Japan Earthquake: nuclear plants
  • Thread starter gmax137
  • #7,601
279
Hey Madder, the chances of a ballistic object landing in that configuration, parallel with anything and just a foot away from a wall,... and not deforming it's shape are quite frankly near zero.
If the object fell in that part of the roof, it probably rolled about until it hit the wall. That would account for its position.
As for deformation, it depends on where it came from and how sturdy it is. For example, in the Air Photo Service pics one can see a large dark gray metal box that was ejected from Unit #3 and was lying on the ground, some 30 meters southwest of the building --- apparently intact.
  • #7,602
2,119
1,461
This link shows a basic layout of the level circuit. 2 taps into the vessel connected to a differential pressure (DP) cell and transmitter. http://www.pbnc2010.org.mx/pdfs/technical/tuesday/14.00_ModelingLevelInstrumentation.pdf [Broken]
The released TEPCO photo shows the techs at a whole panel of DP cells.
I dont think anyone knows for sure where these taps actually sense level in the RPV. Is the bottom tap in the shroud region or acually in the vessel itself (ie below the downcomer)??
It is also not clear if they blew back the sensing lines to make sure they were clear of any obstruction. They also should have pumped water back up to the upper condensate pot to ensure the reference leg was full. Without doing these 2 steps - the readings may still be wrong!!
Well, a theoretical question. If it's not possible to trust those DP cells as water level indicators can they be turned to pressure meters of the RPV relative to the atmospheric pressure?
  • #7,603
Borek
Mentor
28,879
3,428
big stiff box that 'floats' on the soil/rock below. That way, if the ground cracks, deforms, liquefies, or shakes too much, the building may move or sink a bit but is less likely to crack or collapse.
In particular, I do not see any possibility of their lower levels sinking, tilting or collapsing to any significant extent, even if they were resting on top of soil rather than rock. Thus the tilting of #4 that is supposedly visible in the webcam --- and only there --- can only be an optical illusion or artifact.
The way I see it - if they float as rigid boxes, it is quite possible they can tilt without damage.
  • #7,605
279
The chunk has a very different appearence than on the other pictures I posted, where it looks clearly to be concrete, on this one it's not so clear but the rendering of the picture is bizarre. What is really surprising is the small amount of damages around or under it, like if it was delicately put there!
If it is the chunk I am thinking, then it is clearly one of the service floor wall panels --- some 5-7 meters across but perhaps only 30-40 cm thick. The following picture shows it clearly, and shows that it did bend the metal railings above the pipes. If it came from #4, its position and the lack of damage to the pipes are easy to explain. If it came from #3, it may have hit something else (such as the wall of #4 or of its turbine building) before landing there.
http://www.ic.unicamp.br/~stolfi/EX...isc4/drone/hires/aerial-2011-3-30-1-11-12.jpg
http://www.ic.unicamp.br/~stolfi/EX...isc4/drone/hires/aerial-2011-3-30-0-20-11.jpg
  • #7,607
I am following this thread now for a long time and I have to thank you all for the fantastic work done. I learned a lot about reactors and the thinks happening in Fukushima.
During the last days the situation has changed. Many expected this before, but now it is official: R1 and probably also R2 and R3 had full meltdowns with at least the core of R1 burning holes in and/or leaving the RPV (I guess the same must have happened to R2 and R3 too).
http://www.bbc.co.uk/news/world-asia-pacific-13423230" [Broken]
Based on these news (to TEPCO this must be very old news) I would like to know what you think may happen now. Some things I read today in the net:
  1. We may experience a China Syndrone as written by Time.com. Core will explode when hitting ground water soon. Or burns deep into earth's crust triggering a volcano (wtf! I cannot believe this could happen).
  2. The core drops at some day into the 3000t of water in the basement causing an explosion of several megatons distributing the core in a wide area. Maybe Japan (or more) will be inhabitable afterwards.
  3. The core will stay in the basement and slowly cool down. H2 explosions are the only threat.
  4. What else? What do you think will happen now?
From my understanding of the building design, the "lost" water is not directly located under the RPV and there is a concrete wall which may stop the corium from dropping into the basement. What do you think?
I know this is pure speculation, so please excuse me if this is the wrong place to ask. But finally we got some information we can use to extrapolate potential future scenarios.
  • #7,608
gmax137
1,482
Siting plants at higher levels would not help for that aspect of a tsunami. Are power plants designed to handle the lows?
