rachelle
- 18
Hi, I'm trying to do my prelab and I have no idea where to start... if someone can point me to the right direction, I will absolutely be grateful...
Given the following equilibrium:
PbI2 <----> Pb + 2I
You have a solution of the following:
4.77 ml of .00274M Lead Nitrate solution
4.35 ml of .00215M Iodide solution
5.00 ml of water
You measured the solution and get the following:
%T blank = 100.3 %
%T sample = 42.9 %
Absorbance of a 1.000 mM Iodide soln = .775
Calculate the following:
micromoles of Pb(II) originally put in solution
micromoles of I- originally put in solution
mM of I- at equilibrium
micromoles of I- in solution at equilibrium
micromoles of I- precipitated
micromoles of Pb(II) precipitated
micromoles of Pb(II) in solution at equilibrium
mM of Pb(II) in soluion at equilibrium
Ksp
The only ones I solved that were correct were the following:
total volume = 14.12 ml
absorbance of sample = .3688
Hope someone can help me...
PbI2 <----> Pb + 2I
5.00 ml of water
%T blank = 100.3 %
%T sample = 42.9 %
Ksp
