Why ITER is a Useless Investment: The Truth about Tritium and Tokamaks
  • Thread starter Enthalpy
  • Tags
    Iter
In summary, the conversation discusses the cost and usefulness of the tokamak fusion reactor, with the conclusion that it is currently not a practical or feasible solution for providing clean energy. The main point is that the production of tritium, a necessary component for the tokamak, is not readily available and would require large amounts of energy from fission reactors to produce. The conversation also mentions potential safety and environmental concerns with fusion reactors.
  • #36
Astronuc said:
But this is not correct. One neutron causes a fission which produces 200 MeV. The additional neutrons would carry away only 2-4 MeV. They could be absorbed in special assemblies to produce tritium, which is produced in the coolant through the (n, alpha) reaction with Li anyway. There is no 130 MeV being carried away by the extra neutrons from fission.
Astro, I'm not saying (nor was the OP saying) that this energy is carried away by the neutrons, that is not the point.
The point is that you need to liberate 130 MeV in a fission reactor in order for you to have an "absorbable" neutron. This neutron is not carrying this energy, nor is this energy "lost" but is has been irreversibly converted into heat. Heat which can be used to make steam or whatever, to make electricity, to make hydrogen, to desalinate seawater, or to boil eggs, whatever you use a reactor for.
The point is not that there would be a kind of "loss of energy" or that it would require more energy to make the tritium than to use it. No. The point is that 130 MeV of useful fission energy has to be liberated in a fission reactor per available neutron, so (without significant neutron multiplication) per produced tritium atom. If you want to produce 1.5 10^25 neutrons over a year's time to do something with like making tritium, there's no way but to have a fission facility that has liberated a power of about 100 MW. That 100 MW thermal can be used to make electricity or boil eggs or whatever, so it can be put to good usage, but it is power produced by a fission facility. If we take those 1.5 10^25 neutrons and we let them turn Li-6 into tritium, then we have made 1.5 10^25 tritium atoms.
So consider that making 1.5 10^25 tritium atoms required you to run a nuclear facility that liberated useful power of 100 MW.
Now, with this tritium fuel, if you go to a fusion facility running D + T, you can provide for 15 MW (if it doesn't have a blanket).
So the ridiculous part in this case is that you need to run a 100 MW reactor (producing, say, 35 MW of electricity), to fuel a fusion reactor of 15 MW, producing 5 MW of electricity.
So if you were planning to need 40 MW of electricity, you would have to build a fission reactor providing you with 35 MW of electricity and tritium fuel, and a fusion reactor of 5 MW. This is not a problem, but it is ridiculous to spend 100 years of research to achieve THAT.
Now, even with an 80% efficient blanket, you would still need to have a nuclear facility providing for 7 MW of electrical power to have a fusion reactor making 5 MW of electrical power. That too, is ridiculous as an achievement.
Anyway, a substantial fraction of the extra neutrons are absorbed the fuel (U-238) which is converted eventually to fissile Pu239 and (Pu-240, Pu-241), Am241, Cm244, and other TRUs.
Indeed, which makes it WORSE, because, for the same amount of available neutrons to make tritium you need even to liberate MORE fission power, and you make more fission fuel... so your balance tips even more over to the fission power side...
BTW - thorium (Th-232) with U-233 is the basis of a thermal breeder reactor.
I know, I should have said U-235.
  • #37
Again I have to object to this statement. It is the fission process - primarily the kinetic energy of the fission products - that is responsible for the energy. The number of neutrons released is irrelevant - except that having an excess of neutrons allows a sustainable fission process. As long as one neutron is released in the fission process and is subsequently absorbed to cause another fission, the process is sustainable without adding some other type of neutron source.
Now the lesser the number of neutrons released in fission, the more difficult it becomes to design an economic and feasible system to produce energy.
In an LWR, there is an excess of neutrons and many are either absorbed by boric acid in the PWR coolant or in B-10 or Hf in control blades in a BWR. A by-product of n-absorption in boron is Li which undergoes an n-alpha reaction and produces tritium. Tritium is produced in normal operation whether it is subsequently used in fusion or not. However, I don't believe that T is produced in huge quantities.