The cooling inlets may fall dry for 15 minutes, due to distant earthquakes that would not scram the reactor. Can a reactor at full power survive that?
Very interesting question.
The heat of vaporization is about 2000 joules/gram. So a 1 gigawatt plant at full cry would need to vaporize 3 gigajoules worth of water every second, or about 1.5 million grams of water, about 1.5 tons worth. The 15 minute dry spell would vaporize 1350 tons of water. That seems a manageable amount, about equal to the water quantity in SFP 4. No idea if the reactors are designed to have that much reserve capacity though.
Yes. Assuming loss of offsite power. Diesels will be tripped if they try to satrt without cooling water which will protect them during the drawdown period. The high pressure DC systems can inject cooling water for long enough for the drawdown period. At Fukushima that is the isolation condenser at unit 1 and the RCIC and HPCI systems at the other plants. If the water returns and the diesels are undamaged from the tsunami they can be started and then the low pressure AC systems will also be available. The Fukushima event made this scenario impossible due to failure to protect safety systems from the tsunami or from flooding.
An important thing to recognize is that the reactor would trip regardless of the distance to the earthquake - if the sea recedes from the intake area, then the large circulating water pumps that push the normal cooling water through the condenser would run dry, the condenser pressure would increase, and the turbine would trip. This loss of load would lead to a direct reactor trip, or if that failed to occur, then an indirect trip on high pressure in the reactor (among others). So, there is no need to boil off the full reactor power for more than a few seconds.
  • #7,609
634
Are you talking about the graph page 41/66 of http://www.tepco.co.jp/nu/fukushima-np/plant-data/f1_8_Parameter_graph.pdf ?
3 data are between 8 and 12 MPa, but it is difficult for me to read the date more precisely than sometime between March 18th and March 23rd.
I am interested in any interpretation of what happened at any unit late on March 20th or early in the morning on March 21st, because I am curious about the radioactivity peak recorded in Mito at 6 AM on the morning of March 21st, as in most cities in Eastern Japan on that date, which I believe is also connected to the "don't give tap water to babies" crisis in Tokyo during the following days (http://www.guardian.co.uk/world/2011/mar/23/tokyo-water-unsafe-infants ).
My previous posts on that topic :
https://www.physicsforums.com/showthread.php?p=3258585#post3258585 (with Mito 6 AM March 21st peak attachment)
https://www.physicsforums.com/showthread.php?p=3258806#post3258806 (about the gap in Tepco data)
For what it's worth, I posted about Kenichi Ohmae's somewhat isolated view of black smoke being something serious at https://www.physicsforums.com/showthread.php?p=3229089&highlight=Ohmae#post3229089
You can see the data in table form, where it is easy to read the exact values around March 21st.
However there is a problem. Yesterday Tepcos links to modern graphs, tables of data, and csv files did not just contain very recent data like they normally do, they were much larger and contained data going all the way back to before the 20th march. But today the same links have returned to their normal state, just showing data from recent days in may. So I cannot give you links to this information, maybe someone can reupload the data or find different urls?
Here is my post where I talked to someone about this new data yesterday, but as I said the links in it dont give the info I was talking about anymore :(
https://www.physicsforums.com/showpost.php?p=3305309&postcount=7502
In recent messages here I have been disagreeing with someone else about whether the smoke events of 21st march may be responsible for the increased radiation detected far away just a few hours later. I was blaming the weather. Well, I do not mean to sound so certain about this at all. Its only that I do not want to rule the weather out completely, because I checked messages I posted at a different forum around 19th-20th march to remind myself what was being said then. Stories were already appearing in the press about food and water contamination by the 19th march. And I posted messages with concern about the weather that was coming.
For example on March 19th at 21:53 JST I said on another forum:
I dont like the weather forecast and plume prediction models for the days ahead. It looks like wind is likely to be taking stuff inland and there is also rain for many places, especially on Monday. Will have to wait for newer readings from further afield to see if this shows up, certainly expect it to if any significant quantity of stuff is still escaping into the sky, which seems kinda likely.
Also, when I look at radiation data from the Fukushima plant itself, there had been spikes on dates such as 18th, so we should probably not be looking at the march 21st events in isolation. Its been a while since I looked at the radiation data from this time though, so I will look again soon to see if I have forgotten something.
