Japan Earthquake: Nuclear Plants at Fukushima Daiichi
In summary: RCIC consists of a series of pumps, valves, and manifolds that allow coolant to be circulated around the reactor pressure vessel in the event of a loss of the main feedwater supply.In summary, the earthquake and tsunami may have caused a loss of coolant at the Fukushima Daiichi NPP, which could lead to a meltdown. The system for cooling the reactor core is designed to kick in in the event of a loss of feedwater, and fortunately this appears not to have happened yet.
gmax137
Education Advisor
2,756
2,830
Does anyone have any reliable info on the nuclear plants - the reports on the news seem garbled to me.
Edit by Borek:
To All:
Please stick to technical aspects and to things happening at the Fukushima Daiichi NPP.
There are several other threads discussing different aspects of the disaster:
Why is Fukushima nuclear crisis so threatening?
Fukushima radiation detection and measurement
The "more political thread" besides "Japan Earthquake: nuclear plants" scientific one
Japan earthquake - contamination & consequences outside Fukushima NPP
Unless one has direct contact from someone in the plant, the best one can do is the releases by TEPCO or METI, but METI is probably getting it second hand. I haven't seen any official releases from METI though.
TEPCO press releases
http://www.tepco.co.jp/en/index-e.html
http://www.tepco.co.jp/en/press/corp-com/release/11031103-e.html
http://www.tepco.co.jp/en/press/corp-com/release/11031104-e.html
WNN - http://www.world-nuclear-news.org/RS_Massive_earthquake_hits_Japan_1103111.html
IAEA - http://www.iaea.org/newscenter/news/2011/tsunamiupdate.html
WANO is behind the curve.
I have not found any direct press release from METI, but
Fukushima reactor pressure may have hit 2.1 times capacity: METI
http://www.reuters.com/article/2011/03/11/us-japan-quake-tepco-pressure-idUSTRE72A7DB20110311
Woah - not good. That's a big NO-NO.
Problems at a second unit
TEPCO: loses control of pressure at 2nd nuclear plant
http://www.reuters.com/article/2011/03/11/us-japan-quake-tepco-daini-idUSTRE72A8GM20110311
If this is true, I can see a lot of managers getting sacked.
And there is this AP article on Yahoo - http://finance.yahoo.com/news/Japan-quake-causes-apf-1121920057.html?x=0 [Broken]
Is there any real chance at a meltdown or is that just the typical media hype?
At the moment, I don't see a 'real' chance of a meltdown. It is a worst case scenario, which is what licensing space is all about.
Some of the worst case scenarios involve extraordinary, and not necessarily physical real situations. It's a bit like crash testing a car by dropping it out of an airplane at several thousand feet, knowing full well that such a car would never be able to achieve such a velocity on level ground since the engine could not achieve the speed or the tires would blow out well before the speed could be achieved.
Some in the media will sensationalize the situation in order to grab the audience in order to sell commercials for useless stuff. But I digress. :rolleyes:
I'd like to keep the discussion here on the technical aspects - as soon as we learn from reliable sources.
We have the earthquake thread in P&WA.
Ok. This question is pretty 'elementary' but I do not know much about how a NPP works. I read an http://news.yahoo.com/s/nm/20110311/pl_nm/us_japan_quake_nuclear_clinton" [Broken] that said that the US delivered coolant to Japan. Why does Japan need the coolant? I don't understand how an earthquake and a tsunami can make a NPP lose its coolant? Also, what specific purpose does the coolant serve in the plant (what exactly does it cool) and what would happen if Japan could not get more coolant?
There was some miscommunication. I'm not sure who said what to whom, but apparently Sec of State Clinton mentioned coolant was being flown to Japan. That is incorrect.
They might airlift some generators, but I have not heard any details.
A light water reactor (LWR) uses water coolant under pressure to both moderate the neutrons and cool the nuclear fuel. The Fukushima units are boiling water reactors (BWRs), in which the water is boiled in the core at a pressure of ~1055 psia at Tsat ~ 286 C. The steam is sent directly to a high pressure turbine, and then the exhaust of the high pressure turbine feeds a set of low pressure turbines. The units are about 33% efficient, so about 67% of the heat is rejected through condensers to the environment, which at Fukushima is the sea.
