Homework Help: Kinematics of a Particle
  1. Jan 3, 2010 #1
    Hello, I am currently revising for an exam later in the month, and was wondering if anyone could check my answers to this past examination question.
    Thanks in advance.
    The Displacement of a particle is given by x=20/3t3-23/2t2+6t+5 metres at time t. Determine:
    a) the velocity and acceleration when t=0 seconds,
    b) the velocity and acceleration when t=3 seconds,
    c) the value of t when the body is at rest,
    d) the value of t when the acceleration is 37 ms-2
    e) the distance travelled between t=2 seconds and t=3 seconds.
    2. Relevant equations
    d/dt(k.xt)=k.txt-1
    3. The attempt at a solution
    I got answers as follows:
    a) v=6 a=-23
    b) v=105 a=97
    c) 24.1 and 21.9
    d) 1.5
    e) 474
    Any help with checking these answers will be greatly appreciated.
    Thanks in advance
  3. Jan 3, 2010 #2
    Redbelly98
    Staff Emeritus
    (a) looks good.
    (b) double-check v. a looks good.
    . . . If you still get the same answer for v after trying again, please show your work.
    (c) and (d) if you provide the expressions for v and a, and the equations you set up to solve, it will be easier for me or somebody else to check your final answers.
    (e) I disagree. What values do you get for x at t=2 and t=3?
  4. Jan 3, 2010 #3
    Hello, hope your well and thanks for your response.
    For b) I got the same answer for v again. I just sub in t=3 to the velocity equation:
    20*32 - 23*3 + 6 = 180 -75 = 105m/s.
    For c) I said v=0 at rest so, 0 = 20t2 - 23t + 6 = 0
    and then used the quadractic formula to calculate t. Having done it again though, I got 28.02s and 17.98s this time
    For d) I said a=37, so 37 = 40t -23 which solves to give t = 1.5.
    For e) I got different answer again having done it again! I got x=2470.3m for t=2 and 99.5m for t=3. I then subtracted these to give a distance of 2370.8m
    In summary, My new answers are as follows:
    a) v=6, a =-23
    b) v=105, a=97
    c) 28.02 and 17.98
    d) 1.5
    e) 2370.8
    Thanks again for your input
  5. Jan 3, 2010 #4
    ideasrule
    -23*3+6 isn't -75; it's -63.
    Try it again. None of the answers you've given so far are right.
    That's right.
    99.5 m is right, but 2470.3 isn't. Try again. If you keep on making mistakes while punching numbers into your calculator, do it slowly or get a better calculator.
  6. Jan 4, 2010 #5
    Redbelly98
    Staff Emeritus
    Look up the quadratic formula again, especially the part where you divide everything by 2a. Also, what did you get for the quantity
    b2 - 4ac ?​
  7. Jan 4, 2010 #6
    Thanks ever so much for all your help. I Think I've got it now.
    I was making a few silly errors.
    For c) I wasn't dividing it all by 2a, just the bit in the square root!
    For e) For some reason when I got down to the 53.33 - 46 + 12 +5 I multiplied 53.33 and 46 and then added the 12 and 5 to give that answer of 2470! Think I'd been working too long last night!
    I think these answers are correct now (althougth wouldn't supprise me if they weren't lol!)
    a) v=6m/s, a=-23m/s^2
    b) 117m/s
    c) 1.37s
    d) 1.5s
    e) 75.17m
    Thanks again for eveyone's help
