested to date. So you need to get used to time dilation and velocity addition, they are simply part of how the universe actually works. When reality doesn't fit with your mental picture, then you need to change your mental picture: http://www.edu-observatory.org/physics-faq/Relativity/SR/experiments.html