When the reactor shutdowns, there is still some heat being generated from the decaying fission products. "At the moment of reactor shutdown, decay heat will be about 7% of the previous core power if the reactor has had a long and steady power history. About 1 hour after shutdown, the decay heat will be about 1.5% of the previous core power. After a day, the decay heat falls to 0.4%, and after a week it will be only 0.2%." Ref: http://en.wikipedia.org/wiki/Decay_heat#Power_reactors_in_shutdown
So it is important to cool the reactor for several days following shutdown.
The reactor core isolation cooling (RCIC) system in a boiling water reactor (BWR) is a safety system which serves as a standby source of cooling water to provide a limited decay heat removal capability whenever the main feedwater system is isolated from the reactor vessel.
The RCIC requires power from off-site or emergency diesel generators. Well the plant lost off-site power. The EDGs worked for about 1 hour then stopped. Now plant personnel are trying to get power from some other source. It's not clear why the EDGs quit, but they are supposed to work for days.
5.4.6 REACTOR CORE ISOLATION COOLING SYSTEM (BWR)
Likes Zacarias Nason
Ok. Thank you for all of the information. Hopefully they can get the problems resolved soon.
So the coolant system was knocked out, can't they scram the reactor?
The reactor is off but keeps producing heat has radioactive isotopes decay. Basically when it is on it produces a heat and radioactive isotopes which decay to more stable isotopes and give off more heat in the process. You can't turn this second process off, it just keeps going. The amount of heat the second process gives off goes down over time. However that means you have to keep cooling it for a number of days otherwise it would melt into a pile of radioactive goo (and take your expensive reactor with it).
So it's already off and won't explode? Cool, thanks.
It looks like the containment building has exploded. My educated guess is, what they feared might happen at TMI has happened here. The core melted down, releasing lots of hydrogen gas in the chemical reaction with the cladding, which then ignited.
[PLAIN]http://img855.imageshack.us/img855/1472/20mai00383969.gif [Broken]
Is it safe to assume the winds go towards the Pacific Ocean at the site? In case of an exposed meltdown?
At the time of the explosion, the wind was apparently moving toward the northeast, so any vapor would be carried out to sea.
However, I understand that the building where the explosion has occurred is not associated with containment, but I have not been able to verify this.
From World Nuclear News -
http://www.world-nuclear-news.org/RS_Battle_to_stabilise_earthquake_reactors_1203111.html
Tepco has said that the pressure within the containment of Fukushima Daiichi 1 has reached around 840 kPa, compared to reference levels of 400 kPa.
So pressure in containment is about 8.4 atm rather the 4 atm, the nominal design pressure.
and
Television cameras trained on the plant caputured a dramatic explosion surrounding unit 1 at around 6pm. Amid a visible pressure release and a cloud of dust it was not possible to know the extent of the damage. The external building structure does not act as the containment, which is an airtight engineered boundary within. The status of the containment is not yet known.
and meanwhile at the plant next door, Fukushima Daiini (plant 2)
Unit 1's reactor core isolation cooling system had been operating normally, and this was later supplemented by a separate make-up water condensate system. However, the latter was lost at 5.32am local time when its suppression chamber reached 100ºC. This led Tepco to notify government of another technical emergency situation.
The situation is serious. What has happened, shouldn't have happened.
A TEPCO spokesperson made a statement on Japanese TV about 20 minutes ago. The explosion was supposedly from a buildup of hydrogen around the containment vessel. Apparently, they will flood the containment vessel with seawater (and boric acid?) Does that make sense? They also increased the evacuation zone to 20km. The reporters present didn't seem to like the contradiction of TEPCO's claim that everything was still safe and the expansion of the evacuation zone.
Caveat: my Japanese is not so great, so I may have misunderstood some of it.
EDIT: after checking online, looks like I got most of it right, but it was a government official, not a TEPCO spokesperson
I have to say I don't understand how you can have a hydrogen explosion blowing apart the confinement building, and not the reactor vessel.
I also don't understand how you can let any pressure build up in the confinement building at the risk of rupture if it is slowly. One should prefer steam releases (even contaminated) in order to ensure the integrity of the confinement building if ever the reactor vessel breaks, no ? Now we are not very far from a full release of the core in the environment.
I tried to consult the japanese dose rate surveillance site, but it appears they don't have information for the northern prefectures:
http://www.bousai.ne.jp/eng/ [Broken]
I don't know how they transmit their measurements, supposedly via internet. Did the internet break down completely in the northern part of japan?
