Homework Help: Java: Calling On An Object
  1. Apr 5, 2015 #1
    How do I take the union between an object called on and the object passed in the parameter?
    2. Relevant equations
    None
    3. The attempt at a solution
    I have an interface:
    Code (Java):
    import java.util.Set;
         * An extended Set where there is added functionality
         * @version 3/23/14
        public interface NewSet<T> extends Set<T> {
             * Calculates the set union with the given input
             * @param set - the set to perform the operation along with
             * @return  the set representing the invoked set and the parameter
             NewSet<T> union(NewSet<T> set);
             //and a bunch more methods ...
    And I have a class that extends this interface:
    Code (Java):
        import java.util.ArrayList;
        public class gSet<T> implements NewSet<T> {
    Now, the union method requires a NewSet object to be called on. The Union will be performed between the object called on and the object passed in the parameter, which is set. But I am confused on how to do this?
    How do I call on a NewSet object in order to take the union between the object called on and the object passed in?
    Do I just do:
    Code (Java):
        public NewSet<T> union(NewSet<T> set) {
            NewSet<T> calledOn = new ArrayList<T>();
    Or is that totally wrong and I am not understanding what it means for an object to be called on?
  3. Apr 5, 2015 #2
    jedishrfu
    Staff: Mentor
    You'd walk the list of your argument NewSet and if not present in the 'this' instance then add it to the 'this' instance.
  4. Apr 5, 2015 #3
    Hm, what do you mean by walk the list?
  5. Apr 5, 2015 #4
    jedishrfu
    Staff: Mentor
  6. Apr 5, 2015 #5
    I can't use Hashset, I can only use ArrayList. But from what I can understand from your code is you created an instance of a Set, which I can't do because Arraylist isn't a set. So do I just create an instance of NewSet, i.e.
    Code (Java):
  7. Apr 6, 2015 #6
    I am really not understanding this. The changes I made was:
    Code (Java):
    public class GSet<T> implements NewSet<T> {
        private List<T> list = new ArrayList<>();
        public NewSet<T> union (NewSet<T> set)  {
            NewSet<T> rSet = new GSet<T>();
            return rSet;
    But I am still not understanding how to call on a NewSet object in order to take the union between the object called on and the object passed in?
Have something to add?
Draft saved Draft deleted
