Judging distribution shape using mean and standard deviation
In summary, the mean and standard deviation are used to describe the central tendency and spread of a dataset, allowing for comparisons between different datasets. To determine if a distribution is normally distributed, the mean and standard deviation should fall within a certain range and a bell curve or histogram can be used for visual assessment. These measures can also be used to judge other types of distributions, but may not accurately represent highly skewed or bimodal distributions. Outliers can greatly impact the use of mean and standard deviation, and there are limitations to using these measures alone to judge distribution shape. Other measures and visualizations should also be considered for a more comprehensive understanding.
drawar
132
A recent summary for the distribution of cigarette taxes (in cents) among the 50 states and Washington, D.C. in the United States reported mean = 73 and standard deviation = 48. Based on these values, do you think that this distribution us bell-shaped? Justify your answer.
Nil
Basically I don't think mean and stdev have anything to do with the shape of the distribution. I'm here just to ask for some hints from you. Thanks!
Hi there,
I would approach this question by looking at the definition of a bell-shaped distribution, also known as a normal distribution. A normal distribution is a symmetrical, continuous probability distribution that follows a specific mathematical formula. It is characterized by a bell-shaped curve, with the majority of the data falling near the mean and tapering off towards the tails.
In this case, we have a mean of 73 and a standard deviation of 48 for the distribution of cigarette taxes among the 50 states and Washington, D.C. This means that the majority of the data (about 68%) would fall within one standard deviation of the mean, which would be between 25 and 121 cents. This suggests that the data is relatively spread out and not clustered closely around the mean, which is not typical of a normal distribution.
Furthermore, a normal distribution has specific properties, such as a skewness of 0 and a kurtosis of 3. Skewness is a measure of symmetry, with a skewness of 0 indicating perfect symmetry. A kurtosis of 3 indicates that the distribution has a similar shape to a normal distribution. However, it is worth noting that a kurtosis value of 3 is not a definitive indicator of a normal distribution, as other distributions can also have a kurtosis of 3.
In summary, based on the given mean and standard deviation, it is unlikely that the distribution of cigarette taxes among the 50 states and Washington, D.C. is bell-shaped. The data appears to be relatively spread out and not symmetrically distributed around the mean. However, further analysis and examination of the data would be needed to make a definitive conclusion.
1. What is the purpose of using mean and standard deviation to judge distribution shape?
The mean and standard deviation are used to describe the central tendency and spread of a dataset, respectively. By examining these measures, we can get a sense of the overall shape of the distribution and make comparisons between different datasets.
2. How do we determine if a distribution is normally distributed using mean and standard deviation?
A distribution is considered to be approximately normal if the mean and standard deviation fall within a certain range. Specifically, if the mean is close to the median and the standard deviation is small, the distribution is likely to be normal. Additionally, we can use a bell curve or histogram to visually assess the shape of the distribution.
3. Can we use mean and standard deviation to judge other types of distributions, such as skewed or bimodal?
Yes, mean and standard deviation can be used to judge the shape of any distribution, including skewed or bimodal distributions. However, these measures may not accurately represent the distribution if it is highly skewed or has multiple peaks.
4. How do outliers affect the use of mean and standard deviation to judge distribution shape?
Outliers, or extreme values, can greatly impact the mean and standard deviation of a dataset. As a result, the distribution may appear to have a different shape than it actually does. It is important to identify and address outliers before using mean and standard deviation to judge distribution shape.
5. Are there any limitations to using mean and standard deviation to judge distribution shape?
While mean and standard deviation are useful measures for describing distribution shape, they have their limitations. These measures do not account for the entire dataset and may be influenced by extreme values or outliers. Additionally, they may not accurately represent the shape of non-normal distributions. It is important to consider other measures and visualizations in conjunction with mean and standard deviation when judging distribution shape.
20K