I have read much the same in English. So far, I have heard conflicting claims - that the explosion was / was not the containment building. I'd have to find a map of the site to figure out if the explosion was near unit 1 or 4. Unit 1 has the most severe problem, while unit 4 was shutdown cold already. From the picture, it looked like the explosion was near unit 4.
See this article - http://mdn.mainichi.jp/mdnnews/news/20110312p2g00m0dm073000c.html [Broken]
If the containment is breached with an uncooled reactor, that is very serious.
I have heard that Chief Cabinet Secretary Yukio Edano mentioned cooling unit 1 with seawater, but I don't know where he is getting the information.
Cooling directly with seawater would be a drastic step.
The news from the area is rather sketchy.
The articles are just popping up on Japanese pages. The latest may not be translated to English yet. Every Japanese channel has been showing explanations about the containment vessel and the seawater insertion, so I guess they are going to do it.
More than like the explosion was within the Off-gas system external to the reactor building and below the off-gas vent towers you see. Primarily due to radiolytic hydrogen build-up. Radiation level increases would be due to premature release of radioactive noble gases (Ze, K, I whcih are normal held up for decay).
The suppression chamber at 100 C appears to be within or at the limit of DBA parimeters. It is doing what it is supposed to do cool the water and provide cooling water to the LPCIS. The steam driven HPISs are probably out due to lack of vaible carry over steam in the system. If the diesel generators went south then the LPCIS will be failling.
BTW, 1,000 times increase in radiation levels is not that serious, in that the baseline measurement point is background levels in the control rooms and environment. This results in about 50-100 mrem in control room and 30 mrem immediately external to the plant out to the licensee controlled perimeter. Airborne doses to K, Ze, I would be measurable, but a very small portion of allowed emergency doses.
The reactor in question is I believe a BWR 4 GE designed unit. This model is over 40 years old and use less robust safety system that more modern BWRs use.
Others I have heard a suggesting the hydrogen many have been used in the generator as a lubricant which is housed near the reactor. Any coment on that?
Hydrogen is used to cool generators. Hydrogen gas has good thermal conductivity and low viscosity. The generator is housed in the auxilliary building or turbine hall, which is adjacent to the containment. The generator is not housed near the reactor.
Steam from the reactor is passed in steam lines (massive pipes) to the turbines, and the turbines drive the generator.
Here is a link to some expert testimony:
http://news.yahoo.com/s/nm/20110312/ts_nm/us_japan_quake_experts [Broken]
They seem to think that everything is under control.
The best statement:
"We don't have any information from inside the plant. That is the problem in this case.
Otherwise, everyone outside is simply speculating.
They certainly are cautious with public announcements.
http://www.tepco.co.jp/en/press/corp-com/release/11031225-e.html
"Today at approximately 3:36PM, a big quake occurred and there was a big
sound around the Unit 1 and white smoke."
otherwise known as an explosion...
and here:
http://www.tepco.co.jp/en/press/corp-com/release/11031224-e.html
this update is called "occurence of a specific incident stipulated in article 15, clause 1 of the act on special measures concerning nuclear emergency preaparedness"
if you look up article 15, clause 1 in said document you can see that the title of the update basically translates to "occurence of abnormally elevated radiation levels".
Something I don't understand. How would you get K, Ze & I out of the core without melting part of the fuel?
From what I understand, this type of BWR has instead of a strong outer concrete containment like PWR's have, it has a smaller steel containment dome around the reactor pressure vessel, and a weaker outer containment building. So it is possible that the hydrogen was released from the inner containment, and then blew up the outer containment, but leaving the reactor more or less in tact. However, reports I read indicate they are detecting cesium and iodine in the vicinity, indicative of core damage and release.
The story also said dose rates were 1500 micro Sv/hour 5km away from the plant around the time of the explosion (150 mrem/hr). Far above background levels, but not a health hazard. The situation may have changed since last night though.
I doubt there is enough hydrogen in the generator to create an explosion that big, especially since it is not contained in a pressurized container. The pictures clearly show the containment building exploding, and there is a visible fireball with the shockwave.
  • #31
Are satellites able to detect if the core is melting/melted?
i.e., are they capable of detecting a 2000°C temperature difference in an 2x2 meters area?
What kind of satellite should they be? Standard meteo satellites, or secret military atomic-detonation-detector satellites?