In fusion, the goal is to use d+d, and if that is successful, then tritium is not necessary.
  • #38
Astro, we are talking completely next to each other, I don't see why, honestly.
I see completely your point, but it is NOT what I am talking about. I'm also not "attacking" fusion. I'm saying that it is absolutely necessary for D+T fusion to have a self-sufficient blanket, or this form of energy promised is totally ridiculous, which is what I understood from the OP, EXCEPT that the OP also had some doubts about the realistic feasibility about making a genuine self-sufficient blanket in a genuine power plant. And yes, in a much more remote future, we might consider D+D fusion, or even H+H fusion, but nobody is talking NOW in achieving technical break-even in D+D.
So this IS an important issue.
But let us come to our point of apparent disagreement: the fact that a fission plant needs to release about 130 MeV of fission energy per produced neutron that is "available" - under the hypothesis of no significant neutron multiplication outside of the fission process itself.
As I don't seem to be able to make you see the point I'm making, I will try to make YOU make the point. I'm certainly not trying to be condescending, I will just try to ask you some questions in order for you to see where I'm coming from, ok ?
Yes, but you cannot AVOID having fission products when you want to have fission, do you ? You cannot AVOID a fission reaction to liberate about 200 MeV and to heat its environment by said amount of energy, right ?
Now, as THE ONLY SOURCE of neutrons is fissions (you agree with that, up to the small fraction of retarded neutrons ?) and on average a fission will liberate about 2.5 neutrons and you will need 1 of those to sustain the chain reaction, HOW MUCH ENERGY do you think you will need to release in a fission plant to liberate 1.5 10^25 neutrons which you want to absorb in Li-6 ?
How much fissions are going to be necessary to liberate 1.5 10^25 neutrons and sustain a chain reaction ?
Do you think this will be much less than 10^25 fission reactions ? I don't see how you could POSSIBLY extract 1.5 10^25 neutrons out of a fission system without having AT LEAST 10^25 fission reactions happening, simply because each fission an sich has liberated 2.5 neutrons, 10^25 fissions have hence liberated 2.5 10^25 neutrons, but in order to cause those 10^25 fissions, I have "eaten" 10^25 neutrons which are hence not available for any other thing, so my neutron balance of potentially "free" neutrons with 10^25 fissions is just 1.5 10^25 neutrons and no more. Do you disagree that you need at least 10^25 fission reactions in order to be able to provide for 1.5 10^25 neutrons to special-purpose absorption reactions ?
If yes, I would like to be enlightened about the detailed neutron balance.
Now, if we need to have 10^25 fission reactions, I do not see how we can avoid liberating 200 MeV x 10^25 in total fission energy. This is the heat that will be released in the process if we have 10^25 fissions. Do you think otherwise ? Do you think you can have 10^25 fission reactions, and yet not liberate 200 MeV x 10^25 as thermal energy in the reactor ?
If this energy is released during one year of operation, do you agree we come close to 100 MW (thermal) ?
Now, with 1.5 10^25 neutrons available for the Li-6 + n -> T + alpha reaction, do you agree that we can produce at most 1.5 10^25 tritium atoms ?
Now, with 1.5 10^25 tritium atoms, how many fusion reactions can we do in a D + T fusion reactor ?
Given that each D + T reaction liberates about 17 MeV, how much energy is this in total ? And if you release this over one year (the time the other reactor needed to "fill up the stock" of tritium), do you agree that the power will be around something like 15 MW (namely 17 MeV x 1.5 10^25 / the number of seconds in a year) ?
Or not ?
So what is wrong with me saying that:
1) to have 1 neutron "free to be absorbed" from a reactor, you need to dissipate 130 MeV of fission energy, or more, in the reactor ?
2) the fusion power plant (without blanket) will produce way less power burning the produced tritium, than the reactor that produced the tritium in the first place, will have produced ?
