Kinematics motion - Given position, find velocity and acceleration
In summary, given a particle's position as a function of time, xf = xi . sin wt, where xi and w are constants, the expressions for velocity and acceleration can be found by differentiating the position function. The maximum values of velocity and acceleration can then be determined by setting the derivatives equal to zero and solving for t. The maximum velocity occurs at t = pi/2w, while the maximum acceleration occurs at t = 0.
negation
818
Kinematics motion -- Given position, find velocity and acceleration
A particle's position as a function of time is given by xf = xi . sin wt, where xi and w are constants.
a) Find expressions for velocity and acceleration.
b) What are the maximum values of velocity and acceleration.
xf = xi. sin(wt)
a) xf = xi. sin(wt)
velocity v = xf' = d/dt xi sin(wt) + xi d/dt sin(w.t) . d/dt w.t
xf' = xi cos(wt).w = xi.w.cos(wt)
acceleration = v' or xf " = [d/dtxi.w + xi d/dt w]cos(w.t) + xi.w d/dt (cos(w.t) . d/dt (w.t)
xf " = x dw/dt cos (wt) - xw^2 sin(w.t)
Can someone verify the above steps for me before I proceed to part (b)?
negation said:
xf " = x. dw/dt cos (wt) - x.w^2 sin (w.t)
Looks OK, but use the fact that ω is constant to simplify that expression. (Your notation is difficult to read. Consider using Latex in the future.)
Is it possible to simplify further?
On a tangent, how do I utilize Latex? Matlab?
On the advanced editor of physicsforums,you can use latex by pressing the top right button.
I just realized. But the nitty gritty details would have to wait.
Yes.
doc al said:
yes.
https://www.physicsforums.com/attachments/64882
dω/dt = ?
doc al said:
dω/dt = ?
Why do I have to express the equation as dω/dt?
Huh? Your expression for the acceleration contains dω/dt.
negation said:
That is incorrect. Your first post was correct, just not completed.
I believe I'm stuck. Even if ω were a constant, hasn't the equation been differentiated to it's second derivative? I could factor out some variables in the second derivative but I don't think that's what you were going at.
What do you mean "even if"? You are told that ω is a constant.
Answer this. What's the derivative of a constant?
Another hint: The point I am making is so trivial you will slap yourself once you realize it.
it's zero
y" = [d/dt(xw) + (x)d/dt(w)]cos(wt) + (xw) d/dt cos(wt) d/dt(wt)
dw/dt cos(wt) - (xw)sin(wt)w
dw/dt cos(wt) - xw^2 sin(wt)
Sent from iPhone
dw/dt cos (wt) - xw sin(wt)w
dw/dt =0
So,
y" = -xw^2 sin(wt)
Is the workings above correctly reduced?
I would suggest you that while calculating derivative of an function if you see any constant in that equation ,you can substitute 0 directly which makes your equation simple.
In your equations
substitute 0 in place of dw/dt of your acceleration equation .
negation said:
it's zero
Of course!
Keep going.
dw/dt =0
So,
y" = -xw^2 sin(wt)
Exactly.
Doc Al said:
Of course!Keep going.Exactly.
Part (b)
In find maximum velocity:
y' = xw cos (wt)
xw cos (wt) = 0
Cos(wt) = 0
Cos(pi/2) = 0 A cos(3pi/2) = 0
wt = pi/2
t = pi/2w
wt = 3pi/2
t = 3pi/2w
y"(pi/2w)= -xw^2 sin(wt)
= -xw^2 sin(pi/2)
= xw^2 < 0 local max
y"(3pi/2w) = -xw^2
= xw^2 > 0 local min
Max velocity occurs at t = pi/2wIn finding maximum acceleration:
To determine maximum acceleration, we first determine the rate of change of jerk.
Jerk is defined as the 3rd derivative of displacement with respect to time, t.
y'' = -xw^2 sin(wt)
y"' = [d/dt(-xw^2) + (-x)d/dt(w^2)] sin(wt) + (-xw^2) d/dt sin(wt) d/dt(wt)
= [0 + 0 ]sin(wt) - (xw^2) cos(wt)w
= -(xw^3)cos(wt)
y" = 0 = -xw^2 sin(wt)
-xw^2 sin(wt)= 0
sin(wt) = 0
sin(0) = 0 and sin(pi)= 0
wt = 0 and wt = pi
t = 0 and t = pi/w
y"'(0) = -xw^3 cos(w.0)
= -xw^3(1)
= -xw^3y"'(pi/w) = -xw^3 cos(w.pi/w)
= -xw^3 cos(pi)
= -xw^3(-1)
= xw^3
y"'(0) = -xw^3 < 0
local max
therefore, maximum acceleration occurs at t = 0
negation said:
Part (b)
y' = xw cos (wt)
xw cos (wt) = 0
Why are you setting that to zero?
