Just squaring won't work
  1. Aug 5, 2014 #1
    Solve the equation
    (x² + x -2)² + x² = 4
    *Calculators aren't allowed
    2. Relevant equations
    Algebra
    3. The attempt at a solution
    Adding x - 2
    (x² + x -2)² + x² + (x - 2) = 4 + x - 2
    Now, let's say y = x² + x -2, then
    y² + y - (2 + x) = 0
    But it isn't solvable yet
  3. Aug 5, 2014 #2
    jedishrfu
    Staff: Mentor
    Have you tried plugging some numbers in it like 0 or 1?
    or even some small negative numbers like -1 or -2?
    To start solving it, try expanding the first term (x^2 + x - 2)^2 and then add in the x^2 term
    use the trick:
    Code (Text):
                                         x^2   +    x    - 2
                                     *  x^2   +    x    - 2
                                      -2x^2    - 2x   + 4
                             x^3 +...
                  x^4 + ...
                 x^4 + ...
  4. Aug 5, 2014 #3
    ehild
    That method does not help. Now you have two unknowns instead of one.
    Expand the square, bring the equation in form f(x)=0 and try to factorize . It is quite simple.
    ehild
  5. Aug 5, 2014 #4
    Mentallic
    Take -4 on each side, then [itex]x^2-4=(x-2)(x+2)[/itex] and then add [itex]x^2(x+2)[/itex] to each side. It should all fall into place after that.
    Also keep in mind that as jedishrfu suggested, you can find some easy rational roots such as x=0 and x=-2, and when you do find such roots, you then know that
    [tex]f(x)=(x^2+x-2)^2+x^2-4=x(x+2)(ax^2+bx+c)[/tex]
    For some constant a,b,c (you can quickly tell that a=1 for example) and then you can find b and c after comparing coefficients. This is also what polynomial division accomplishes.
  6. Aug 6, 2014 #5
    Borek
    Staff: Mentor
    To the OP: to make it look less random, it is an application of the integral root theorem. If you have a polynomial, where the leading coefficient is 1, if the polynomial has an integer root, it is guaranteed to divide the free coefficient.
    If you try to attack the problem by brute force, just squaring and tidying the polynomial in question you will find there is no free coefficient, so 0 is one of the roots. After factoring it out, you will find the remaining 3rd degree polynomial has the free coefficient equal 4 - so possible integer roots are -4, -2, -1, 1, 2 and 4. Just try them all, and you will be left with a simple quadratic equation.
    This is in turn weaker version of the http://en.wikipedia.org/wiki/Rational_root_theorem.
  7. Aug 6, 2014 #6
    Ray Vickson
    If this is an olympiad question, you might assume the solution is easy, but tricky. Try assuming the two terms on the left are equal; that is, try ##x^2 = 2, \: x^2 + x - 2 = x##.
  8. Aug 6, 2014 #7
    Thanks!
  9. Aug 6, 2014 #8
    x2+x-2=(x+2)(x-1)
    So
    [tex](x^2+x-2)^2=(x+2)^2(x-1)^2[/tex]
    Try substituting that into your equation, and factoring out (x+2). The remaining factor will simplify greatly if you expand it.
    Chet
  10. Aug 6, 2014 #9
    Thanks, Chet, a good way to solve too
  11. Aug 7, 2014 #10
    ehild
    You could have solved the problem without any tricks, just expanding the square:
    ##(x^2+x-2)^2+x^2-4=0##
    ##x^4+2x^3+x^2-4x^2-4x+4+x^2-4=0\rightarrow x^4+2x^3-2x^2-4x=0##
    x can be factored out, one root is zero.
    ##x^3+2x^2-2x-4=x^2(x+2)-2(x+2) ##... easy to factorize further.
    ehild
Have something to add?
Draft saved Draft deleted
