Kernel and Image
  • Thread starter bubbles
bubbles
97
[SOLVED] Kernel and Image
Ker(A) = Im(B)
AB = ?
A is an m x p matrix. B is a p x n matrix.
Since Ker(A) is the subset of the domain of B and Im(B) is the subset of the codomain of B, AB = I. I = identity matrix.
Is this right? It doesn't seem to make sense. There must be a mathematical (symbolic) way to solve for AB, right?
Answers and Replies
Dick
26,263
621
I'm assuming this means B:R^n->R^p. A:R^p->R^m. That way at least Ker(A) and Im(B) live in the same space. Now what do you say AB:R^n->R^m is?
bubbles
97
Is AB the p x m identity matrix?
Dick
26,263
621
Bad guess. AB is nxm. Consider AB(v). B(v) is in Im(B)=Ker(A). Guess again. Uh, what do you mean by 'identity matrix' anyway. There is no pxm identity matrix. Do you mean the zero matrix?
bubbles
97
Since Im(B) = Ker(A), does that imply that A and B are invertible? Then if B(v) is in the Ker(A) and Ker(A) = {0}, then AB = 0. Is that right?
Dick
26,263
621
Only one thing you said is right. Why should anything be invertible and why should Ker(A)={0}? If B(v) is in Ker(A) what's A(B(v))? If you think AB=0 then try and put together an argument that will convince me. In your own words.
bubbles
97
Since B(v) is in Ker(A) and T(v) = A * ker(A) = 0, then AB must be zero.
Dick
26,263
621
What's T? I think you MIGHT know what you are trying to say, but that's just a guess. If that's what you are planning to turn in as a solution, I don't think it will work. Can't you put that more clearly?
bubbles
97
The book defines the kernel as a subspace x and T(x) = Ax = 0 and ker(A) = x. T(x) is the linear transformation and A is the matrix. Should I not put the book's equation T(x) = Ax in my solution?
So in the solution I wrote in my homework, I wrote: BX is in ker(A) and AX = 0, X is in ker(A), therefore AB = 0, is that a good explanation?
Dick
26,263
621
I don't have your book. What's the linear transformation associated with Bx? Is it also T? What's the linear transformation associated with AB(x). If it's T, I'll scream. You aren't expressing yourself clearly. That's all I'll say.
Dick
26,263
621
It's getting there. Try saying this. For any vector x, Bx is in Im(B). Since Im(B)=Ker(A) then Bx is in Ker(A). If Bx is in Ker(A) then A(Bx)=0. So ABx=0 for all x. So AB=0. How does that sound?
bubbles
97
Thank you for your help! I understand what you mean about my vague explanation. I will try to clarify things a bit on my paper.
Dick
26,263
621
You're welcome. Thanks for letting me scream. Good luck!
Suggested for: Kernel and Image
  • Last Post
  • Last Post
  • Last Post
  • Last Post
