Java: Set Interface
  1. Apr 9, 2015 #1
    If I have a subclass that implements a set class how can I avoid having to override all the set classes methods?
    2. Relevant equations
    None
    3. The attempt at a solution
    I have an interface:
    Code (Java):
    import java.util.Set;
         * An extended Set where there is added functionality
         * @version 3/23/14
        public interface NewSet<T> extends Set<T> {
             * Calculates the set union with the given input
             * @param set - the set to perform the operation along with
             * @return  the set representing the invoked set and the parameter
             NewSet<T> union(NewSet<T> set);
             //and a bunch more methods ...
    And I have a class that extends this interface:
    Code (Java):
        import java.util.ArrayList;
        public class GSet<T> implements NewSet<T> {
    Now, all my methods in NewSet has been implemented into GSet, but since NewSet extends Set<T> the compiler wants me to implement the methods of Set, i.e. addAll(), removeAll(), containsAll(), and more but I don't want to override those methods. Is there away to avoid this? Do I make my GSet abstract and thus make the methods that need to be implemented from set abstract as well? Or is there an easier way to go about doing this like backing up my GSet class with an arraylist?
  3. Apr 9, 2015 #2
    jedishrfu
    Staff: Mentor
  4. Apr 9, 2015 #3
    Borg
    2017 Award
    jedishrfu beat me to it.
    If your assignment requires that you build it the way that you've shown, you can look at the HashSet source to quickly put together the implementations.
  5. Apr 9, 2015 #4
    Is it okay if I extend ArrayList instead because we haven't discussed HashSet yet?
  6. Apr 9, 2015 #5
    jedishrfu
    Staff: Mentor
    I don't think ArrayList is a Set though as it can allow multiple instances of the same object.
    ArrayList is a cloneable, serializable and randomaccess List
    http://docs.oracle.com/javase/7/docs/api/java/util/ArrayList.html
    You need to use one of the follow to subclass:
    Set setA = new EnumSet();
    Set setB = new HashSet();
    Set setC = new LinkedHashSet();
    Set setD = new TreeSet();
    Others are shown here:
    http://docs.oracle.com/javase/7/docs/api/java/util/Set.html
Have something to add?
Draft saved Draft deleted
