Kinematics: Object Thrown Up from 3.6m Window
In summary, an object is thrown vertically up from a window 3.6m above the ground with an initial speed of 2.8m/s. The time it takes to ascend is equal to the time it takes to descend. The acceleration of the object is g down and can be calculated using the formula v0 = g*t. The height traveled up can be calculated using the formula h = v0*t - 1/2*g*t^2, while the height traveled down can be calculated using the formula h+h0 = 1/2*g*t^2. In a graphical representation, the parabola representing the object's motion will be upside down, with the x coordinate representing time, the y coordinate representing height
ryan8642
24
1. an object is thrown vertically up from a window that is 3.6m above the ground.
Its initial speed is 2.8m/s.
N/a
Is the time the object takes to ascend equal to the amount of time it takes to descend?
The acceleration of the oobject will be g down.
now you can calculate the time spent to go up, because v0 = g*t
the height traveled up: h=v0*t - 1/2*g*t^2
now down: h+h0 = 1/2*g*t^2
To look at it in a graphical way:
draw a parabola upside down. x coordinate is the time, y is the height, the steepnes of the parabola is the speed. Move the parabola such that
- it is raising at x=0 : the initial speed is positive
- it is positive at x=0: initially it is in up in the window
Now note whether the y distance of the top of the parabola form the origo (time spent up) is equivalent to the y distance from the top of the parabola to where it cuts the horizontal axis (time spent down).
What is kinematics?
Kinematics is the study of motion, including the position, velocity, and acceleration of objects, without considering the forces that cause the motion.
What is the initial velocity of an object thrown up from a 3.6m window?
The initial velocity of an object thrown up from a 3.6m window is 0 m/s. This is because the object starts at rest and has no initial velocity in the upward direction.
What is the acceleration of an object thrown up from a 3.6m window?
The acceleration of an object thrown up from a 3.6m window is -9.8 m/s^2, assuming no air resistance. This is due to the force of gravity acting on the object, causing it to accelerate downwards.
How long does it take for an object thrown up from a 3.6m window to reach its maximum height?
The time it takes for an object thrown up from a 3.6m window to reach its maximum height can be calculated using the formula t = √(2h/g), where t is the time, h is the initial height (3.6m in this case), and g is the acceleration due to gravity (9.8 m/s^2). Therefore, it would take approximately 0.85 seconds for the object to reach its maximum height.
What is the maximum height reached by an object thrown up from a 3.6m window?
The maximum height reached by an object thrown up from a 3.6m window can be calculated using the formula h = (v^2)/2g, where h is the maximum height, v is the initial velocity (0 m/s in this case), and g is the acceleration due to gravity (9.8 m/s^2). Therefore, the maximum height reached would be approximately 0.66 meters.
