Homework Help: Kinematics with 2 objects
  1. Feb 12, 2012 #1
    Emily and Grace are each in a bumper car facing each other 10m apart. Emily moves toward Grace at a constant speed of 2.5 m/s. Grace accelerates toward Emily at a rate of 0.5 m/s^2. Relative to where Emily started, where do the two bumper cars collide?
    2. Relevant equations
    x=V[itex]_{}0[/itex]t+1/2at^2
    x-x[itex]_{}1[/itex]=V[itex]_{}0[/itex]t+1/2at^2
    3. The attempt at a solution
    Grace
    x=1/2at^2
    x=(.5)(.5)t^2
    x=.25t^2
    Emily
    x-10=2.5(t)
    (.25t^2)-10=2.5(t)
    .25t^2-2.5t-10=0
    t=13.06, -3.06
    x=.25(-3.06)^2
    x=2.34
    Can someone tell me if I did this correctly?
  3. Feb 12, 2012 #2
    Look at your result. Emily has an initial speed of 2.5 m/s. Grace starts from 0 speed. Your answer implies Grace went a greater distance......
  4. Feb 12, 2012 #3
    I would have written the second equation as 10-x=2.5(t)
  5. Feb 12, 2012 #4
    Well, if you write the second equation that way it doesn't change the answers you will get because you square them.
  6. Feb 12, 2012 #5
    But it is wrong the way you have it written. The ends don't justify the means. You want the sum of the distances moved by both to be 10 m. So you could write:
    2.5t + .5at^2 = 10
    If you add your two equations, you do not get the above.
    The distance 2.34 m is the distance from Grace's original position. Question asks for point of impact from Emily's original position.
  7. Feb 12, 2012 #6
    So, if 2.34 is the distance from Grace wouldn't 10-2.34 be the answer I am looking for?
  8. Feb 12, 2012 #7
  9. Feb 12, 2012 #8
    Okay thanks, but is there a way to set up the problem so that the x calculated is from Emily's position?
  10. Feb 12, 2012 #9
    Sure, take the equation
    2.5t + .5at^2 = 10
    and solve for t just as before.
    Then apply the time to
    Xe = Ve * t = 2.5 * t, t=3.06 sec
    which gives how far Emily moved from her initial position.