  • #32
Could these image be used to monitor the meltdown?!?
http://webpanda.iis.u-tokyo.ac.jp/IIS/L1B/ [Broken]
http://www.nodc.noaa.gov/dsdt/cw/ [Broken]
  • #33
oldsloguy said:
Something I don't understand. How would you get Kr, Xe & I out of the core without melting part of the fuel?
If there was some corrosion of the cladding, or the fuel rods overheated, then the softer cladding balloon to the point of perforation. That is not core melting, and in general, core melting is something of a misnomer.
It's not clear what temperatures are reached in the core - whether the cladding got to 100 deg C or 1000 or more, or somewhere in between. While there is water boiling, then the cladding temperature is near the saturation temperature of the boiling water - at 4 atm or 8 atm or whatever the ambient pressure is.
In the steam region, the temperature would be higher because of the poor heat transfer in the steam, especially without forced convection.
One only needs a small breach in the cladding to release Xe, Kr and a little I. Iodine is water soluble, and it is more likely in the coolant.
An infrared thermometer could be used to gauge the temperature of the exposed drywell and inner containment.
  • #34
Excerpt: 3.1.3 Release of Fission Products from Fuel Contaminant
Even though the reactor core may contain no defective fuel, natural uranium contamination of core construction materials and Zircaloy cladding, as well as enriched uranium contamination of the external cladding surfaces, could be the source of fission products in the coolant during power operations. The recoil range of a fission product is approximately 10 microns; therefore, only the fissions that occur within ≈10 microns of the outer surface of the Zircaloy cladding can introduce fission products into the coolant. It is safe to assume that half of the recoils from the fissioning nuclei will escape to the coolant and the other half will be embedded in the host material.
More Info: http://www.nap.edu/openbook.php?record_id=9263&page=35 [/url
  • #35
NHK English is currently reporting that the hydrogen explosion didn't rupture the containment vessel. (Albeit the outer wall of the building) From what I know of these things, that's pretty much where it would be expected to happen - given that they try to vent the steam 'under the dome' rather than to the outside?
Drastic mostly in terms of radiation leakage, then? I mean, I doubt they have much concern for the reactor itself at this point.
They were due to be decommissioned soon even without this disaster, so I think it's safe to say these reactors will never go critical again.
<h2>1. What caused the Japan earthquake and subsequent nuclear disaster at Fukushima Daiichi?</h2><p>The Japan earthquake, also known as the Great East Japan Earthquake, was caused by a massive underwater earthquake that occurred on March 11, 2011. The earthquake had a magnitude of 9.0 and was the strongest ever recorded in Japan. The earthquake triggered a massive tsunami, which caused extensive damage to the Fukushima Daiichi nuclear power plant and led to a nuclear disaster.</p><h2>2. What is the current status of the nuclear reactors at Fukushima Daiichi?</h2><p>As of now, all of the nuclear reactors at Fukushima Daiichi have been shut down and are no longer in operation. However, the site is still being monitored for radiation levels and there is an ongoing effort to clean up the radioactive materials that were released during the disaster.</p><h2>3. How much radiation was released during the Fukushima Daiichi nuclear disaster?</h2><p>According to the International Atomic Energy Agency, the Fukushima Daiichi nuclear disaster released an estimated 10-15% of the radiation that was released during the Chernobyl disaster in 1986. However, the exact amount of radiation released is still being studied and debated.</p><h2>4. What were the health effects of the Fukushima Daiichi nuclear disaster?</h2><p>The health effects of the Fukushima Daiichi nuclear disaster are still being studied and monitored. The most immediate health impact was the evacuation of approximately 160,000 people from the surrounding areas to avoid exposure to radiation. There have also been reported cases of thyroid cancer and other health issues among those who were exposed to the radiation.</p><h2>5. What measures have been taken to prevent future nuclear disasters in Japan?</h2><p>Following the Fukushima Daiichi nuclear disaster, the Japanese government has implemented stricter safety regulations for nuclear power plants and has conducted stress tests on all existing plants. They have also established a new regulatory agency, the Nuclear Regulation Authority, to oversee the safety of nuclear power plants. Additionally, renewable energy sources are being promoted as a more sustainable and safer alternative to nuclear power in Japan.</p>
  • Nuclear Engineering
46K
51
416K
17K
258K
14K
10K
