Homework Help: Java powers of two question.
  1. Oct 20, 2011 #1
    Write a program that takes a command line argument integer M and prints all the positive integers that are powers of 2 and less than or equal to M.
    2. Relevant equations
    for loops; if conditional.
    3. The attempt at a solution
    Code (Text):
    public class PowersOfTwo
        public static void main(String[] args)
            int m = Integer.parseInt(args[0]);
            for (int i = 0; i <= m ; i++)
                if (Math.pow(2, i) <= m)
                    System.out.println(Math.pow(2, i));
    Is this true and answers the problem? Why are the values printed in type double rather than integer? Like so, when I input 4 in the command-line:
    1.0
    2.0
    4.0
    And is there another way to do that using boolean? How do you check if an integer is a power of two? Do you use the modulus or what?
  3. Oct 20, 2011 #2
    Mark44
    Staff: Mentor
    Because the pow method returns a double, not an int.
    You can do this without using the pow method, by instead using nothing more complicated that multiplication.
    2 = 21 = 2
    4 = 22 = 2*2
    8 = 23 = 2*2*2
    and so on.
  4. Oct 23, 2011 #3
    Code (Text):
    public class Power
            int n = Integer.parseInt(args[0]);
            int a = 2;
            for (int i = 1; i <= n ; i++)
                a = a * 2;
                if (a <= n)
                    System.out.println(a);
    Is this fine? Whenever I input a number like 99, it works fine for the first couple of values then a negative number appears and a series of 0s appear out of nowhere.
  5. Oct 23, 2011 #4
    Mark44
    Staff: Mentor
    You should have some logic in your loop so that it exits after a > n.
    Try this.
    Code (Text):
       a = a * 2;
       if (a <= n)
       else
          break;
  6. Oct 23, 2011 #5
    Nevermind.
    I think I got it.
  7. Oct 23, 2011 #6
    Your version worked, but I did this:
    Code (Text):
    public class Power
            int a = 1;
            for (int i = 1; i <= n * i / a; i++)
                a = a * 2;
                if (a <= n)
    ..and it worked. I unintentionally did that, though; the i <= n * i /a.
  8. Oct 23, 2011 #7
    Mark44
    Staff: Mentor
    I like my solution better because it is simpler. A simpler solution is usually better than a clever solution, because it will be easier for some other person reading your code to understand.