Yes, I'm not saying that. I'm saying that of the 2.5 neutrons produced in the fission process, you will use 1 (one) in the chain reaction which is hence not available for something else, such as a neutron beam, or
I agree with all that, but we were talking about how much NUCLEAR FISSION POWER we need to liberate in order to fuel a D + T fusion reactor that will itself consume a certain amount of tritium if there is no blanket, or if there is a lossy blanket.
Of course. The other possibility is to have a fully self-sustained blanket in a D+T reactor. This will need neutron-multiplication to cover for losses of all kinds. Both are serious challenges.
  • #39
vanesch said:
Well, there as of now already another serious problem that indicates this tritium difficulty: there is now a world-wide scarcity of He-3. He-3 is used in cryogenics, but also in neutron detection, and there's a world-wide problem with it.
Well, He-3 is the decay product of tritium. If you have enough tritium, there isn't any He-3 supply problem. So the fact that there is now such a He-3 problem indicates that tritium is a very scarce resource.
The cost of manufacturing tritium is on the order of $100,000 per gram. Despite the shortage, commercial He-3 still costs $15,000 per gram. In essence, tritium alone costs much more than the electric energy that we could extract from it via d-t process if we had a working fusion reactor.
  • #40
I understand vanesch's point now. Basically, he is saying that for whatever neutron flux you are using to produce tritium in a fission reactor, that neutron flux would be producing on the order of 10 times as much power from fissions compared to what you would eventually get fusing the tritium, due to the fact that one neutron releases 200 MeV from fission but only ~20 MeV from fusion.
However the reason why this is inaccurate is because when Li-7 is used to breed tritium, it produces a neutron of lower energy. So one fission neutron could end up producing multiple tritium atoms (the number of which I am not sure of, I'd have to model it and see).
  • #41
The reason why the cost is so high is because the production is very low. The production is low because the is only limited and specialized demand. The price would go way down if it was mass-produced for commercial purposes.
  • #42
So if Tritium is currently in short supply, what would a viable alternative be for a fusion fuel?
I think one advantage of D-T mixture is the energy gain and activation energy compared to something like a D-D reaction. For a D-D reaction, when efficiencies of a power generation cycle are taken into account total energy gain nears break even and couldn't be as useful from a large energy production standpoint.
  • #43
I think Eric Drexler summed up the issue in his blog post.
Why fusion won’t provide power (at a reasonable cost)
http://metamodern.com/2010/01/20/why-fusion-won%E2%80%99t-provide-power/"
  • #44
Complaining about the capital costs for commercial fusion power plants is a bit premature at this point, don't you think?
Try reading the report he cites. I couldn't find any hard numbers, just a bunch of vague fluff about technology readiness levels. Then again I couldn't manage to get more than a few pages into it, I'm not good at reading political-speak mumbo jumbo.
  • #45
The relevant cost of T would be after Beryllium blanketed fusion reactors exist, not before.
Ok, but there's no viable He-3 fusion reactor on the table, even if you had it. He-3 He-3 cross section is, what, ~50X smaller than D-T, requires an impossibly hotter temperature (in a thermalized containment reactor) and produces 1/3 less energy per go.
Let's see. A gram of T undergoing 100% fusion w/ D, at 17 MeV per fusion would release ~34x10^23MeV, or 544 gigajoules, of which a ~third could be converted to electricity, resulting in ~50 MW-hrs. At the current retail price of $100/MW-hr that's about $5000 of sellable energy. So indeed, if D-T fusion is to work commercially, I suppose the cost of T is coming down. :wink:
  • #46
...jumping in: No, it's not premature. Otherwise we could have a go at building spacecraft powered by anti-matter, which is produced all the time in accelerators but not (nearly) for a reasonable capital cost. ITER is not purely a research facility. In addition to research, it's there to prove the concepts required for commercial fusion power.
  • #47
Yes, this is what I also understood from the OP.
