Solving Physics Homework: Car Dropped from 32.8m Cliff
In summary, the car lands 2.08 meters from the base of the cliff. Its impact speed is 19.3 meters per second, and the angle of impact is 19.3 degrees.
saralsaigh
A stunt man drives a car at a speed of 19.3 m/s off a 32.8 m high cliff. The road leading to the cliff is inclined upward at an angle of 19.3°. How far from the base of the cliff does the car land?
What is the car's impact speed?
What is the angle of impact?
First i divided my initial speed into components so i got Vx=6.38m/s and Vy=18.22m/s
I started with the y-direction:
d= v1t+0.5at^2 <---- i solved for time using inital speed at 18.22m/s
I got t= 1.86s
I then moved to the x-direction:
I used v= d/t with v= 6.38m/s
I got d= 11.87m
This answer is wrong however i don't know where i went wrong and what i should do to correct it. I didnt get a chance to move on to the other questions either. Any help would be appreciated.
Thanks
You mixed up the components of the initial velocity.
Welcome to PF, saralsaigh.
I think you may have the velocity components mixed up.
thanks
oops yea i see that now, thanks alot:blushing:
grrr...
ok so i switched my speed components around but i seem to still get a very close answer i got dx=11.86m which is wrong also... :grumpy: HELP!
Can you show how you worked out this equation d= v1t+0.5at^2 ?
ok
ok this is how i worked it out , i started with the y-direction and v1=6.38m/s, d=32.8, and a=-9.8 i subbed those into the equation and i got
4.9t^2 - 6.38t + 32.8 = 0 so i used the quadratic equation and i got t= 0.651seconds.
Then i used this time and plugged it into my x-direction and used the formula d=vt with my speed in the x-direction being 18.22m/s and i got an answer for dx= 11.86m.
Clearly i went wrong somewhere but i cannot point out my error...
I worked it out only now, and that equation does not have a solution in the reals.
Are you sure you typed the question correctly?
i think so, idk i used my calculator to get the answer, but here's how i set it up:
d=32.8m, v1= 6.38m/s (maybe this number should b negative since speed is down in the y-direction, wat do u think?) and a= -9.8m/s^2
so d=v1 t + .5 a t^2
32.8 = 6.38t + -4.9 t^2
then i used my calculator and it gave me t= 0.651s.
You've taken the positive y-direction to point up, therefore the y-component of the initial velocity is positive. It is the acceleration that points down, and hence negative.
yay i got the right answer, i was doing it wrong in terms of calculating time, i had to first calculate the time it took it to reach its max hight and then calculate the time it took from its max hight to reach the floor.
so for my y-direction my v1=6.38m/s, and v2= 0 and i know that a= -9.8m/s^2 so i used the equation a= (v2-v1)/t to calculate time and i got t=0.65s and then used the same information in this equation= (v1)^2 - (v2)^2 = 2ad to calculate distance and i got d= 2.08. so i added this distance to my given 1distance of 32.8 and used the equation d= 1/2 a t^2 to find out the time from my max hight to the floor and i found t=2.67. Therefore my total time is 3.32s. I used this time in my x-direction and i found out that dx = 60.49m which is the correct answer.
Thanks a lot for ur help guys :!)
Good work! :smile:
1. How do I calculate the time it takes for the car to hit the ground?
To calculate the time taken for an object to fall from a certain height, we can use the equation t = √(2h/g), where t is the time, h is the height, and g is the acceleration due to gravity (9.8 m/s²).
2. Can I ignore air resistance when solving this problem?
In most cases, air resistance can be ignored when solving problems involving objects falling from a height. This is because the force of air resistance is relatively small compared to the force of gravity.
3. How do I calculate the velocity of the car when it hits the ground?
To calculate the final velocity of the car when it hits the ground, we can use the equation vf = √(vi² + 2gh), where vf is the final velocity, vi is the initial velocity (which is 0 in this case), g is the acceleration due to gravity, and h is the height.
4. Can I use different units for height and acceleration in the equations?
No, it is important to use consistent units when using the equations for solving physics problems. In this case, the height should be in meters and the acceleration should be in meters per second squared.
5. Is there a specific method I should follow when solving this type of problem?
It is always helpful to start by identifying what is given and what is being asked for in the problem. Then, use the appropriate equations and plug in the values to solve for the unknown variable. Finally, double check your units and answer to ensure accuracy.
9K
