Kinetic energy and elastic collision question
In summary, the conversation was about finding the change in Kinetic Energy during an elastic collision. The individual had the mass and initial and final velocities of objects A and B, and was trying to use the formula .5(mA + mB)(velocity)^2 to calculate the change in KE. However, they were unsure about how to combine the initial and final velocities and whether or not to add the masses together. They were eventually guided to use the formula KE = .5mv^2 and add the initial KEs of objects A and B together with the final KEs. The conversation also included a discussion about the rules of the forum and finding solutions on one's own.
klm
165
okay i have a problem that deals with an elastic collision. so i have the mass of obj A and B and i found the initial velocity of A and B, and i have the final velocity of A and B
so now i want to find the change in Kinetic Energy, so i am doing
.5(mA + mB)( velocity final ^2) - .5(mA + mB)( velocity initial^2)
but what i am confused about is what i am suppose to use for the final velocity and initial velocity. i mean do i just add if initial velocities of obj A and B and use that as Vi, and add up the final velocities of obj A and B and use that as Vf? i don't think that seems right? any help would be great!
check your equations again they, as are incorrect.
the change in KE = .5mVf^2 - .5mVi^2 . is that incorrect?
no but the way you combined the mass was. the masses are different objects. KE1 + KE2
i am sorry i don't understand what you mean. i cannot combine the masses to make
.5 ( mA+mB) vf^2 ? how come?
you have 2 different velocities, do you not?
yes i have 2 diff initial velocity for A and B and 2 diff final velocities for A and B
what is the KE of an object?
.5mv^2
so what do you get when you add the KE of 2 objects?
i don't know?
why don't you try adding the KE's and see what happens?
i can't add the KE's b/c i don't know how to use the velocity in the equations. i know i need to use the final and initial, but my only problem is that i have 2 intials and 2 finals. and i don't know how to use that. i don't have a problem to solve, i am just asking because this is a concept i am getting stuck on.
how do you add one plus two? now add KE1 plus KE2. the final KE equals the initial KE. does your text have examples? i can assure you if it does that there is a problem like this one.
ok thank you for your help. i will go look for an example
i'm sorry but the general rules on this forum are to help people arrive at their own solutions. it is clear from your approach that you never learned the material or otherwise never remembered it. perhaps paying attention or reading your book will help. if you'd rather not do those two, i hear wikipedia has all the answers.
To find the change in KE you use the formula KE = .5mv^2
so the KEi (initial) is .5*m,a*vi,a^2 + .5*m,b*vf,b^2
you do KE,f the same way but with the final velocities
then you do KEf - KEi
does this answer your question?
thank you moncheri. i did not think you were allowed to do this way because i thought you needed to keep the initial velocities separate from the final velocities. i am confused because how can you put the final velocity of b, with the initial velocity of a like you did. thank you for responding!
and fliinghier- yes i am aware of the general rules of this board. i am not asking you to give me an answer to a problem, i am asking for help to understand an equation. thank you though
i don't understand why youre confused - i kept the initial velocities separate .. you have to add the KEi of a with the KEi of b .. because before the collision the two objects a and b are seperate, correct? If they're together that's a different story - maybe I don't understand?
Well, I thought anyway that during an elastic collision KE is conserved. Right?
no no sorry i am confusing you! you are right, the two objects are separate before and after the collision.
to klm: I'm sorry if i made it difficult on you. i was trying to get an answer along the lines of KE1 + KE2 out of you. here's what you do:
KE1i + KE2i =KE1f +KE2f
i think i understand how to do it. thank you for all your help :)
thank you fliinghier. i wasn't sure what the rules were and if you could just add things together like that. thank you for explaining!
What is Kinetic Energy?
Kinetic energy is the energy an object possesses due to its motion. It is defined as the work needed to accelerate a body of a given mass from rest to its current velocity.
How is Kinetic Energy Calculated?
Kinetic energy is calculated using the formula KE = 1/2 * m * v^2, where m is the mass of the object and v is its velocity.
What is an Elastic Collision?
An elastic collision is a type of collision between two objects where both kinetic energy and momentum are conserved. This means that the total kinetic energy and total momentum before and after the collision remain the same.
How is the Kinetic Energy in an Elastic Collision Calculated?
In an elastic collision, the kinetic energy of the two objects after the collision can be calculated using the formula KE = 1/2 * m1 * v1^2 + 1/2 * m2 * v2^2, where m1 and m2 are the masses of the two objects and v1 and v2 are their velocities after the collision.
What Factors Affect the Kinetic Energy in an Elastic Collision?
The kinetic energy in an elastic collision is affected by the masses and velocities of the two objects involved. A larger mass or higher velocity will result in a higher kinetic energy after the collision.
