• Support PF! Buy your school textbooks, materials and every day products Here!
Kepler's Law
  • Thread starter Trizz
(a) Determine the forces that the moon and the sun exert on a mass, m, of water on Earth. Your answer will be in terms of m with units of N. (Use data from table 8-1 in your textbook for this question. The mass of the moon is 7.3 x 10 ^22 kg, and it can be assumed to be 3.9 x 10^5 km from the Earth's center.)
______ m N (force exerted by moon)
______ m N (force exerted by sun)
Fgr = G M1m2 / r^2
mass of earth = 5.98 x 10^24
I thought that I had everything for the equation, but I still can't seem to get it. Check out my work and see if there's something I'm missing. I'm not sure on what to use for the radius.
Fgr = (6.67e-11)(7.3 x 10^22)(5.98 x 10^24) / (3.9 x 10^5)^2
Answers and Replies
Say the earth is not there but replaced by a bit of water of mass "m". Then?
Thanks for the response Bright Wang.
So I replaced my equation with m, and this is what I got
Fgr = (6.67e-11)(7.3 x 10^22)(m) / (3.9 x 10^5)^2
then
Fgr = (4.860e12)(m) / (3.9 x 10^5)^2
then
(3.9 x 10^5)^2 = 4.869e12m
does that look right?
The given data for radius is in KM.
Alright I multiplied the radius side by 1000 to make up for the KM units. But one more question. Is that number supposed to be divided by 2 since I want radius, and isn't that diameter? Anyways, i got .03 for an answer, does that seem too small?
ideasrule
2,266
Which number? There's no diameters in this question.
i need r^2 for the Force of gravity equation. The statement said that the moon is 3.9 x 10^5 km from the earth. Is that not diameter? or is that the radius? Regardless, i still got .03 for the answer, which doesnt seem to make sense to me
Actually, im not sure what i got was .03. But here's my equation anyway.
(3.9 x 10^5)^2 = 1.521e11 x 1000 (for km) = 1.521e14
(6.67e-11)(7.3 x 10 ^22)(m) = 4.8691e12(m)
so.....
4.8691e12(m) / 1.521e14 = m????
Distance is radius. It doesn't even matter, r represents the distance between the objects.
4.8691e12(m) / 1.521e14 = m???? "
What? Your just using the equation.
You want to find Fg. Fg = GMm/r^2.... Why do you have mass on both sides? You trying to find force not acceleration.
Its just plug and chug. I didn't get 0.3m N.
I thought you said to use "m" for a variable ???
"Say the earth is not there but replaced by a bit of water of mass "m". Then? "
or do i just ignore that number
m can be whatever.
Fg = GMm/r^2 = G*(Mass of the moon)*m / distance{in meters}^2 = {some number}*m
wasnt able to get it in time. Thanks for the help though. Hopefully my teacher will explain it better
Related Threads on Kepler's Law
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
