Quantum_Grid
- 63
Man, its the middle of january, and I STILL can't turn my A/C off! It's so hot and muggy, I almost miss the cold. I guess that's New Orleans fer ya'
Anyone else from the big easy?
The Earth's atmosphere naturally traps in heat from the sun, creating an environment with a range of temperatures. When the Earth's surface absorbs sunlight, it heats up and releases this heat back into the atmosphere. This is known as the greenhouse effect and is what makes it feel hot outside.
Scientists use a device called a thermometer to measure temperature. A thermometer typically contains a liquid, such as mercury, that expands or contracts based on the temperature. The expansion or contraction is then measured and converted into a temperature reading.
Some areas may be hotter than others due to a variety of factors, including differences in latitude, altitude, and proximity to large bodies of water. Additionally, urban areas tend to be hotter than rural areas due to the heat-absorbing properties of pavement and buildings.
Humidity is the amount of water vapor in the air. When humidity is high, it can make the air feel warmer because our bodies have a harder time cooling down through sweat evaporation. This is why high humidity days often feel more uncomfortable than low humidity days with the same temperature.
Extreme heat can have serious consequences on both human health and the environment. It can lead to heat stroke, dehydration, and other heat-related illnesses. It can also cause droughts, wildfires, and harm to crops and other plants. As the Earth's temperature continues to rise, extreme heat events are becoming more frequent and severe.
