Kenetic fluid energy
  1. Apr 4, 2009 #1
    Can anyone tell me how to calculate the kenetic energy loss in the pressure of a fluid by forcing it to change direction 180 degrees? I need to know the pressure loss in a single reversal so I can start to figure how many I need. I’ve asked this question of your fluid power engineers, but they tell me it basically boils down to trial and error. But I need a reasonable point at which to start a trial.
    I need to lower the pressure of a 9.5 Liter/minute stream of .453 Kg/liter water 280 Kg/cm through a minimum passage area of 3.17 mm. I can’t do this with a single orifice because of anticipated solids in the fluid which would quickly clog such a tiny opening. I wish to harass and hector the fluid as much as possible by passing it through a course of abrupt right angle turns using the fluid’s inertia and other properties to accomplish a series of pressure drops. Is it possible working with this small volume? Does anyone have a reasonably non graduate student level formula which takes into account those factors needed to calculate the pressure losses? Thanks to anyone with the education to size this thing up.
Draft saved Draft deleted
