Kinematics: falling stone question
In summary: You should make sure you understand the concept of finding the impact velocity, as it is used throughout physics.
AStupidHippo
While standing at the edge of the roof of a building, you throw a stone upward with an initial speed of 6.91 m/s. The stone subsequently falls to the ground, which is 16.5 m below the point where the stone leaves your hand. At what speed does the stone impact the ground? How much time is the stone in the air? Ignore air resistance and take g = 9.81 m/s2.
I solved for impact velocity fairly easily. v=19.2 m/s
I'm having trouble with finding time. I have to use an online HW submitter (Sapling Learning), but it keeps saying I'm wrong.
v^2 = u^2 +2as
v=u+at
[/B]
19.2 = 6.91 + 9.81(t)
12.29=9.81(t)
t=1.25 seconds
Apparently this is wrong: http://prntscr.com/cdptl8
Greetings.
Could you show how you come up with t = 1.25s?
I tried the problem myself, and I do get a different answer, using your formula: v = v0 + at
You have to make the formula be based on t instead, which gives you: t = (v - v0) / a
Now I did the calculation twice: once for figuring out the air-time the stone uses to the top of the upward throw, and one for calculating the amount of time the stone takes from the top of the throw all the way to the bottom.
The first calculation has v0 = 6.91
The second calculation has v0 = 0
In the first calculation, a will be negative (assuming we've set a positive direction upwards)
In the second calculation, a will be positive.
This gives you two numbers you should be able to add together to see the total amount of air time. There's probably a better method of doing this in one calculation.
Hans Herland said:
Greetings.
Hi!
So this is what I did: (Impact velocity - initial velocity)/a = t
(19.2-6.91)/9.81=t
This gave me t=1.25
AStupidHippo said:
Hi!
(19.2-6.91)/9.81=t
This gave me t=1.25
This should give you the time it would take for the stone to drop if it was thrown directly towards the ground. Since the stone is thrown upwards, you'll need to find the time it takes for the stone to travel with initial velocity of 6.91, to impact velocity of 0 (where the stone starts dropping).
Ok. So I should make v= 0 and solve for time with this: 0=6.91-9.81t
t=.7
And then I add it it to 1.25? So the answer is 1.25+.7= 1.95
t=.7
You should re-check the 1.25 number, since that's still based on the time it would have taken for the stone to drop at the height it was thrown in. Remember that it now drops from a higher altitude, making the drop longer than before, and the initial velocity of the drop is 0.
Since the stone was thrown up into the air, it accelerated downwards due to gravity, making it slow down and eventually "stop". When this happens, the stones velocity starts accelerating again, but this time the velocity also points downwards.
I got 0.7 seconds as well when calculating the time it takes for the stone to reach the top of the throw.
Likes AStupidHippo
Yes. It's 1.25+.7+.7=2.6. This is the correct answer. Thank you!
Likes Hans Herland
Alternatively you could use the v=vo +at formula, but have v0 be negative, because at the bottom you are moving the oppositve way of the intitial throw. If you have movement in two different different directions one of the values has to be negative.
Likes AStupidHippo
Indeed, this is the correct way to solve the problem. Since acceleration is constant throughout, it is quite unnecessary to break it into separate upward and downward stages.
Likes AStupidHippo
how did you find the impact velocity?
Likes Delta2
See the relevant equations in post #1.
I think OP's original solution was fine - just need to be careful not to round off answers too early.
As in post #1? The correct answer is given in post #7.
Apologies. Had OP used -6.91 as initial velocity instead of 6.91, the approach would have been correct. Although he should probably use the non-rounded answer to the first part (impact velocity). Or at least maintain all calculations correct to 2 dp consistent with g=9.81 m/s^2.
As you've said there was no real need to break the time problem into two parts but many students seem to prefer doing things that way.
One could also use ## v_{av}Δt=16.5## where ##v_{av}=\frac{-6.91+19.27}{2}##
What is kinematics?
Kinematics is a branch of physics that studies the motion of objects without considering the forces that cause the motion. It focuses on describing the position, velocity, and acceleration of an object in a given time frame.
What is the falling stone question?
The falling stone question is a classic kinematics problem where an object is dropped from a certain height and the goal is to calculate its position, velocity, and acceleration at different points in time.
How do you solve the falling stone question?
To solve the falling stone question, you can use the equations of motion, which include the initial position, velocity, acceleration, and time. These equations are:
- Position (s) = initial position (s0) + initial velocity (v0) * time (t) + 0.5 * acceleration (a) * time (t)^2
- Velocity (v) = initial velocity (v0) + acceleration (a) * time (t)
- Acceleration (a) = (final velocity (v) - initial velocity (v0)) / time (t)
- Time (t) = (final velocity (v) - initial velocity (v0)) / acceleration (a)
You can also use a position-time or velocity-time graph to visually solve the problem.
What factors affect the motion of a falling stone?
The motion of a falling stone is affected by various factors, including the initial height of the stone, the gravitational force, the air resistance, and the mass of the stone. These factors can impact the stone's position, velocity, and acceleration at different points in time.
What are some real-life applications of the falling stone question?
The falling stone question has practical applications in fields such as engineering, sports, and transportation. For example, engineers can use this problem to calculate the trajectory of a falling object and design structures to withstand the impact. In sports, understanding the falling stone question can help athletes improve their performance in events such as long jump or diving. In transportation, this problem can be used to calculate the distance and time needed for an object to fall from a certain height, which can be useful in designing safety measures for vehicles.
