Homework Help: K_a and K_b
  1. May 17, 2010 #1
    Hi everyone, I need help understanding something. My assignment is talking about the dissociation of CaCl2 and NaHC03- in water and heats of solution etc and says: "Write out the K_a and K_b for the bicarbonate ion with chemical equations". Problem is though that I don't even know what K_a and K_b is...I've never seen this in my life, my high school teacher must of missed this completely and now they're asking this of me in University! So, if anyone could explain to me what this is and how I go about finding a solution I would MOST SINCERELY appreciate it! Help please! :)
    2. Relevant equations
    3. The attempt at a solution
  3. May 17, 2010 #2
    danago
    Ka and Kb are called the acid and base dissociation constants. They are basically a way to measure how strong a particular acid or base is.
    Im assuming that you have learned about chemical equilibrium? If you have the following reaction:
    [tex]A+B \rightarrow C+D[/tex]
    Then the equilibrium constant is given by:
    [tex]K=\frac{[D][C]}{[A]}[/tex]
    This number will represent how far the reaction proceeds in the forward direction before reaching chemical equilibrium.
    If you recall from your study of acids and bases, the strenght of an acid is how well it ionizes in a solution. For example, HCl in water will almost fully ionize into H+ and Cl- ions and is therefore a strong acid. However, HF is a weak acid and will only partially ionize. To quantify the extent to which it does actually ionize (i.e. the strength of the acid), the equilibrium constant of HF ionizing is used, which is called Ka.
    The same applies for a base. So to summarize, Ka and Kb are really just equilibrium constants that are given a special name when applied to acid/base reactions.
    For more info, have a look at http://en.wikipedia.org/wiki/Acid_dissociation_constant, or else do a google search--there is heaps of information out there!
  4. May 18, 2010 #3
    Borek
    Staff: Mentor