I'm no expert, but it is going to be tricky. People use Be and Pb as "neutron multipliers", and I myself gave also the example of Li-7. But it is tricky, and all structural material will make you loose some neutrons, non-full angular coverage too. And this is what I realized (I didn't think of this before reading the OP): it is ABSOLUTELY ESSENTIAL to show that this problem can be solved or (DT) fusion is ridiculous, as it stands.
Everybody is concentrating on the Q factor and so on, and how much Q should be in order for a commercial plant to be viable, but the blanket is just as important. Without a self-sufficient blanket, it is a no-go.
  • #48
If we could buy He-3 for that price, we would be happy ! We got quotes of more than 2000 Euro for one litre (1 atmosphere).
EDIT: silly me, that's comparable :redface:
  • #49
Sufficient T generation is only one of the absolutely critical problems that need to be solved for successful commercial fusion. DT fusion also requires a first wall that can withstand the fast neutron flux (every single atom in the first wall will be displaced 30 times per year [1]) for sufficient time as is required of an economic reactor. The design of a fission reactor can play games with fuel rod count and diameter to manage heat flux. No such design fix is possible with the first wall of a Tokamak.
[1] http://www.askmar.com/Robert%20Bussard/The%20Trouble%20With%20Fusion.pdf"
  • #50
vanesch said:
...natural abundance of tritium... is of the order of 10-17..., inexploitable for commercial energy production.
As I understand the OP, his point is the following: given that tritium has to come from an artificial source, usually neutron bombardment of Lithium, there is a bookkeeping problem:
a) one fusion reaction consumes one tritium nucleus, and produces one neutron.
b) if we have only a tritium production of one tritium atom per neutron, this is never going to achieve auto-refueling.
c) if a serious fraction of the to be burned tritium has to come from another source, nuclear fission, then we have the following problem:
c1) [Fusion produces less electricity than the fission reactors that supply tritium to it, hence not interesting]
[Please refer to the post by Vanesh, I shorten it in the present quote]
...the blanket needs to achieve self-sufficiency if this power source doesn't want to be ridiculous, because needing a bigger fission power station next to it than it can deliver itself.
Yes, this is what I tried to explain. Many thanks to Vanesh to have made it clearer than I did.
It means that, to substantially replace fission, fusion has to regenerate tritium by itself. This is, to my eyes, a harder constraint than technology issues (which receive solutions despite they first look like impossibilities): it is an issue detectable in neutron bookkeeping - the kind of things that shall work with big margin before you include technology meanness, but here the margin is negative.
Other reactions than D-T would solve that but are out of reach by tokamaks, even on the timescale of fusion research.
Though this issue of tritium regeneration hasn't been widely publicized (...sorry folks...) it is known by tokamak researchers. I had raised this objection, as did specialists with more knowledge and influence. This is why ITER now includes a programme to develop and test blankets with neutron multipliers, the only way to regenerate tritium.
Many papers deal with this presently; unless I missed something,
- Beryllium is abandoned as it couldn't achieve regeneration in simulations;
- Lithium-7 is abandoned, blankets would even be enriched in Lithium-6;
- Lead seems to be the only hopeful multiplier through (n, 2n) reactions exploiting the 14MeV neutron from D-T fusion.
Nearly all papers consider a lead-lithium eutectic for tritium regeneration. This eutectic would serve as heat removal fluid as well, because both need to cover the chamber completely.
A simple description of the experimental blankets for ITER:
http://www.nuklearforum.ch/_upl/files/Pr__sentation_Poitevin.pdf
Under simulation conditions, the regeneration factor could reach up to 1.15 - the kind of figure I hate to see when I must guarantee >1 but other design constraints haven't been included yet... And a tokamak brings some additional design constraints, doesn't it?
  • #51
The NIF LIFE concept proposes to create it's own Tritium using a Lithium-enriched liquid salt blanket:
LLNL.gov said:
Q: Tritium is rare and very expensive to produce. How would a fusion power plant get the tritium it needs to sustain continuous fusion reactions?
