IT people -small setup advice
  • Thread starter kmwest
In summary: Read moreIn summary, a small business with roughly 20 employees and limited server needs is looking to update their IT systems. They require a file server, print server, and barebones Sharepoint server, but do not need a webserver or Exchange. The individual worker's folders will have restricted user permissions, while the sister and senior managers will have access to all folders. The recommended solution is to implement Active Directory (AD) for unified authorization and access control. It is also suggested to stick to the default installation configuration of Small Business Server (SBS) for easier management and increased security. The recommended server should meet the sizing requirements for SBS 2011. It is also advised to consider using RAID for data protection.
kmwest
28
My sister owns a small business and I'm helping update their IT. Right now it's virtually nonexistent. Requirements are small:
~20 users, each with own laptop. All on laptops connected via WiFi to the office wireless router. Employees work off-site nearly all day and come back throughout the day for various reasons, so really I'm looking at maybe 10 users actually in the building at any given time.
Very limited server role requirements:
- print server (around 5 printers in the whole building)
- file server - just looking for auto-backups of all client laptops over our wifi network. Just standard MS Office / PDF docs. I will restrict user permissions to to the individual worker's folder. Additionally my sister and her senior managers will have access to all folders.
- barebones Sharepoint server - mainly just want to use it as a filesharing site.
- Quickbooks 2012 server
- personnel management software server
NO Webserver requirement (barebones website, and they are registered with webhosting service)
NO Exchange needed (use webmail as part of the webhosting service)
I'm looking at getting this server:
http://www.newegg.com/Product/Produc...82E16859115004
And then upgrading to SBS 2011 Essentials, then getting SPS Essentials for free once I've registered SBS Essentials.
So I'm thinking of just setting up all the users on a workgroup and not setting up AD, especially since the only real networking requirements are for sharefolders and shared printers. But will I still have to set up AD to set up the SPS? Because I know SPS typically uses AD for user authentication.
Also how much RAM and processor speed would you recommend I have on this thing so it doesn't slow to a crawl? And do you think 500GB will be enough storage space, or will I need more?
I apologize for any stupid questions, even though I'm a military communications officer it's been a while since I've done this. :) Any advice/suggestions will be appreciated.
Ralph
Computer science news on Phys.org
Hi Ralph,
This quote from your original post justifies implementing Active Directory (AD):
AD will help you manage unified authorization and access control lists by providing you with a consolidated user database. Then, you can enable users to login to laptops using cached credentials after they have successfully authenticated to the Domain Controller (which would be the SBS server) and logged into the LAN at least once.
This way your users can authenticate using the same credentials regardless whether they are connected to the network, and you can optionally synchronize folders from their laptops to the server whenever they do connect.
Ultimately, you don't have a choice - Active Directory is an integral part of Small Business Server (SBS), as indicated at the bottom of this link:
http://www.microsoft.com/sbs/en/us/compare-features.aspx"
You are doing the right thing by itemizing your requirements ahead of time. Keep in mind, however: SBS is a turnkey package solution, so it will attempt to install and configure DNS, Active Directory, web, email, and groupware services by default. Even if you do not desire to use these, avoid deviating from the preferred default installation configuration unless you have reviewed the implementation guides and can justify the headaches you will likely encounter. Instead, simply don't use what you don't need, until you need it.
While this flies in the face of generally accepted "best practices" which dictate increasing security by decreasing the complexity of your system implementation, SBS is designed to be rolled out in a standardized configuration (which trades versatility for reduced cost and lower administrative burden). Because it is a combined package, trying to tear things out of it after the fact or bludgeoning it into allowing you to skip various components will reduce your security by causing increased downtime and greater technical support burden down the line.
That link appears to go nowhere from the machine I'm using right now, so I cannot advise on that directly. However, you can evaluate your proposed build by comparing it to the SBS 2011 sizing requirements here: http://www.microsoft.com/sbs/en/us/system-requirements.aspx"
Hope this information was helpful in finding answers to your questions.
Welcome to PhysicsForums, lordaq (and a great first post!)
Perhaps it's just me (as a small home networker), but to the OP, have you considered just a NAS (network attached storage) with some sort of versioning software? That or buying a cheap server case, running some sort of DIY NAS (usually Linux-based), and hooking the printer up to that? Perhaps I'm misreading, but IIRC, the idea for most print servers is to allow multiple computers to access a common printer, and not the other way around.
