I Kerr black hole from above
  • Thread starter Creedence
Summary
How does it look like?
How does a Kerr black hole look like from above? Is it the same as a Schwarzschild one?
I could not find any convincing visualization for this question.
By above I mean from a point r>0 and ϑ=0.
4,414
What is the metric for a Kerr black hole and what do you get when you substitute 0 in?
Where to substitute?
Nugatory
Mentor
12,191
4,657
Are you asking for a reasonably technically accurate illustration? That’s what I’m inferring from the word “visualization”.
Of course the black hole itself doesn’t look like much of anything because it neither emits nor reflects light. All the interesting visual effects come from the matter nearby: accretion disks, radiation from infalling matter, jets, ....
Ibix
Insights Author
5,125
3,422
One could imagine a large piece of paper with a polar coordinate system drawn on it behind the black hole and ask how the pattern changes as the angular momentum increases, I suppose. Presumably you should hold the irreducible mass constant while doing it, and come up with some way of defining how far away you are in a reasonably consistent manner.
A.T.
1,467
This is relevant:
But I don't know if they ever made any visualization looking perpendicular to the plane of rotation.
Yes, this is what bugging me. I've created a simple raytracer some years ago and generated some videos, for example: .
A few weeks ago I started to refactor it and fix its bugs (mostly numerical in the nonlinear computations). For some reasons the black hole is in a fixed position and the rotation axis points to the viewer. The output totally looks like a nonspinning BH. I can't find anything to validate the output.
Edit: The other reason for this question is that the raytracer's old version knew only the Schwarzschild solution. Now I try to add the Kerr solution.
What differences did you expect from that view angle?
I rendered images of the BH using a square grid background. From that viewpoint the grid may get a vortex-like distortion in the case of a>0. Because of gtf ≠ 0.
Or with another not so precise wording: the lightrays come from infinity and "parallel" with the rotational axis of the BH get an eφ speed component. So the image gets a twist in the near of the BH shadow.
A.T.
1,467
Try a background that is not scrolling and has better contrast (black lines on white). And increase the spin rate and/or the resolution, in case the effect is still too weak to see.
Ibix
Insights Author
5,125
3,422
I would think a better background would be the polar coordinate system I suggested above. I would expect that evenly spaced rings would not appear so, and radial lines would spiral somewhat. One could easily cheat on the rendering in this case by only analysing a single radial line and noting the symmetry. Or maybe a couple of radial lines, to check the symmetry.
A.T.
1,467
@Creedence As Ibix suggests: Before rendering full size videos, one should do some quick tests, to find out what parameters would produce a visible effect. And to verify that the code actually produces that effect at all.
The video I posted is OK. It's generated by my old program version. The actual one generates images with grid background.
Ibix: radial lines is a good idea, thanks.
Want to reply to this thread?
"Kerr black hole from above" You must log in or register to reply here.
Related Threads for: Kerr black hole from above
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
