Homework Help: KVL Exercise - Basic
  1. Feb 6, 2013 #1
    Click on the link
    https://www.diigo.com/item/image/2sb3i/yjim [Broken]
    2. Relevant equations
    KVL Law
    Similar Example :
    https://www.diigo.com/item/image/2sb3i/orwa [Broken]
    3. The attempt at a solution
    (a)
    In the left loop :
    -8-12+VR2 = 0
    VR2 = -20 v
    (b)
    In the big loop :
    -8-12+7-9-V2-3+VR1 = 0
    -8-12+7-9-V2-3+1 = 0
    V2 = -24
    Why is my solution wrong?
    If I take the right loop for (b) using the right answer for (a) :
    -4+7-9-V2-3+1 = 0
    V2 = -8 which is true.
    Is the wrong with the negative voltage (-8) ??
    thanks.
  3. Feb 6, 2013 #2
    gneill
    Staff: Mentor
    Yes, it looks like whoever created the circuit diagram created confusion when they labeled the leftmost resistor's potential drop. As it is marked, strictly speaking there should be a -8V potential drop across that resistor proceeding from bottom to top, which translates into a +8V potential rise as you've properly interpreted it. However, it would appear that they (confusingly) intended the "+ -" indicators to show the actual direction of the potential change of 8V.
    Bottom line: assume that the "-8V" is really "8V" oriented according to the "+ -".
  4. Feb 6, 2013 #3
    thank you
    but I see that there is no difference if it was "+8" instead of "-8" ???
  5. Feb 6, 2013 #4
    gneill
    Staff: Mentor
    Um, how can it make no difference if you change the sign of a potential change?
    For part (a) your equation summing the potential drops would become: +8-12+VR2 = 0
  6. Feb 6, 2013 #5
    ok, how the solution of (a) will be if :
    https://www.diigo.com/item/image/2sb3i/y0us [Broken]
  7. Feb 6, 2013 #6
    gneill
    Staff: Mentor
    Just solve your equation that I presented in my previous post...
  8. Feb 6, 2013 #7
    I'm sorry
    but can you tell me the equation of (a) if the potential change was "-8"?
    I thought that the equation +8-12+VR2 = 0 is used when the potential change = -8.
  9. Feb 6, 2013 #8
    gneill
    Staff: Mentor
    Yes, that's right. The problem is not with your understanding, it's with the problem itself; the resistor is not labeled correctly for the given answers. The resistor should have its potential labeled as "8V", not "-8V", or alternatively, the + and - tags should be reversed.
  10. Feb 6, 2013 #9
    aha
    thank you Mr. gneill
