Homework Help: Kepler's Third Law
  1. Nov 13, 2013 #1
    Find the period of a satellite that is in orbit 6.7×10^6 meters from the center of the earth?
    2. Relevant equations
    P^2=R^3 P=period and R=average distance
    3. The attempt at a solution
    so far I have tried P^2=(6.7×10^6)^3
    then sqrt of (P^2)=sqrt of (3.00763×10^20)
    My answer is the period of the satellite=1.73425×10^10
    I'm pretty sure my answer is way off, please describe how to get the correct answer.
  3. Nov 13, 2013 #2
    jedishrfu
    Staff: Mentor
  4. Nov 13, 2013 #3
    4∏/T^2=GM/R^3
    4∏/T^2=(6.67×10^-11)(5.98×10^24)/(6.7×10^6)^3
    12.57/T^2=(3.98866E14)/(3.00763E20)
    12.57/T^2=1.326180414E-6
    T^2=1.66700878E-5
    T=.0040829019
    Is this answer correct?
  5. Nov 13, 2013 #4
    jedishrfu
    Staff: Mentor
    I don't think so. How did you get T^2= ?
    I would have solved for T^2 first and then inserted the values. It always makes things easier.
    GM*T^2 = 4*pi^2 * R^3
    T^2 = 4*pi^2*R^3 / G*M
  6. Nov 13, 2013 #5
    SteamKing
    Staff Emeritus
    Unit-free calculations almost never end well.
  7. Nov 13, 2013 #6
    A Revision to my previous post
    The equation is 4pi^2/T^2=GM/R^3 not 4pi/T^2=GM/R^3
    I changed my answer to 5.46 periods
    39.48/T^2=(3.98866E14)/(3.00763E20)
    T^2=39.48/1.33x10^-6
    sqrt of T=sqrt of 39.48/1.33x10^-6
    T=5.45×10^3 periods/earth years
    Is my answer correct?
  8. Nov 13, 2013 #7
    jedishrfu
    Staff: Mentor
    I fixed my eqns to say pi^2
    so that T^2 = 4 * pi^2 * R^3 / (G * M) = 4 * pi^2 (6.7E6)^3 / ((6.67E-11) * (5.98E24)) = 2.98E7
    and T =5.46E3
    When I did my calculations I got tripped up by a lack of parentheses around the denominator terms which meant that I divided by the G and then multiplied by the M instead of dividing by (G * M)
  9. Nov 13, 2013 #8
    SteamKing
    Staff Emeritus
    Still won't knuckle under and use units, eh? Good Luck with the rest of your course work!
  10. Nov 13, 2013 #9
    jedishrfu
    Staff: Mentor
    Klingon programmers have no need of units, we use junits...
  11. Nov 13, 2013 #10
    jedishrfu
    Staff: Mentor
    Edit: To the OP I forgot the pesky pi factor again but fixed my post above.
    Having gotten the answer for T and knowing R does it seem reasonable?
    What object might have a periodicity like this?
    Oh and as SteamKing said where is your unit analysis? What units is used for T?
  12. Nov 13, 2013 #11
    D H
    Staff Emeritus
    That result is incorrect. You dropped a factor of pi.
    You are being sloppy and it is getting you in trouble.
    You also are not following instructions. You didn't read the instructions on where to post your physics problems.
    This is not an advanced physics homework problem. I'm moving this to the introductory physics homework section.
  13. Nov 14, 2013 #12
    SteamKing
    Staff Emeritus
    'Advanced Physics' also doesn't mean, "Units? Units? I don't need no stinkin' units!"
Have something to add?
Draft saved Draft deleted