Whatever you go with, I'd suggest running RAID 0, 0+1, or 5. It won't save your data in the event of a catastrophic failure (e.g. building / computer burns down), but will make it easier to get back up and running if a single hard drive goes kapput. If you absolutely must have that sort of protection, you can look into having another computer / NAS device, situated off-site or across the building that just performs incremental backups on your array (or even just the data you want protected).
Excellent advice! However, be forewarned: of these three common RAID types, RAID 0+1 (striped and mirrored, sometimes called "RAID 10") and RAID 5 (striped with parity) provide fault tolerance against hardware failures, while RAID 0 does not.
Typical suggestion for RAID is:
  • If provided by dedicated hardware, use RAID 5 or 0+1 in order to gain fault tolerance and higher performance -- the dedicated RAID hardware avoids consuming CPU cycles to manage parity calculations or I/O pipelines.
  • If provided by the operating system (aka "software RAID"), stick with RAID 1 to achieve fault tolerance.
RAID 0 simply stripes data across multiple disks in order to achieve a performance benefit. By increasing the number of hardware components, it increases the rate of occurrence for unrecoverable hardware failures. This is sometimes a desirable trade off -- RAID 0 is commonly implemented on disks that require high read/write bandwidth but do not contain mission essential data. Examples of this might be print spools, swap files, application caches, etc.
Meanwhile, RAID with mirroring (redundancy through duplication) or parity (redundancy through calculation) accommodate recovery from failed hardware. Both of these methods are advantageous to performance in some circumstances and detrimental to performance in others, but their primary purpose is to increase available storage space while decreasing risk of a single drive failure causing unrecoverable data loss.
Although "everyone" used to "always" recommend RAID 5 for servers, RAID 0+1 is becoming more popular in small business environments because dedicated hardware RAID controllers and hard drives themselves are so inexpensive. Half the raw storage is consumed by the mirrors of RAID 0+1, but IO operations perform better than on a single drive because the mirrors consist of striped arrays. RAID 5 versus 0+1 can be a slippery slope toward a religious debate, so I'll leave that one alone.
WORD OF WARNING: Whichever RAID implementation is used, buy at least one spare disk of the same make and model as the others when you deploy the server. Failing this is like buying a car with a space for a full-size spare but leaving it empty because you assume you'll easily find a replacement whenever you have a blow-out.
Well, that's a bad typo! Clearly, you should go for RAID 1, 0+1, or 5.
http://en.wikipedia.org/wiki/RAID
EDIT: If you're looking for some form of redundancy, that is.
1. What are the essential components for setting up a small IT network?
The essential components for setting up a small IT network include a router, switches, servers, and computers. A router is necessary for connecting multiple devices to the internet, while switches are used to connect devices within the network. Servers are used for centralizing data and managing user access, and computers are the devices used by individuals to access the network.
2. How many servers do I need for my small IT setup?
The number of servers needed for a small IT setup depends on the specific needs and requirements of the organization. Generally, a small setup can function with one server, but it is recommended to have at least two servers for redundancy and backup purposes.
3. What is the best operating system for a small IT setup?
The best operating system for a small IT setup depends on the specific needs and preferences of the organization. Some popular options include Windows Server, Linux, and macOS. It is important to research and consider the features and compatibility of each operating system before making a decision.
4. How can I ensure the security of my small IT network?
To ensure the security of your small IT network, it is important to have a strong firewall and regularly update and patch all devices and software. It is also recommended to have strict user access controls and implement data encryption for sensitive information. Regular security audits and training for employees can also help maintain the security of the network.
5. How can I troubleshoot common IT issues in a small setup?
To troubleshoot common IT issues in a small setup, it is important to have a basic understanding of the network components and their functions. It is also helpful to have documentation of the network setup and any recent changes. Basic troubleshooting steps include checking network connections, restarting devices, and running diagnostic tools. If the issue persists, it may be necessary to seek assistance from an IT professional.
  • Feedback and Announcements
94K
  • DIY Projects
  • Art, Music, History, and Linguistics
  • General Discussion