  • #7,610
634
If you follow thread for a long time then I am a bit surprised you have not read plenty here about China syndrome and some of the other doomsday core scenarios. The very silly China syndrome is almost universally laughed at, but other things like criticality, and how far the core may already have fallen are still open to debate.
Should also note that meltdown is not a precise technical term, so means different things to different people. Official story is still only at the stage where the fuel has all melted, but still remains in the reactor pressure vessel (even though it has made some holes in it). You are missing the next stage from your list, the core next has to fall into the containment vessel, and then melt through the containment vessel, before it gets to the concrete that you speak of. Until we learn more about how much of the core may have left the reactor pressure vessel, we should not skip ahead to thinking of it being in the basement.
Be especially careful with term 'full meltdown' because to some people full just means all fuel melted, but to others it may imply full meltdown through bottom of reactor vessel & then through drywell containment.
  • #7,611
486
Have the recent large volume of new data released by TEPCO shed any further light on the questions of:
1) the possible origin of the explosion of Bldg 3 (ie, origin from the primary containment?), or
2) the nature of the radiation spike resulting from the explosion of Bldg 3 (ie, sudden criticality vs. some other mechanism of apparent littoral explosion in SFP3 with gamma shine)?
Apologies in advance for a busy schedule and relative lack of mental acuity for meaningful interpretation of the large volume of technical data on the reactors that was released. Thanks.
  • #7,612
634
What do people think of Tepcos roadmap update then? Several english documents available here:
http://www.tepco.co.jp/en/press/corp-com/release/11051703-e.html
TEPCO have made it sound like progress is going quite well. Spin aside, and to be fair, the documents remind us that there has actually been some real progress in certain areas. I was quite surprised to see that if I have read the document properly, fuel pool 3 has water injected through normal cooling system, for example.
Aside from that the main change is what we expected, reactor 1 plan to fill containment with water not yet completely erased from the roadmap, but the recirculation of water plan now takes priority at that reactor.
  • #7,613
I know that the China Syndrome in its basic idea is nonsense, but a core melting through the basement into some meters of earth can not be ruled out, was my understanding so far.
But: How can the core melt holes into the RPV without falling out afterwards at least partially?
  • #7,614
103
Spiffing .AOK Just as expected:rofl:
  • #7,615
HEllo, Yes, the Russians learned a lot and should have been consulted earlier,... though as I understand it the mechanisms and type of cleanup needed are very different. There's a good vid on YT that says they eventually pumped Liq. N2 into the ground under the reactor,... and the evaporating N2 gas "put the fire out"
The corium there seems to have melted the sand they poured on and it cooled and solidified before reaching water table.....
However the Russians had an open reactor, on which to dump sand.
I think not knowing the state of the three CORES here is the main problem..... How can you know what to do..... I hope modern reactors have a radiation proof camera looking at the state of the core incase this happens again.
Exactly and btw thanks for your reply.
I'm not a nuclear engineer, but read a lot about Chernobyl, after the fukishima accident and how close they/we were (Chernobyl) to an even bigger incident, that eventually transpired.
The whole of northern Europe uninhabitable type of incident. IF the corium core had hit the water table.
They took drastic measures to ensure this didn't happen and were succesful.
Is this type of incident a possible scenario in this case or is there not enough information to conclude.
Thanks
  • #7,616
Forgive me I should read the latest posts before posting as my questions have already been asked and somewhat answered
Thanks for all the info here and take care all
  • #7,617
798
30
We had reasons to believe that the primary containment was, or got, involved also before we had these additional data, With the extra data we have just more reason to believe so. I do not think data can point to the origin of the explosive event. It remains a possibility that the origin could have been somewhere else, and the excursion from the primary containment was a secondary effect.
or
CAMS readings are absent in the dataset, from shortly before the explosion and until 3 days after, so we can still say nothing about the effect it may have had on those readings.
  • #7,618
798
30
I am interested in any interpretation of what happened at any unit late on March 20th or early in the morning on March 21st, because I am curious about the radioactivity peak recorded in Mito at 6 AM on the morning of March 21st, as in most cities in Eastern Japan on that date<..>
I think it is fair to say that the new data set indicates an untoward event occurring in unit 3 about 2am on March 21st. This is something we have been so far completely oblivious about. It happened during the nighttime, so theres no imagery of the event, and for the relevant period of this event, we also had no access to data until now.
  • #7,619
634
The main problem with the data and these questions is the time period that the data covers. There were 2 important releases of data in recent days.
