Homework Help: Karatsuba method
  1. Apr 30, 2014 #1
    For polynomials f(x),g(x) of degree d = 2(r−1)−1, check that multiplying f(x) and g(x) by the Karatsuba method requires 3(r-1) multiplications in the field F.
    2. Relevant equations
    You can can more clearly see problem on page 383 #10:
    http://igortitara.files.wordpress.com/2010/04/a-concrete-introduction-to-higher-algebra1.pdf
    3. The attempt at a solution
    I understand Karatsuba method is
    (a1r+a0)(b1r+b0) = a1b1r2 +(a1b0+a0b1)r+a0b0
    = a1b1r2 +(a1b1r+a0b0r−(a1−a0)(b1−b0)r)+a0b0
    = (a0b0r+a0b0)+(a1b1r2+a1b1r)−(a1−a1)(b1−b0)r
    but I do not understand how to implement this with only the degree given in the problem.
  3. Apr 30, 2014 #2
    Zondrina
    Karatsuba multiplication has an advantage over the usual multiplication algorithm when ##n## is large enough.
    For example, take the polynomials ##f(x)## and ##g(x)## and suppose that ##r=1##. Then ##d = 0## and the Karatsuba method requires only ##1## multiplication since ##f(x)## and ##g(x)## are both constant.
    Now to see the effectiveness, suppose ##r = 2##. Then ##d = 1## and the Karatsuba method requires ##3## multiplications. Although by the usual FOIL method, we would require ##4## multiplications.
    I believe induction will be of assistance.
Have something to add?
Draft saved Draft deleted
