- #1,646
nikkkom
- 2,075
- 399
Charles Smalls said:I think when you design and sell a plant based on the notion that it is too safe to fail, you can’t really then go on to clearly and explicitly plan for an event in which then does.
This might have been the reason before Fukushima.
But what are the reasons why filtered vents are not mandated in US even _after_ Fukushima experimentally demonstrated that meltdowns are a realistic possibility?
As for on the Daiichi itself, I think even with manuals, I don’t know if the outcome would have been any different. Handbooks are only as good as the data you have to put into them.
Well, they definitely could have properly engaged IC on Unit 1, if accident manuals has clear directives to do so in station blackout. Thus, Unit 1 could have been saved.
And if manuals would have sections directing them to do so, they could have vented RPVs of Units 2 and 3 down to atmospheric pressure _before_ fuel started to melt. This would have released small amounts of radioactivity, yes, but then they could start injecting water with much less powerful pumps, since there would be no pressure difference to fight against. Units 2 and 3 could have been saved, too.
In reality, and as the video above clearly explains, with no manuals, they tried to reach two opposing goals at once: keep RPVs pressurized, and pump water into them. It was not possible to achieve both at once.
