Java JTable not Visible
  1. Aug 24, 2016 #1
    Hi,
    I am trying to add data in a table. I am not getting any error but table is not vi
    Code (Java):
    import javax.swing.*;
    import java.util.*;
    import javax.swing.JTable;
    import javax.swing.table.DefaultTableModel;
    public class TableEg{
    JFrame frame = new JFrame("Table Eg1");
    JPanel panel = new JPanel();
    JTable table = new JTable();
    DefaultTableModel model = new DefaultTableModel(  );
    JScrollPane scrollPane = new JScrollPane(table);
    TableEg() {
      Vector<String> rowOne = new Vector<String>();
        rowOne.addElement("Row1-Column1");
        rowOne.addElement("Row1-Column2");
        rowOne.addElement("Row1-Column3");
        model.addRow(rowOne);
        Vector<String> rowTwo = new Vector<String>();
        rowTwo.addElement("Row2-Column1");
        rowTwo.addElement("Row2-Column2");
        rowTwo.addElement("Row2-Column3");
        model.addRow(rowTwo);
        table.setModel(model);
      frame.setSize(500,200);
      frame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
      frame.add(panel);
      panel.add(table);
      panel.add(scrollPane);
      frame.setVisible(true);
    public static void main(String args[]){
      new TableEg();
    Some body please guide me why i cant see the table data?
    Zulfi.
  3. Aug 24, 2016 #2
    jedishrfu
    Staff: Mentor
  4. Aug 25, 2016 #3
    Hi,
    This problem has been solved. I got its solution from other forum.
    I cant understand what you mean by layout of the table.:
    <Off the bat, I don't see where you've defined a layout for the table.>
    if you mean the dimension of the table then you are right. They suggested me to use another constructor.
    Code (Java):
    Complete code is:
    import java.util.*;
    //DefaultTableModel model = new DefaultTableModel(  ); ***Doesnt work
    DefaultTableModel model = new DefaultTableModel(new Object[]{"1","2","3"},0  );
    TableEg() {
      frame.add(panel);
      //panel.add(table);
      new TableEg();
    Thanks for your response.
    Zulfi.
Have something to add?
Draft saved Draft deleted
