Josephson effect
  • Thread starter chientewu
Hi,
I am confused about josephson effect. Take SNS for example. If the phase of these two superconductors are different, then there will be a josephson current through the junction. Experimentally, do we measure the current by attach two ends of SNS with a wire? If there is no wire attached to these two ends, will there be a current flowing through the junction? In other words, will there be a self-generated current in it without a loop?
Thanks for you help.
f95toli
425
Yes, you measure it by passing a current through the junction and then measuring the voltage across it.
And no, there won't be "self generated" current.
The only time you would get a current through a junction not connected by a wire is if it is part of a loop that is being threaded by a changing flux (i.e. an RF- SQUID).
Thanks for your quick reply. Now I am confused about your statement "measure it by passing a current through the junction and then measuring the voltage across it." It means we have to pass a current through the junction, otherwise there will be no current? Is it correct. Thanks.
f95toli
425
Yes, the current-voltage characheristics of JJs are measured in exactly the same way as for example semiconductor diods; you use current source to bias it and then a voltmeter to measure the voltage across it (you can do it the other way aorund, using a voltage source and an ammeter; but this is quite tricky since the impedance of the junction is practically zero when you are on the supercurrent branch).
Related Threads for: Josephson effect
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
