Uniformly Accelerated Motion: A Puzzling Problem?
In summary, the problem statement involves a particle traveling along the x-axis with uniformly accelerated motion and the need to show that its acceleration can be calculated using the formula a = 2(yt-xs)/ts(s-t). However, the problem seems to be ill-posed as there are multiple possible solutions without additional data points.
ilp89
The problem statement:
A particle travels along the x-axis with uniformly accelerated motion. At times t and s its position is x and y, respectively. Show that its acceleration is a = 2(yt-xs)/ts(s-t).
The attempt at a solution:
I could be wrong, but it seems to me this problem is ill-posed. Couldn't one solution be a = 0? Couldn't another be that acceleration which gets the particle from rest at (x,t) to (y,s)?
It does seem to be ill-posed; A particle can get from one point to another (from x to y) in a given time interval using any choice of initial speed and a suitable constant acceleration. Another data point of some kind would be required to make the problem determinate.
1. What is uniformly accelerated motion?
Uniformly accelerated motion is a type of motion in which an object's velocity increases or decreases at a constant rate. In other words, the object's acceleration remains constant throughout the motion.
2. How is uniformly accelerated motion different from uniformly motion?
Uniform motion is when an object's velocity remains constant, meaning there is no change in its speed or direction. In contrast, uniformly accelerated motion involves a constant change in velocity, either increasing or decreasing.
3. What is the formula for calculating uniformly accelerated motion?
The formula for uniformly accelerated motion is: v = u + at, where v is final velocity, u is initial velocity, a is acceleration, and t is time.
4. How is uniformly accelerated motion used in real life?
Uniformly accelerated motion is used in many real-life scenarios, such as objects falling due to gravity, cars accelerating or decelerating, and athletes running sprints. It is also used in physics experiments to study the effects of acceleration on different objects.
5. What are some common examples of uniformly accelerated motion?
Some common examples of uniformly accelerated motion include a car accelerating from a stop sign, a ball rolling down a ramp, a rocket launching into space, and a person jumping off a diving board.
