Kinetic energy of a sled question
In summary, when a package of equal mass is dropped onto a coasting sled on an icy surface of a frozen river, the kinetic energy of the sled plus the added load is 1/2 the original kinetic energy of the sled. This can be determined by using conservation of linear momentum and comparing the kinetic energy before and after the impact.
hey123a
37
A sled of mass m is coasting on the icy surface of a frozen river. While it is passing under a bridge, a package of equal mass m is dropped straight down and lands on the sled (without causing any damage). The sled plus the added load then continue along the original line of motion. How does the kinetic energy of the (sled + load) compare with the original kinetic energy of the sled? A) It is 1/4 the original kinetic energy of the sled. B) It is 1/2 the original kinetic energy of the sled. C) It is 3/4 the original kinetic energy of the sled. D) It is the same as the original kinetic energy of the sled. E) It is twice the original kinetic energy of the sled.
kinetic energy intial = 1/2mv^2
kinetic energy after = 1/2(2m)v^2 = mv^2
comparing the kinetic energy before and after, i get the after is twice the original kinetic energy of the sled but apparently this is wrong
You forgot to conserve momentum.
You will need to use conservation of linear momentum to calculate the velocity of the sled+load after the impact as your attempt shows them traveling at the same velocity.
If before the impact, the sled has momentum mu and after it travels with the velocity 'v' and the load is initially at rest, then using conservation of linear momentum what is v in terms of u?
ah okay i think i got it
m1v1o + m2v2o = (m1+m2)vf
where m1 is the sled, and m2 a mass that is equal to the sled
m1v1o = (m1+m2)vf
m1v1o = 2mvf
m1v1o/2m = vf
v1o/2 = vf
original ke = 1/2mv^2
KE of sled + load = 1/2(2m)(v1o/2)^2
ke of sled + load = 1/2(2m)(v^2/4 = 1/4mv^2, which is 1/2 the original kinetic energy of the sled
Well done.
It's easier to check your answers if you get formal with the working.
for instance, if I write:
before:
momentum: ##p_i=mu##
kinetic energy: ##K_i=\frac{1}{2}mu^2##
after:
momentum: ##p_f=2mv##
kinetic energy: ##K_f = mv^2##
conservation of momentum:
##p_f=p_i\implies 2mv=mu \implies v=u/2\\ \qquad \implies K_f=\frac{1}{4}mu^2##
Comparing KE "after" with KE "before":
$$\frac{K_f}{K_i}=\frac{\frac{1}{4}mu^2}{\frac{1}{2}mu^2}=\frac{1}{2} \\ \qquad\implies K_f=\frac{1}{2}K_i$$
You can see all the steps and most of the reasoning.
Good for long answers or when you are practicing (or writing questions here ;) ) - but probably more work than you'd like for a simple multi-choice.
Still... no worries aye?
1. What is kinetic energy?
Kinetic energy is the energy that an object possesses due to its motion.
2. How is kinetic energy calculated?
Kinetic energy is calculated using the formula KE = 1/2 * m * v^2, where m is the mass of the object and v is its velocity.
3. What factors affect the kinetic energy of a sled?
The kinetic energy of a sled is affected by its mass and velocity. The heavier the sled and the faster it is moving, the more kinetic energy it has.
4. What is the relationship between kinetic energy and work?
Kinetic energy and work are directly related. Work is the transfer of energy to an object, and when work is done on an object, its kinetic energy increases.
5. How does friction affect the kinetic energy of a sled?
Friction acts in the opposite direction of motion, so it decreases the kinetic energy of a sled. This is why it is harder to move a sled over rough or uneven surfaces.
