Kinetic Energy of 0.2 kg Ball with 20 m/s Velocity
In summary, the kinetic energy of the ball at the top of its path can be calculated using the formula KE = ½mv², but since the ball is thrown at an angle, the velocity must be resolved into horizontal and vertical components. At the top of its flight, the vertical component is 0, so only the horizontal component needs to be considered. This is why the formula used is KE = ½mvH².
pkossak
52
I realize this problem is like ridiculously easy, but I just don't understand why you get the answer this way.
A 0.2 kg ball is thrown with an initial velocity of 20 m/s at an angle of 30 degrees with respect to the horizontal. What is the kinetic energy of the ball at the top of it's path?
I don't understand why in order to get the answer, you have to use the horizontal velocity componenent, Vx. Shouldn't you just use the velocity as given, and plug it into .5mv^2? Thanks
KE = ½mv², where v is the velocity of the ball.
After projection, the ball's velocity can be resolved into horizontal and vertical components. So it's KE at any particular time is,
[tex]KE = \frac{1}{2}mv_H^2 + \frac{1}{2}mv_V^2[/tex]
But at the top of it's flight, [tex]v_V = 0[/tex]. so only the horizontal velocity needs to be considered.
great explanation
u must take note that you are projecting the object at an angle of 30 degrees not vertically upwards. Thus, there is velocity also in the horizontal component. Since there is velocity in the horizontal component, there must also be KE in the direction also.
[tex]K=(1/2) mv^2[/tex]
Here, v is the speed. That is:
[tex]v = \sqrt{{v_H}^2 + {v_V}^2}[/tex]
where [itex]v_H[/itex] is the horizontal component of the velocity, and [itex]v_V[/itex] is the vertical component.
Plugging this into the formula for kinetic energy, we get Fermat's result (above):
[tex]K = (1/2) m ({v_H}^2 + {v_V}^2) = (1/2) m{v_H}^2 + (1/2)m{v_V}^2[/tex]
In this particular example, at the top of the flight, we have:
[tex]v_H = 20\cos 30\deg[/tex]
[tex]v_V = 0[/tex]
1. What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion.
2. How is kinetic energy calculated?
Kinetic energy is calculated by multiplying the mass of an object by the square of its velocity, and then dividing by 2. In this case, the calculation would be (0.2 kg)*(20 m/s)^2 / 2 = 40 J.
3. Why is the mass of the ball important in determining its kinetic energy?
The mass of an object is a crucial factor in determining its kinetic energy because it directly affects the amount of force it can exert due to its motion. In this case, a heavier ball with the same velocity would have a higher kinetic energy than a lighter ball.
4. How does the velocity of the ball affect its kinetic energy?
The velocity of an object is directly proportional to its kinetic energy. This means that as the velocity increases, so does the kinetic energy. In this case, a ball with a velocity of 30 m/s would have a higher kinetic energy than one with a velocity of 20 m/s.
5. Can kinetic energy be converted into other forms of energy?
Yes, kinetic energy can be converted into other forms of energy, such as potential energy or thermal energy. For example, when the ball comes to a stop, its kinetic energy is converted into potential energy as it gains height due to gravity. Friction also converts some of the kinetic energy into thermal energy as the ball rolls on a surface.
