Java Math.abs()
Office_Shredder
Staff Emeritus
214
When you take the absolute value of an integer value:
http://docs.oracle.com/javase/1.4.2/docs/api/java/lang/Math.html#abs(int) [Broken]
Note that if the argument is equal to the value of Integer.MIN_VALUE, the most negative representable int value, the result is that same value, which is negative.
Wondering if anyone can explain what abs does that makes it fail on the minimum integer value
Answers and Replies
Hurkyl
Staff Emeritus
Integer overflow. Check the magnitude of Integer.MIN_VALUE and Integer.MAX_VALUE.
I'm surprised they chose that, instead of raising an exception. Ah well.
Office_Shredder
Staff Emeritus
214
Thanks!
AlephZero
6,994
291
At least they chose some definite value, which is an improvement on the C standard.
Maybe this is an example of the design principle, "don't throw exceptions for things that are impossible to fix cleanly even if you catch them".
Related Threads on Java Math.abs()
10K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
