Kirchoff's Law Problem
  • Thread starter Yosty22
Yosty22
185
In the following figure(Figure 1) the battery has emf 26.0V and negligible internal resistance. R1 = 4.10Ω . The current through R1 is 1.50A and the current through R3 = 5.00A
What are the resistances of R2 and R3?
(Image Attached)
Kirchoff's Loop/Junction Rule
I am having some real problems with Kirchoff's Rules. Can someone help me figure out how to begin? I started out by saying that Since the current through R3 is 5A, then that is the same as the current that gets split at the junction into I_1 through R_1 and I_2 through R_2. Also, I know that the voltage drop across R_1 is equal to the voltage drop across R_2 which is 6.15V. Using this, I said that (R_2)(I_2)=6.15V. I was given I_1 (the current through R_1) and I believe the current that enters the junction is the 5A that were given in the problem that go through R_3. Using that, I said that I_2 + I_1 = 5A. Knowing I_1, I found that I_2 should be .9A, which would make R2=6.833 Ohms. I don't know if this is right. Even if it is, how do I go about solving for R_3? I am very confused. Any help would be great.
Answers and Replies
phinds
Insights Author
2021 Award
17,802
9,862
... I was given I_1 (the current through R_1) and I believe the current that enters the junction is the 5A that were given in the problem that go through R_3. Using that, I said that I_2 + I_1 = 5A. Knowing I_1, I found that I_2 should be .9A,
Uh ... you might want to take a remedial course in arithmetic here :smile:
I mean, .9 + 1.5 = 5.0 ???
Yosty22
185
Oh woops, I didn't see that. So in that case, I_2 = 3.5A, not 0.9. so the voltage drop across R_2 is the same as that across R_1, which I know is 6.15V. Therefore (3.5A)(R_2)=6.15V. Is this correct?
7,693
Yeah that seems right. You got that from the loop thru the battery right?
i1*r1 + i3*r3 - 26 = 0 with i1*r1 = (1.5)(4.1) = 6.15 V and since you know i2=3.5A ...
ALso you should still read the wiki article as it mentions the restrictions on K's laws for AC circuits and when magnetic fields are present.
Yosty22
185
Ok, thank you. So that would make R_2 = 1.757 Ohms. So how would I go about finding R_3? I already know the current through there, but what do I do about the EMF? Should I find the equivalent resistance of the top loop, then write another equation using Kirchoff's Law around the whole outer loop? So find R_eq for R_1 and R_2, then have I(R_eq)+I_3R_3-EMF=0? However, if I find R_eq, would the voltage drop be the same as each individual one, allowing me to solve for the current that would flow through R_eq?
7,693
whats the voltage drop across R3? you were able to determine the voltage drop across R1 and R2.
Yosty22
185
That is what I am unsure how to find. Would I have to find the equivalent resistance for R1 and R2 and then write another equation since I know the current through R3 already?
7,693
Doesn't the problem say the voltage source is 26V and you know its 6.16V across the R1/R2 piece so now what is it across the R3?
Yosty22
185
Is it just 26-6.16?
Yosty22
185
Im pretty sure it is, but I cannot think of why that would be. Any insight?
7,693
Look at K voltage law again, what does it say about summing voltages in a loop?
Yosty22
185
Ahh, so the emf + the voltage on each resistor has to add up to 0. Then once I solve for the voltage of R3, I know the current, so I can find the resistance. Is that correct in my thinking?
7,693
Yes.
Yosty22
185
Thank you very much for all of your help. I was having a lot of trouble visualizing this and the steps you have to break things down into. I really appreciate all of your help and putting up with what seems to be nothing short of my ignorance on how to approach this. I really appreciate it.
Suggested for: Kirchoff's Law Problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