One set filled in some gaps at various times later on, for example around 18th-19th march onwards when they managed to switch on lots of additional temperature sensors at reactor 3. We already had a lot of this data but some corrections were made and some gaps were filled in, but I think this was more notable for reactor 2 at an earlier time period, think I mentioned this yesterday.
The other set was a large quantity of data about lots of reactor parameters during the earthquake and in the hour or so that followed afterwards. So this data is from too early a period to tell you about the explosions. Its probably of most interest to those who want to see how water levels and emergency systems responded to the earthquake and tsunami. Press stories indicate that the data shows the emergency cooling at reactor 1 being turned off. But there is also data showing what things such as the RCIC were doing in the first hour or so. Problem with much of this data is we need to know what happened in the many emergency hours that followed, but this data is not available.
  • #7,620
NUCENG
Thanks, that is a good amplification on my post. I should have covered the trip.
  • #7,621
205
Sure you could build a floating box with 20 foot thick walls all around, doesn't mean it can't be shaken. Do you want to put your really thick walled floating box on sand or solid rock? See the difference yet?
  • #7,622
634
To be honest it is not true that data about this event was new to us yesterday. Plenty of people had likely seen some of this data in graph form already, although it may not have been noticed because of the larger messy temperature etc picture seen on reactor 3 graphs both before and after 21st. And the data that showed huge pressure spike from one sensor at 01:25, 01:45 and 02:30 had certainly been seen before by some people on this forum, because someone found old version of this data on the internet and posted about it here a while back, but again Im not sure if anyone noticed the pressure spike early on 21st march.
The problem I still have with this event is that there are no interesting changes to CAMS readings around this period, and simply because there was so much going on during the week of the 20th march that it is hard to know what to rule out. I have already talked about weather, and I believe tepco webcam archive images from around 20th will show that it rained on site. They had been connecting power up to various things at various reactors. When they got temperature sensors working at reactor 3 around 19th march, they saw scary temperatures and I think they implemented additional cooling within a few days. And by the end of the week we heard about basement water at reactor 3 because workers trod in it. And even now I think I am missing out plenty more things that happened that week.
Im not trying to dismiss the march 21st event, but given these things, and the fact that there also seemed to be spikes in radiation levels on site in the days before 21st, we should not try to look at this event in relative isolation. Its not so easy because as mentioned the interesting temperature measurements are unavailable until 19th march, so there is a gap in our knowledge about key early days of problems at reactor 3.
  • #7,623
I_P
48
This, elektrownik, is a most interesting document. It includes far more datapoints than I have seen before, including during the most interesting moments. I've previously estimated the pressure drop within the containment during the explosion of unit 3 to be >=0.1 MPa. Based on this document, the estimate of DW pressure drop must be revised to >=0.4MPa.
It is also news to me from this document, that the RPV during the period of the 'black smoke event' on March 21st briefly peaked out at >12MPa, before it dropped back abruptly and went down to to atmospheric. My,my.
At the time (20th) TEPCO said that they were considering venting unit 3 due to rising pressure. Later they said that the situation had resolved itself and they didn't need to vent... Yes, of course they didn't because the pressure dropped to atmospheric after the 'resolution', whatever it was.
  • #7,624
798
30
That's a perfect non-argument. The a priori chances of its landing in _any_ particular configuration is near zero.
C'mon.... it was installed there before anything happenned.
Why do you think so?
  • #7,625
634
Its a good question. Im not sure if TEPCO have tried to answer it, but from everything I have read this seems to be the position they currently take on this matter, as talked about a lot in the news at the weekend.
It maybe that they actually mean that most of the core is still in the reactor pressure vessel, and that they do not exclude possibility that a little bit of it escaped.
It could be that they mean very tiny holes. Or holes that are above the level where the corium now lives, but still low enough down that water they pump in escapes.
Or some combination of the above in conjunction with the idea that the corium didnt melt the reactor vessel itself, but rather something that is normally connected to the reactor pressure vessel, but melts more easily, and leaves a gap where it was before it melted.
I assume the main reason we dont hear far more talk about the core no longer being in the reactor, is the temperature levels of the reactor vessels. They are still hot, so we assume something is still there to heat them. But this is far from my area of expertise so other people could say better about this stuff.
Related Threads on Japan Earthquake: nuclear plants
15K
389K
  • Last Post
20K
  • Last Post
9K
  • Last Post
13K
  • Last Post
15K
  • Last Post
  • Last Post