Cos(wt) = 0
wt = pi/2
t = pi/2w
wt = 3pi/2
t = 3pi/2w
= -xw^2 sin(pi/2)
y"(3pi/2w) = -xw^2
No.
OK.
y'' = -xw^2 sin(wt)
= -(xw^3)cos(wt)
OK.
Why are you setting the acceleration = zero? You calculated the jerk, so use it!
-xw^2 sin(wt)= 0
sin(wt) = 0
wt = 0 and wt = pi
t = 0 and t = pi/w
= -xw^3(1)
= -xw^3
= -xw^3 cos(pi)
= -xw^3(-1)
= xw^3
y"'(0) = -xw^3 < 0
local max
No.
Try once more.
What was I thinking. I was rushing to type these.
Will retry
But in finding maximum velocity, shouldn't I find the derivative of velocity, which gives me acceleration, then set it to zero to determine the roots(max velocity implies y"(root)<0 )?
or are you implying that because I have derived the function for jerk, I should work on jerk instead?
In finding maximum velocity:
y''= 0 = -xw^2 sin (wt)
sin(wt) = 0 if sin(0) or sin(pi)
wt = 0
t = 0
and
wt = pi
t = pi/w
roots are t = 0 and t = pi/w
y'(0) = xw cos(wt) = xw cos(0) = xw
y''(pi/w) = xw cos(w. pi/w) = xw cos(pi) = -xw
max velocity occurs at t = 0
In finding max acceleration:
y''' = -xw^3 cos(wt) = 0
cos(wt) = 0 if cos(pi/2) and cos(3pi/2)
wt = pi/2
t = pi/2w
and
wt = 3pi/2
t = 3pi/2w
y''(pi/2w) = -xw^2 sin (w . pi/2w)
= -xw^2 sin (pi/2)
= -xw^2
y''(3pi/2w) = -xw^2 sin(w. 3pi/2w)
= -xw^2 sin(3pi/2)
xw^2
max acceleration occurs at t = 3pi/2w
That's what you should have done, but not what you did. You set the velocity equal to zero, not the acceleration.
Jerk can be used when calculating the maximum acceleration.
Is my workings now correct?
wt = 0
t = 0
and
wt = pi
t = pi/w
Good. Max velocity is ±xω. That occurs when ωt = 0, π, ...
wt = pi/2
t = pi/2w
and
wt = 3pi/2
t = 3pi/2w
= -xw^2 sin (pi/2)
= -xw^2
= -xw^2 sin(3pi/2)
xw^2
Good. Max acceleration is ±xω^2. That occurs when ωt = π/2, 3π/2, ...
Yes, much better! :thumbs:
1. What is kinematics motion?
Kinematics motion is the study of the movement of objects without considering the forces that cause the motion. It involves analyzing an object's position, velocity, and acceleration over time.
2. How do you calculate velocity in kinematics motion?
Velocity can be calculated by dividing the change in an object's position by the change in time. It is represented by the equation v = Δx/Δt, where v is velocity, Δx is the change in position, and Δt is the change in time.
3. What is acceleration in kinematics motion?
Acceleration is the rate of change of an object's velocity over time. It can be calculated by dividing the change in an object's velocity by the change in time. The equation for acceleration is a = Δv/Δt, where a is acceleration, Δv is the change in velocity, and Δt is the change in time.
4. How do you find an object's position using kinematics motion?
To find an object's position, you can use the equation x = x0 + v0t + 1/2at^2, where x is the final position, x0 is the initial position, v0 is the initial velocity, t is time, and a is acceleration. This equation is known as the kinematics equation for position.
5. Can kinematics motion be used for any type of motion?
Yes, kinematics motion can be used for any type of motion, as long as the forces causing the motion are not considered. It is particularly useful for studying the motion of objects in a straight line, such as objects moving along a horizontal or vertical path.
