• Support PF! Buy your school textbooks, materials and every day products Here!
Kirchoff's Circuit Law
  • Thread starter yaro99
1. Homework Statement
Determine the values of the other currents in Figure P1.37, given that ia = 2 A, ic =−3 A,
ig = 6A,and ih= 1A.
2. Homework Equations
∑currents entering a node = ∑currents exiting the node
3. The Attempt at a Solution
I used Kirchoff's Circuit Law on each of the outer nodes:
if = ig + ih = 6 + 1 = 7A
ia + id = if
2 + id = 7
id = 5A
ic + ih= ie
-3 + 1 = ie
ie = -2A
ib = ia + ic = 2 - 3 = -1A
I think I may have went wrong somewhere, because when I apply KCL to one of the inner nodes I get this:
ie + ig = id (?)
-2 + 6 ≠ 5
Answers and Replies
gneill
Mentor
20,537
2,627
ig = 6A,and ih= 1A.
ia + id = if
2 + id = 7
id = 5A
ic + ih= ie
-3 + 1 = ie
ie = -2A
ie + ig = id (?)
-2 + 6 ≠ 5
There's only one "inner node" where B, D, G, and E meet; despite there being two connection dots there, they are all one single conducting path with no components in between.
So, your node equation needs to account for ##i_b##, too.
73
Aha, in that case it will be
-2 + 6 = -1 + 5
4 = 4
How do I know that the node includes ##i_b##, is that current not affected by the current ##i_d##?
Is the point connecting B and D not a node?
Simon Bridge
17,822
1,639
The two inner nodes are actually one node.
You missed a current: two currents go into the node and two currents go out of the node.
[edit]gah: too slow!
gneill
Mentor
20,537
2,627
So long as there is a continuous conducting path it is all one node. A node is not a dot on the diagram, it's the entire continuous conducting path.
To make it more clear, you can shift component E over a bit as follows:
The wiring in green is continuously connected, so it's all one node.
Ah, yes that confused me a bit. It makes sense now thanks!
Simon Bridge
17,822
1,639
Great - the other way to look at it is to add an extra current arrow ##\small{i_0}## in the gap between the "two" center nodes. You can tell which direction it has to point in by looking at the other currents - but it actually doesn't matter:
Current in = current out:
... so on the left node you get ##i_0 = i_b+i_d##
... and for the right node you get ##i_0=i_g+i_e##
... eliminate the ##\small{i_0}## term gives you ##i_b+i_d = i_g+i_e##
and it all comes out in the wash ;)
It's just easier to realize that the nodes for Kirkoffs laws actually include the entire wire between components. Thus two drawn node-symbols, on the diagram, that have no components between them, are one and the same.
Related Threads for: Kirchoff's Circuit Law
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
