Iterating through an array
  • Thread starter magnifik
I'm trying to understand a sorting algorithm (selection sort, to be exact). I started out with this:
public static void selectionSort1(int[] x) {
for (int i=0; i<x.length-1; i++) {
for (int j=1; j<x.length; j++) {
if (x > x[j]) {
//... Exchange elements
int temp = x;
x = x[j];
x[j] = temp;
but that didn't work so i made one slight modification by changing j to i + 1
for (int j=i+1; j<x.length; j++) {
if (x > x[j]) {
int temp = x;
x = x[j];
x[j] = temp;
i'm having trouble figuring out what's the difference between the codes?
Answers and Replies
The first one will not work because you check:
first iteration:
x[0] > x[1]
x[0] > x[2]
x[0] > x[3]
and so on. This will work for first iteration.
some iterations later:
x[3] > x[1]
x[3] > x[2]
x[3] > x[3]
and so on. This will not work because now you will switch places with numbers already sorted.
For example x[3] will for sure be larger than x[1] because x[1] is sorted to be the second smallest number. And when they switch a larger number is placed in x[1].
Second code works because
first iteration:
x[0] > x[1]
x[0] > x[2]
x[0] > x[3]
and so on
x[3] > x[4]
x[3] > x[5]
x[3] > x[6]
this will work because you discard the already checked values which is not the case in the first code
7,140
When you include code in your post, please put (code) and (/code) tags around it (with the tags in brackets [] though). Doing this preserves your formatting and makes your code easier to read.
I have edited your post to do this.
Code:
            if (x[i] > x[j]) {
                int temp = x[i];
                x[i] = x[j];
                x[j] = temp;
Code:
            if (x[i] > x[j]) {
                int temp = x[i];
                x[i] = x[j];
                x[j] = temp;
Related Threads on Iterating through an array
  • Last Post
  • Last Post
  • Last Post
15K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
