JD Jackson example
  • Thread starter Berko
On page 60 of his 3rd edition of Classical Electrodynamics, he discusses the method of images applied to a grounded conducting sphere with a single charge q outside it.
Near the end of the problem, he calculates the force on a small patch of area da as (sigma^2/2epsilon_nought)da.
Now, it seems to me that the force should be the E field at that point times the charge of the patch....i.e.
dF = (sigma/epsilon_nought)*(sigma da).
Where does the factor of 2 come from?
Thank you.
Answers and Replies
Bill_K
Insights Author
4,155
195
The E field of a surface charge density is calculated by applying Gauss's Law. The usual situation is symmetrical -- half the E field comes out of each side of the surface. However in this case E=0 on the inner side, so all of the E has to come out the outer side, and is consequently twice the usual value.
But, that's exactly my point. The E field SHOULD be sigma/epsilon_nought....but it IS sigma/2epsilon_nought.
I'm having a thought.
Can it be due to the fact that the electric field (sigma/epsilon_nought) is due to the entire surface and we are only interested in the field the REST of the surface produces at the surface patch under consideration?
So, here's what I came up with. Would love confirmation.
The E field is generally sigma/2epsilon. Since it's a conductor, the E field is sigma/epsilon. So, the rest of the conductor must be supplying the needed E field to cancel the inside E field and reinforce the outside E field. How much cancellation and reinforcing is there? You guessed it. E/2epsilon.
So, the E field provided by the rest of the conductor is E/2epsilon.
Tada?
Weeee!
Related Threads on JD Jackson example
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
16K
12K
