1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Kirchoff's Laws
  1. Sep 14, 2006 #1
    http://img157.imageshack.us/img157/2147/showmegf4.gif [Broken]
    a) What is the current I1 which flows through R1?
    I1 =
    (b) What is the current I3 that flows through R3?
    3 Equations
    I1-I3 = 0
    I1R14 + I1R2 - E1 =0
    I3R2 + I3R3 +E2 = 0
    is that even right?
  3. Sep 14, 2006 #2
    Not quite.
    Label the node in between R1, R3, and R2. What can you say about this node in terms of current?
    From kirchoff's law you know that
    [tex] \sum i_{in} = \sum i_{out} [/tex]
    The trouble you are having is that there is another current. Can you see why?
    Looking at that node we talked about.
    [tex] I_1 = I_2 + I_3 [/tex]
    where [itex] I_2 [/itex] is defined as leaving the node.
  4. Sep 15, 2006 #3
    so is this how?
    I1 = I2 + I3
    I1R14 + I2R2 - E1 =0
    I2R2 + I3R3 +E2 = 0
  5. Sep 15, 2006 #4
    For the last equation, you want to make sure you keep the signs right. You can indicate a drop of voltage as a result of resistors as NEGATIVE, while an increase in PD as a result of a cell as POSITIVE or vice versa, just keep it CONSISTENT
  6. Sep 15, 2006 #5
    So
    I1 = I2 + I3
    -I2R2 - I3R3 +E2 = 0
    i tried that and it is not the right answer
  7. Sep 15, 2006 #6
    Ok so im guessin it is something like that
    I1 = I2 + I3
    -E1 + I1R1 + I2R2 + E2 + I1R4 = 0
    wat bout the 3rd equation? Thanks
  8. Sep 15, 2006 #7
    try writing KVL for the other loop
  9. Sep 15, 2006 #8
    Actually
    I1 = I2 + I3
    E2+R2I2+R3I3
  10. Sep 15, 2006 #9
    HW is due in 2 hrs and i tried everything any help is appreciated :redface:
  11. Sep 15, 2006 #10
    The two loop equations are:
    [tex] -\xi_1 +I_1(R_1) +I_3(R_2) +\xi_2 +I_1(R_1) = 0 [/tex]
    [tex] -\xi_2 -I_3(R_2) +I_2(R_3) = 0 [/tex]
    Note: That is two equations with THREE unknowns. So you need to come up with another equation to solve.
  12. Sep 15, 2006 #11
    Thanks Alot
  13. Sep 15, 2006 #12
    Try to do this when you are coming up with the equations.
    1) First draw the currents (you can choose whatever direction you want).
    - Remember that current does not change when passing elements in a series. - It only changes when it reaches elements in parallel.
    2) Traverse a branch (ie make a loop).
    - When you get to an element (such as a resistor) if the current direction is pointing into the element then write that voltage term (ie V=IR, where I = current going into the element, and R = the resistance of the element) as POSITIVE.
    - If you are going around the loop and you reach an element but the current is pointing in the opposite direction of the element, then write that term as NEGATIVE.
    - Set all of these terms equal to 0. Take note that the voltage supplied (such as from a voltage source) is equal to the voltage drops (such as a resistor takes away a certain amount of voltage).
    You really need to do a few examples for all of this to sink in.
  14. Sep 16, 2006 #13
    ok sorry but this equation for some reason did not work, i know one equation should be
    I1 = I2 + I3
    -E1 + I1R14 + I2R2 + E2 = 0
    I just still cant get the third equation for the left loop
    i was thinking it was
    -E2 + R2I2 + R2I3 + R3I3
    any help, thanks
  15. Sep 16, 2006 #14
    Woops sorry buddy. I interchanged I2 and I3.
    The correct equations for this network are:
    -E1 +I1R1 +I2R2 +E2 +I1R4 = 0
    -E2 -I2R2 +I3R3 = 0
    I1 = I2 +I3
  16. Sep 16, 2006 #15
    lol :( nope not it i have the answer, it is the 2nd equation that is giving me trouble to get. i need to understand this for coming exam. I asked my TA and he said it is not a straight forward thing
  17. Sep 16, 2006 #16
    Are you saying that what I posed (the last one) is not the right answer?
    If that's the case, let me know what the right one is.
    It is VERY straightforward... I have no idea why your TA is saying that. You basically have to remember two things.
    1) the voltage around a loop is equal to zero.
    2) current in equals current out.
  18. Sep 16, 2006 #17
    Never mind, for some reason it wouldnt accept my answer but i kept clickin ok and all of a sudden it took it. I had the equation from the start way before i did this thread. It wouldnt just accept my answer. Damn computers. Thanks for ur help
  19. Sep 16, 2006 #18
    I'm almost positive the last answer I put down is correct... if I'm wrong, I'm either having a huge space out (I did already with the switching of I2 and I3) or I have no idea what I'm doing... (which I hope is not the case ;)
    oh...
    so what is the answer?
  20. Sep 16, 2006 #19
    Answer was .031 but i had .03064435 even though it says on top to keep all sig figs and to aviod rounding
  21. Sep 16, 2006 #20
    ur equations were right
Similar Discussions: Kirchoff's Laws
  1. Kirchoff's Laws (Replies: 25)
  2. Kirchoffs law (Replies: 1)
  3. Kirchoff's Law (Replies: 5)
  4. Kirchoff's Laws (Replies: 26)
  5. Kirchoffs Laws (Replies: 6)
Loading...
