Homework Help: Kepler's third law
  1. Aug 30, 2007 #1
    Using astronomical units as the unit of length , years as the time , and the mass of the Sun as the unit of mass , the value for k in kepler's third law is 1. In these units , what is the value of Newton's constant of gravitation G?
    2. Relevant equations
    P^2 =k*a^3
    P^2= 4*pi^2*a^3/(G(m(1)+m(2))
    Possibly k=4*pi^2/G*M(sun)
    P is the period
    3. The attempt at a solution
    since k = 1 and k =4*pi^2/G*M(sun), all I have to do is switch variables. k=4*pi^2/(G*M(sun)) => 4*pi^2/(M(sun))=G , but I found that method to be a problem because the G I calculated isn't equal the universal Gravitational constant we are all familar with.
  3. Aug 31, 2007 #2
    learningphysics
    So taking the mass of the sun as 1 solar mass... your answer should be [tex]G = 4{\pi}^2 (years)^{-2}(AU)^3(solar masses)^{-1}[/tex]
    To check that this is the same G you need to convert units...
  4. Aug 31, 2007 #3
    D H
    Staff Emeritus
    The universal gravitational constant has units. The value with which you are familiar, [tex]6.6730\times10^{-11}[/tex] is in units of [tex]m^3/kg/s^2[/tex]. The value differs when you change the system of units. For example, G is [tex]7.616\times10^{-5}[/tex] in the ever-popular furlongs-fortnights-stones system. You are asked to specify G in the AU-Msun-year system. The answer is not [tex]6.6730\times10^{-11}[/tex].
  5. Aug 31, 2007 #4
    Are my equations correct? I just need to convert my units to SI units?
  6. Aug 31, 2007 #5
    learningphysics
    Yes, I think the equations are right. just convert the units.
  7. Aug 31, 2007 #6
    D H
    Staff Emeritus
    Your instructor did not ask for the value of G in SI (MKS) units. He asked for it in AU-solar mass-year units. Learning physics gave you the answer in these units post #2.
    You only need to convert to SI if you want to verify that your answer is correct. If you do the conversion right, you will get [itex]6.672\times10^{-11}\text{m}^3/\text{sec}^2/\text{kg}[/tex], which compares very favorably with the published value of [itex]6.673\times10^{-11}\text{m}^3/\text{sec}^2/\text{kg}[/tex].
