1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Kinetic Energy and Velocity
  1. Feb 19, 2008 #1
    [SOLVED] Kinetic Energy and Velocity
    The gravitational pull of the earth on an object is inversely proportional to the square of the distance of the object from the center of the earth. At the earth's surface this force is equal to the object's normal weight mg, where g=9.8, and at large distances, the force is zero.
    a) If a 50000kg asteroid falls to earth from a very great distance away, how much kinetic energy will it impart to our planet? You can ignore the effects of the earth's atmosphere.
    Express your answer using two significant figures.
    b) What will be its minimum speed as it strikes the earth's surface?
    2. Relevant equations
    Wtot = 1/2m(v2)^2-1/2m(v1)^2
    Wgrav = mg
    3. The attempt at a solution
    a) W = mg = (50000kg)(9.8m/s^2) = 4.9 x 10^5 J (wrong)
    b) W = 1/2mv^2, v = [tex]\sqrt{2W/m}[/tex] = 4.4 (definetly wrong)
    as you can see I tried using the work energy theorem with the given data, but nothing was right, any help is appreciated.
  3. Feb 19, 2008 #2
    Doc Al
    Staff: Mentor
    W = mg is a formula for the weight of something near the earth's surface (not work).
    Hint: Look up the gravitational PE between two bodies as a function of distance.
  4. Feb 19, 2008 #3
    but no distance was given, I know Ugrav = mgd, d being distance...
  5. Feb 19, 2008 #4
    Doc Al
    Staff: Mentor
    Ug = mgd only applies near the earth's surface, which is not the case here. Look for another version of a gravitational PE formula.
  6. Feb 19, 2008 #5
    so I guess you're talking about the gravitational PE formula where the force approaches zero:
    U = -GMm/r
    but no distance is given so I can't find a radius, I'm assuming you're using:
    Ugrav + Wtot = K
    but I don't understand how I can get it without a given distance so I can find a radius for the potential energy, do I use the radius of the earth?
    edit: so apparently -GMm/r = -1/2mv^2, but again I'm stumped about the radius.
  7. Feb 19, 2008 #6
    tried it with the earth's radius and got the answer for part a)
    GMM/r_earth = K = 3.1x10^12 J w00t!
    now for part b)
    would it be [tex]\sqrt{2K/m}[/tex]?
  8. Feb 19, 2008 #7
    lol, I'm answering all my own questions.
    it is what I just posted above, thanks to Doc Al for pointing me in the right direction with the proper formula.
  9. Feb 19, 2008 #8
    Doc Al
    Staff: Mentor
    Good work!
  10. Feb 25, 2008 #9
    can anyone summarize how to solve this problem, i do not understand how to use this formula GMm/r
    what is G,? 9.8?, does it give you potential energy of the object? doesnt the question ask for kinetic?
    thanks for the help
  11. Feb 26, 2008 #10
    Doc Al
    Staff: Mentor
    G is the universal gravitational constant, which appears in Newton's law of gravity. Since mechanical energy is conserved, knowing the change in gravitational potential energy allows you to calculate the change in kinetic energy. Read: http://hyperphysics.phy-astr.gsu.edu/Hbase/gpot.html#ufm"
  12. Feb 26, 2008 #11
    Use conservation of energy. At very large distances, the asteroid has zero potential energy. We can see this is true because U = k/r (k is a constant), so as r tends to infinity, U tends to zero, so very large r we can neglect U (gravitational energy). Then it becomes trivial to solve using conservation of energy. It starts with at least zero kinetic energy.
Similar Threads - Kinetic Energy Velocity Date
Understanding Drag Force against a non-linear Force Jun 26, 2017
Kinetic Energy and Velocity Apr 13, 2017
Need help finding energy for escape velocity Mar 29, 2017
