Did I Solve the Object Thrown Vertically Upwards Problem Correctly?
In summary, the conversation discusses a problem involving an object being thrown vertically upwards with a given speed and finding the time it takes to reach a point 25 meters below the starting point. The provided answer is 4 but the correct answer is 5. Upon further examination, an error was found and the correct solution was determined.
Darth Frodo
212
5. An object is thrown vertically upwards with a speed of 72 kilometres per hour. How long does it take to reach a point 25 meters below the starting point? You can take g as 10 ms-2 for convenience.
Here is my answer. I got 4 yet the answer is 5.
http://i.imgur.com/Ewvwh.jpg
http://i.imgur.com/ynVmM.jpg
http://i.imgur.com/OBVsX.jpg
Am I correct?
[IMG ]http://i.imgur.com/Ewvwh.jpg[/PLAIN]
[IMG ]http://i.imgur.com/ynVmM.jpg[/PLAIN]
[IMG ]http://i.imgur.com/OBVsX.jpg[/PLAIN]
Am I correct?
Please reduce the size of your images.
Ah, Nevermind error found
1. What is kinematics in 1D?
Kinematics in 1D is a branch of physics that deals with the study of motion in one dimension, typically along a straight line. It involves analyzing the position, velocity, and acceleration of an object in motion.
2. What is the difference between distance and displacement?
Distance is the total length covered by an object in motion, while displacement is the shortest distance between the initial and final position of the object. Displacement takes into account the direction of motion, while distance does not.
3. How is velocity different from speed?
Velocity is the rate of change of displacement with respect to time, while speed is the rate of change of distance with respect to time. Velocity also takes into account the direction of motion, while speed does not.
4. What is the difference between average and instantaneous acceleration?
Average acceleration is the change in velocity over a certain period of time, while instantaneous acceleration is the acceleration at a specific moment in time. Average acceleration is calculated by dividing the change in velocity by the change in time, while instantaneous acceleration is calculated using calculus.
5. How does mass affect an object's motion in 1D?
The mass of an object affects its motion in 1D by determining how much force is needed to accelerate the object. Objects with larger masses require more force to accelerate, while objects with smaller masses require less force. In 1D motion, mass also affects an object's inertia, or its resistance to changes in motion.
12K
12K
18K