A: It's true that tritium exists only in small quantities in nature, so a fusion energy power plant would need to create its own tritium fuel. The neutrons generated in the fusion reaction will be absorbed within a liquid salt blanket surrounding the fusion chamber to create a hot fluid that will turn a turbine to generate electricity. The salt will contain lithium, which will react with the fusion neutrons to produce helium and tritium. Due to neutron multiplication reactions, it is possible to make more than one triton (tritium nucleus) for each one consumed in fusion reactions, creating a net positive generation of tritium. This tritium is then sent to the target factory to be used to produce new targets.
https://lasers.llnl.gov/education/faqs.php#tritium
  • #52
So Enthalpy, you don't agree that funding the ITER, which could possibly lead to fusion using not only D-T, but also D-D or other fuels, is a worth it?
  • #53
He is right saying:
  • #54
vanesch said:
Yes, that's the point. Actually, until I read the OP's post, I never realized how critical this blanket was. It will be quite difficult to achieve self-sufficiency, because of course you cannot capture the neutrons in 4 pi without any structural capture and loss. So you need a neutron multiplier.
D-T reaction needs neutron multiplying coefficient 1.15-1.25 or to produce Tritium in existing fission reactors. And no any other way.
vanesch said:
Non-fission neutron multiplication isn't easy (apart from spallation). If it were, people would use it to make thermal breeders with uranium
That’s not so. If considering that realization of fusion means less danger wastes.
vanesch said:
Yes, of course, but when you look at the difficulties people have to realize self-sustained, energetically useful let alone commercially competitive energy from D + T (that's the hope in the second half of this century) even granted tritium provision, D + D is for the 22nd century at best.
I doubt in commercial feasibility of D-D reaction. More interesting is to build D-T reactors with bigger than 1.15-1.25 Tritium breeding coefficient, then to wait till some tritium will decay to He3 and then to build aneutronic D-He3 reactors.
vanesch said:
I'm not saying ITER is useless, but the tritium bottleneck is yet another difficulty as compared to the rosey pictures of "soon, clean energy here", no ?
ITER useful for accumulation of technology know how – magnets, vacuum, blanket, first wall, neutral injection, etc. Someone should do these jobs.
But I doubt that TOKAMAK as such ever will be able to generate net power. As if you see this link: http://iter.rma.ac.be/Stufftodownload/Texts/BurnCriteria.pdf where is taken into account real energy conversion cycles’ efficiency is calculated that required confinement time should have an order of 560 s. (page 8 after formula (57) ).
But there is not any bottleneck with Tritium. And I am disagreeing with statement mentioned here as Lithium is a rare element.
  • #55
While Lithium is certainly abundant enough, reaching the mandatory Tritium breeding coefficient looks impossible, given that present computations don't integrate many difficult constraints.
Any designer likes to start with a margin of 10 at scratch, if he's to keep >1 as his design advances. For uranium chain reaction, they had 2.4 neutrons to keep 1 and this needed a big effort to develop materials, forms... Starting from 1.15 is disheartening - to my eyes it's impossible.
3He-D is even more difficult than D-D because of the third repelling proton.
Then, you have the radioactive pollution by the regeneration blankets, which promises to be as bad as uranium fission.
Developing Tokamaks for the sake of pure science may be fun, but not if we need energy right now, not if we see a probable impossibility, not if it takes for decades thousands of brilliant people who could solve instead more productive challenges, like electricity storage.
  • #56
To my eyes it's impossible to produce net power using TOKAMAKs and D-T reaction.
But I am talking not about the viability of certain fusion Method. But here I am only talk about fuel cycles. And tritium breeding with any needed breeding coefficient is less complicated challenge than the breakeven achievement.
I never heard about blankets in which a few years loading of breading materials (Li6+neutrons multiplier) should be placed. But only current quantities. So, that will not be as dangerous as fission in case of accident.
You are wrong. Demand on electricity growths. And only growth of generation would solve a problem. Or we would not need any electricity storage.
