Kong Physics
  1. Mar 1, 2008 #1
    (I have already posted this problem in the physics help, but it is more math than physics, so I am also posting it here)
    For a physics experiment, we had to take a kong (dog toy with a rubber ball on the end of a rope), twirl it and then throw it as far as we could. We were told to record how long it was in the air for, and the distance for two throws. This was all was we were told to record. Afterwards, we need to find the maximum height the kong reaches, it's horizontal velocity as it is in the air and it's vertical velocity when it hits the ground.
    Throw #1-
    Distance: 52m
    Time: 4.9s
    Throw #2-
    Distance: 65m
    Time: 3.84s
    So far, I have been able to figure out the horizontal velocity by using V=d/t.
    #1- 52m/4.9s=10.61m/s
    #2- 65m/3.84s=16.93m/s
    Now, I think that in order to find the vertical velocity, I would need to first find the kongs maximum height, and then divide this by half of the time, (since at the halfway point the kong will now be traveling horizontally, and would take the same amount of time to reach the ground as a kong that is dropped from the same height). However, I am not sure on how to find the maximum height.
  3. Mar 1, 2008 #2
    HallsofIvy
    Do you know the formulas for the horizontal a vertical distances and speeds? Putting distance and time into the formula for vertical distance should tell you the initial vertical speed and then you can use the distance formula, with half the time, to find the maximum height.
  4. Mar 1, 2008 #3
    no, I don't know the formula, :(
  5. Mar 1, 2008 #4
    ok, i think i figured out how to solve it. at half the total time, the kong will be going horizontal, so the time it will take to reach the ground is the same as if it was just dropped from the same height. I can than use x=1/2(a)(t^2) to find the height. WOuld this work right?
  6. Mar 1, 2008 #5
    ok, here is what i got...
    #1-
    Horizontal Velocity- 10.61m/s
    Vertical Velocity- 12.25m/s
    Maximum Height- 30.01m
    #2-
    Horizontal Velocity- 16.93m/s
    Vertical Velocity- 9.6m/s
    Maximum Height- 18.43m
