Kinematics of Falling Object
In summary, the conversation discusses a problem involving an object falling through a medium with drag force proportional to its velocity. The equations F=ma, F=KV, and a=dV/dt are used to solve the problem. The correct solution involves solving a first-order linear differential equation and using initial conditions to determine the final formula for velocity in terms of time. The conversation also includes a discussion on the importance of including all necessary variables and correctly solving for the integrating constant.
First, let me preface this question that I have been out of academia for about 5 years now, and am just starting to get back into it, although it seems my Calc/Kinematics is a little rusty.
b]1. Homework Statement [/b]
An object of weight W is falling through a medium such that the object's drag force is proportional to its velocity. Express the velocity in terms of time if the initial velocity of the object is zero.
F=ma
F=KV
a=dV/dt
Ok, so just from the problem statement alone, I know we have an object on which two forces are acting; the weight of the object due to gravity and the drag force on the object.
Fnet = mg - KV
Since g is always a constant, it's the acceleration of the drag force we are trying to solve for, correct? Since F=KV, and F=ma, by association we have ma=KV, or a=KV/m, so now we have a function of acceleration in terms of velocity. If we plug this into a=dV/dt, we end up with:
KV/m = dV/dt
or
dt = (m/KV)dV
Integrating both sides, we end up with:
[itex]\int[/itex]dt = (m/K)[itex]\int[/itex](1/V)dV or t = (m/K)ln(V)+C
Now if we solve for V in terms of t we get:
ln(V) = (tK/m)-C or V = e^[(tk/m)-C]
So this is as far as I have been able to get with this problem, because when you plug in initial velocity to solve for C, you get 0 = e^(0-C), but e^x is undefined when x = 0.
Am I making a wrong assumption at the beginning of the problem? I've got about 6 pages of scratch work and I feel this is the closest I've gotten to the actual solution. Any advice would be helpful. Thanks in advance.
sn0wxboarder said:
F
F=ma
F=KV
a=dV/dt
Fnet = mg - KV
NO. The body has acceleration, not the force. The acceleration caused by the individual forces add up. The acceleration of the body is proportional to the total force Fnet. Fnet=ma. As a = dv/dt,
m (dv/dt ) = mg -Kv.
This is a first-order linear differential equation, solve for v(t). You can solve it by separation of the variables.
ehild
The relevant equations should be
Ft = ma = W - kV
W = mg
a = dV/dt
m dV/dt = mg - kV (1)
This differential equation has an easy to guess special solution
V = mg/k = const.
The homogeneous equation for the one above is
m dV/dt = -kV (2)
Note that it is similar to yours but the sign. So the solution to (2) is
V = e^(-k/m t + C) = Vo e^(-k/m t)
(BTW. e^0 = 1)
Now you have a special solution to the equation (1), and a general solution to the homogeneous equation. The general solution to (1) is the sum of above
V = mg/k + Vo e^(-k/m t)
Vo may be found remembering that the initial velocity was zero.
0 = mg/k + Vo e^0
Vo = -mg/k
The velocity of the falling object is given by
V = mg/k(1 - e^(-k/m t))
Make a graph of it to see what it means.
ehild
Ok, so here's my best attempt at this:
m(dv/dt)=mg-KV
dv/dt=g-KV/m
1/(g-KV/m)dv=dt (1)
Now from here we can use u-substitution:
u=g-KV/m
du/dv=-K/m or dv=(-m/K)du
Subbing this into equation 1:
(-m/K)(1/u)du=dt or (1/u)du=(-K/m)dt
Now integrate both sides:
ln(u) = (-K/m)(t+C)
e^(ln(u))=e^((-Kt/m)+(KC/m)) or u=e^((-Kt/m)+(KC/m))
Now we sub back in for u, and solve for V:
g-(KV/m)=e^((-Kt/m)+(KC/m))
(KV/m)=g-e^((-Kt/m)+(KC/m))
V=(m/K)(g-e^((-Kt/m)+(KC/m))
Now this is very similar to Andrzej's answer, but somehow he had an additional "g" before his exponential, so he could pull out the term (mg/K). What did I miss that include that? With the included "g", you can use initial conditions to solve for your constant of integration and determine your final formula for V in terms of t.
e^((-Kt/m)+(KC/m))= e^(-Kt/m)*e^(KC/m). Find the constant C from the initial condition(v(0)=0. You will find that e^KC/m =g.
ehild
The reason is, you haven't got the final answer yet, as your formula still has an integrating constant C.
Note that exponential function has a following feature
e^a e^b = e^(a+b).
Find the value of C in your function remembering that for
t = 0
velocity was also zero
V(0) = 0.
I understand now, thanks so much guys, you rock.
Suggested for: Kinematics of Falling Object