  • #57
Joseph Chikva said:
You are wrong. Demand on electricity growths. ...
Not lately in the US:
http://www.eia.gov/totalenergy/data/annual/txt/ptb0802a.html"
2005 4,055
2006 4,064
2007 4,156
2008 4,119
2009 3,953
2010 4,120
Similarly US energy intensity, that is energy per $ of economic production has been and continues to decline.
http://www.eia.gov/emeu/25opec/sld022.htm
  • #58
2005 4,055
2006 4,064
2007 4,156
2008 4,119
2009 3,953
2010 4,120
World production? China, India, Brazil, some developing countries? Total energy generation?
That is not engineering but more an economical and political issue.
If cheap electricity in US would increase the competitivnes of US economics and generation demand will growth as well. Certainly if USA is not going to concede its economical leadership. The gap between China and USA is smaller and smaller.
And renewables are not cheap.
  • #59
Umm, I don't think that looking 5 years in the past is sufficient to say that future energy demand won't/isn't increasing. A quick look on that table shows that up until 2008 there was a continual increase. And if your view of "lately" is only 3 years ago, then I think you should expand your view on the situation.
  • #60
Any chance you can confine the fusion bashing to ONE thread encephalaphy?
  • #61
"Won't" and "Isn't" are to very different things. I did not say "Won't". The data says, not me, that for the last 5 years US electric demand "Isn't" increasing (linear fit).
A quick look on that table shows that up until 2008 there was a continual increase. ...
The 5 year window is sufficient to say this: the 5 year trend (ie lately) is flat or down with a linear fit to those numbers, no more no less.
US billion kwh vs year:
  • #62
• Till 2008 increasing.
• After August 2008 (crisis beginning) some fall which if we call as” trend" - very short term
• After the end of crisis - do not know but think that growth again
  • #63
Let me put it this way mheslep. Your post was pointless and serves no purpose in regards to this thread. Not only did it not refute what you quoted, it ignores all long term trends, other variables, and only takes one single country into account. So what if the US energy usage has flattened out in the last few years? That has no bearing on this discussion.
  • #64
Ah, good, then the US can drop all support for ITER.
  • #65
Poitevin's description of tritium-breeding blankets has moved, available here:
http://www.iter-industry.ch/wp-content/uploads/2010/01/Pr__sentation_Poitevin.pdf
  • #66
Poitevin's Pdf tells that beryllium could be an other neutron multiplier, as an alternative to lead, but beryllium is scarce.
Believing the miners at USGS rather than the chemist cited by Wiki, we have 80,000 t of beryllium ressources - exploitable ore, not reserves which limit to present economic conditions.
http://minerals.usgs.gov/minerals/pubs/commodity/beryllium/mcs-2012-beryl.pdf page 29
According to the IEA, the worldwide energy consumption was in 2008:
http://www.iea.org/textbase/nppdf/free/2011/key_world_energy_stats.pdf (pages 24 and 6)
- 15 PWh = 54 EJ as electricity made from hydrocarbons (including coal) or from uranium;
- 10 Gtep as hydrocarbons (including coal) or uranium, or 440 EJ replaceable by 300 EJe of electricity.
1 mole or 9g of beryllium produces about 1,4 mole of tritium of which each atom produces 25MeV heat converted to 35% in electricity, or 130 TJe/kg of Be.
If other uses continue to need 270 t/year of beryllium, ressources cover :
- 120 years of electricity, needing 270 + 410 t/year. That's less than coal;
- 31 years of hydrocarbon replacement, needing 270 + 2300 t/year - and we want to replace hydrocarbons.
With beryllium as a neutron multiplier, ITER wouldn't hold it promises. Even if it only produced the electricity presently consumed, its R&D would have been longer than its operational life.
Except if someone sees a better neutron multiplier (no Th nor U nor Pu, thanks), we have only Pb and its radioactive waste.
Marc Schaefer, aka Enthalpy
  • Nuclear Engineering
12K
